  • 2 Post By MSMS3
 Old 02-05-2019, 10:04 AM   #1
JackDG's Avatar
Posts: 21   (View Stats)
JackDG will become famous soon enoughJackDG will become famous soon enough
Default Is there a way to tell if my vvt chain has been done?
When I bought the car the previous owner said it had been done, but there is no paperwork to prove this. Just wondering if there is a way to tell if it has been by inspection?
Has about 87000 miles and sounds fine.
JackDG is offline   Reply With Quote
 Old 02-05-2019, 10:49 AM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You can see the heat treatment by the button on the vvt actuator.
 Old 02-05-2019, 02:10 PM   #3
JackDG's Avatar
thanks for that.
What exactly am I looking for in regards to that? I am new to car mechanics!
 Old 02-06-2019, 06:44 AM   #4
Reds3's Avatar
Posts: 31   (View Stats)
Reds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the rough
i would assume discoloration from the heat treatment. blue-ish, orange tint of some kind.
2007 Mazdaspeed 3 / Cobb SRI / 219K and Counting
1995 EG6 B16A3 78K *sold*
Reds3 is offline   Reply With Quote
 Old 02-06-2019, 12:04 PM   #5
Posts: 2,826   (View Stats)
Neutral  +1 score
Isn't it possible to take it to any dealer and have them run the VIN? That ought to show any work done while it was still under warranty.
danb and Reds3 like this.
 Old 02-06-2019, 02:45 PM   #6
Posts: 2,233   (View Stats)
As long as the job was done by the dealer....
The older VVT unit was prone to crack but even if you have an updated VVT, it doesn't mean your chain cannot get slack and gring your valve cover....I think my late 2007 ms3 had the updated unit and my VC had still heavy marks when i opened it at about 90k miles....
You may remove the VC and check it for marks.
You can check for chain slack from the vc cap when the car just stopped with remaining oil pressure...
I don't know if a snake cam could be used to see how much extended is the chain guide extender from the top....???
 Old 02-07-2019, 10:36 AM   #7
VIC-CX7's Avatar
Posts: 13   (View Stats)
VIC-CX7 will become famous soon enough
I replaced my VVT actuator with a new post TSB unit and yes there was a distinct dark blue mark on the front face where they apply heat treatment to an internal pin to make it last longer. I did all my work on my 2007 CX7 at 55k miles, and the timing chain was already very noisy, and would be especially noisy during initial engine startup of the day for the first 3-5 seconds until oil would quiet the valvetrain and chain noise somewhat. The chain tensioner was already fully extended and the chain was already loose and beginning to grind on the valve cover.
After installing the new parts, the engine sounded like new again and today at 95,000 miles it still sounds good, no noises from chain or VVT.
If your engine has 87,000 miles on it and is not making any noise, chances are it was already repaired and most probably the improved VVT actuator, new chain and tensioner were installed.
My 2 cents.
VIC-CX7 is offline   Reply With Quote
 Old 02-07-2019, 04:00 PM   #8
JackDG's Avatar
thanks everyone for replies.
Good idea with the dealership, I will check that out. the car has a fairly full mazda digital service record so that bodes well.
I had a proper listen on a cold start up with the hood up today and absolutely no vvt noise so I am confident its not about the immediately blow up!
Page generated in 0.29404 seconds with 25 queries
