![]() Join Date: Dec 2016 Location: So Cal
Rep Power: 0 ![]() Thanks: 30
Groaned at 6 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score Tried smogging car w/ original map sensor, but CEL said it was bad. Swapped it out w/ used 3 bar map sensor, still getting same code when I took it back in for smog. Got some MAF cleaning spray & cleaned the original MAP sensor. Installed clean old MAPsensor now car won't crank to start. I should add that i left the battery terminals connected to battery while I did the swap. It's always recommended to disconnect battery before working on a car I understand, but what I didn't shouldn't have put anything at risk. Besides checking that all the fuses are good & that my plugs were connected, what do you guys suggest i do to troubleshoot problem. I cannot believe this is happening, urgh.
__________________ Tricks get applause, style gets respect. |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Wiggle the starter wire. Jump the car. The map sensor has nothing to do with the starter. What was the code. What did you touch when under the hood other then yourself. Fwiw the only time i unhook the battery is when i unplug the ecu or a air bag harness. The worst that will happen with koeo a code could pop up.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | Db09ms3 (10-03-2018) |
(Thread Starter) | Not Ranked : 0 score Yes there was a bit of fondling once I got it all back together for the second time. Urgh was heated for sure. I'll give that a shot & report back to the thread.
| Reoccurring crank position sensor code. | Funktionull | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 10-07-2016 09:51 AM |
| need a how to on setting tdc to replace crank sensor | turd burglar | MazdaSpeed 3 - How-To's | 7 | 12-22-2015 11:09 PM |
| Car wont Crank | Oalmon | CX-7 > Issues & Troubleshooting | 30 | 07-23-2014 11:41 AM |
| swapped map sensor now car wont start | TWOptSL0W | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 11-05-2011 06:50 AM |
