 Old 08-18-2017, 12:41 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Default Strange idle...lite popping?
My idle doesn't sound quite right. Sounds like one cylinder isn't like the rest. Compression is good. Hasn't been long since I replaced plugs. Cleaned injectors earlier this year. No codes. Drives good. Tuned on 93, but running E20 mix which is pushing the fuel trims up a few %. Mods in sig.
https://youtu.be/NWXDH2h8xoo
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
tom10122 (08-19-2017)
 Old 08-18-2017, 01:25 PM   #2
ffej's Avatar
Posts: 14   (View Stats)
ffej will become famous soon enoughffej will become famous soon enough
I couldn't get the video to load, tried on 2 devices.
2008 speed3. Mazdaspeed CAI and Cat back, Corksport downpipe, AP and 1 blown engine
ffej is offline   Reply With Quote
 Old 08-18-2017, 03:35 PM   #3
aackthpt's Avatar
Posts: 1,450   (View Stats)
Content Warning
If the owner of this video has granted you access, please sign in.
Inside a button: This video is private.
2013 'speed3, silver
Stage Bro
 Old 08-18-2017, 04:57 PM   #4
Fstrnyou's Avatar
Sry. Fixed now. I thought link would work as private. Changed it to unlisted.
Other rides:
History:
 Old 08-18-2017, 08:59 PM   #5
speed23's Avatar
Posts: 1,480   (View Stats)
Hmm...that don't sound too good.
 Old 08-18-2017, 09:16 PM   #6
Fstrnyou's Avatar
Stock exh. manifold too. I know equal length will sound different.
Other rides:
History:
 Old 08-21-2017, 01:54 PM   #7
aackthpt's Avatar
I take it the high pitched noise is just insects or something? Anyway it does certainly sound like one cylinder misses, and then hits once in a while. However I'm not really convinced that's all that abnormal. I will go listen to the exhaust on my speed later and compare.
Stage Bro
 Old 08-21-2017, 02:49 PM   #8
Fstrnyou's Avatar
The high pitch seems to be some sort of resonant "squeaking"? Exhaust vibration of sorts I guess.
Other rides:
History:
Speed3$ (11-21-2019)
 Old 08-22-2017, 08:13 PM   #9
Fstrnyou's Avatar
Showed the video to a friend. He said his mom's Forester with sticky valve buckets sounded exactly like that. I guess it couldn't hurt to do a seafoam oil flush.
Other rides:
History:
 Old 08-23-2017, 10:56 AM   #10
aackthpt's Avatar
Haha. I wouldn't go that far... sure it could. At least plan to change the oil immediately if you mess around with that crap.
Stage Bro
 Old 08-23-2017, 03:09 PM   #11
Fstrnyou's Avatar
The general consensus I've seen is change oil within about 100 miles or so of putting that stuff in. I'd like to give it time to disolve the gunk, but not soo long that it wears out metal from not getting adequate lubrication. There's also MMO, but I've read that's mostly kerosene. Ha.
I will admit I have been on a 5000 mile OCI since i bought this car a year and half ago. Entirely too long, especially for the way I drive. Built motors running big power might change at 2000.
Other rides:
History:
Jakeypoo (08-23-2017)
 Old 07-04-2019, 06:06 PM   #12
ghost-rider's Avatar
Posts: 10   (View Stats)
ghost-rider will become famous soon enoughghost-rider will become famous soon enough
Got some update or solution for this issue recently??
HM-Upgrade K04 Turbocharger, 3" Corksport Catted DP, 3" FMS Catback Exhaust, HG-Motorsport HPFP Internals, Upgraded TMIC, Silicone Turbo Inlet Pipe+Neck, Silicone Intercooler Hose, Simota Podfilter, GFB Mach 2 BPV, Primary EGR Delete Kozmic, PTFE Intake and Throttle Gasket, Throttle Coolant Delete, Cobb Accessport V3
ghost-rider is offline   Reply With Quote
 Old 07-05-2019, 03:15 AM   #13
Fstrnyou's Avatar
No solution. Still does it.
Other rides:
History:
ghost-rider (07-05-2019)
 Old 07-05-2019, 11:08 AM   #14
Police - Grammarhead
Vansquish's Avatar
My car has been doing something like that for the last 120,000 miles. I'm not concerned.
 Old 07-05-2019, 07:48 PM   #15
Fstrnyou's Avatar
Didn't realize the age of this thread. I've rebuilt the engine since the OP and it still did it. So I'm not concerned either.
Other rides:
History:
Strange Idle and more t2heavy Gen2 MS3 General Discussion 11 02-12-2014 06:00 AM
Strange Behavior at Idle on Cold Start Redline143 2010 MS3 - Troubleshoot/Diagnostics 9 10-16-2012 07:07 AM
VW says Up! Lite will get 70 mpg Haltech Automotive News 0 12-03-2009 03:10 AM
Strange High Idle Problem nytmar3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 12-01-2009 04:14 PM
Strange Idle Issues after FMIC Install nytmar3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 06-21-2008 12:11 AM
Page generated in 0.32455 seconds with 25 queries
