 Old 01-13-2019, 04:53 AM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
Sounds like your gonna need either rings or a valve job but I'd lean towards you needing rings, save up and buy forged pistons and good rods so it doesn't go zzb
06 Speed6
White/Black interior
Thoughts on this compression test please redvine MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-16-2019 09:57 AM
Compression test bross2009 MazdaSpeed 6 - Engine, Transmission & Driveline 6 10-30-2017 11:58 AM
Compression test..... Colepidd55 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-07-2014 01:56 PM
compression test SLOWHATCH Gen2 MS3 General Discussion 35 03-14-2013 07:47 AM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
Page generated in 0.22201 seconds with 21 queries
