 Old 10-11-2017, 06:47 PM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
I run catless 3" dp/rp and have for eight continuous years with the stock K04 and mods below. I never developed any smoking turbo until I got to about 110,000 miles. I know some cars have smoking turbos that are completely stock, so it's hard to generalize. I don't think you will have any problem running with a stock downpipe and an aftermarket test pipe. One way to permanently fix the problem is to ditch the stock K04 for a BNR stage 1. It has the same mounting and flow as the stock K04 but has Garrett guts.
If you start smoking, you probably would have started smoking anyway. I've never used any oil, even when the K04 finally started smoking. That is probably something else, like ring lands.
I'm curious about your oil use. What is your static compression and have you done a leak down test?
One thing you can do to help with the crankcase pressure that is a part of the "smoking turbo" problem is to raise idle rpm +200 rpm. Your tuner can do that for you if it is not already in the tune.
I actually "took care" of my oil problem. I did a piston soak overnight and it must have unstuck the rings. Couldn't believe it. Went from a quart every 100 miles to a quart every 2000 which is good enough for me. Compression was 155 across the board with 135 for cyl 3. Didn't check after the piston soak though.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
The Following User Says Thank You to tom10122 For This Useful Post:
MSMS3 (10-11-2017)
MS3 08 Smoke from tail pipe ThunderMidget MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-23-2011 06:25 AM
Brand name test pipe vs. custom muffle shop test pipe Huligan MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-05-2009 07:52 AM
Page generated in 0.22973 seconds with 21 queries
