 Old 08-05-2017, 07:48 PM   #1
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Default techniques to replace MS6 CV shafts
So I have a torn boot, joint is getting bad, I have to replace front cv joints
A while back, had the whole front end apart to do arms and bushings, sub frame lowered, the 9 yards
tapers were never siezed per normal during reinstall
but, just cannot get the rear arm free of the fuckin knuckle insert
I can drop the frame again and get the other end free to get at the shaft, but that would suck balls
does anyone have any tricks on that knuckle/ ball joint issue ?
or, with the front LCA dropped, rear still attached... if i remove the UCA and the 3 tower nuts,.....
would I get enough knuckle play to get the axle out ??
Leaking Drive Shafts Death-From-A-Mile MazdaSpeed 6 - Engine, Transmission & Driveline 20 06-09-2015 10:56 AM
CV Boots are done-- need CV SHAFTS oakley990099 MazdaSpeed 3 - Engine, Transmission & Driveline 31 03-14-2014 01:16 PM
Time to buy CV half shafts. But from where ? Cornjacked MazdaSpeed 3 - Engine, Transmission & Driveline 7 06-04-2013 08:53 PM
Drive Shafts? Jarods7920 MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-27-2010 09:52 PM
Page generated in 0.23448 seconds with 20 queries
