![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Ive changed my axel control arms and shock still geting a popping noise when i hit pot hole go over a bump or shaking the steering wheel left and right. What can it be? |
Groans: 211
| Not Ranked : 0 score What are axel control arms? Do you mean the lower control arms front and rear? Where did you get them? What brand? Most likely its your sway bar bushings and/or sway bar end links. Try spraying the sway bar bushings with lithium grease and see if the noise goes away. Whats the condition of the upper ball joint? When you changed the shocks did you also replace the strut mount bearings?
(Thread Starter) | Not Ranked : 0 score Control arms axel struts part from auto zone all cprrect parts noise happened before the replacement. I did not change Strust mount bearing due to it being in good conditions. |
| CX7 Popping Noise between 2000-3000rpm | DeeOrzz340 | CX-7 > Issues & Troubleshooting | 6 | 03-07-2017 09:20 PM |
| Popping when turning wheel & general suspension questions | lreyes66 | MazdaSpeed 3/6 - Suspension & Brakes | 16 | 01-17-2017 01:29 PM |
| Popping noise from Speaker on startup | rastlun | 2010 MS3 - Troubleshoot/Diagnostics | 13 | 05-30-2013 05:54 PM |
| Rear Suspension Popping | ABQ Speed6 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 08-25-2012 07:47 PM |
| front suspension popping | frodaddyweez | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 01-14-2011 08:24 PM |
