![]() Join Date: Dec 2014 Location: Orlando Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
__________________ Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds |
| Not Ranked : 0 score If you're talking about the bolt that holds the turbo onto the bracket I'm pretty sure I either use a ratchet and muscle it or stack two wrenches for more leverage.
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
| Not Ranked : 0 score long handle wrench, with additional leverage as necessary. 11 Piece Metric Highly Polished Long Handle Combination Wrench Set that's a bitch of a bolt.
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel |
(Thread Starter) | Not Ranked : 0 score I know I'm about to sound retarded but might as well ask.... So I'm on the passenger side pulling towards me..... That's correct right.... I gotta ask just cus this shot is mind boggling tight
The way I always think about removing bolts/nuts (if they're right hand threaded which 99% of stuff is) is spin right (clockwise) to move it away from you or spin left (counterclockwise) to pull it towards you. In this case, since the bolt head is upside down, you want it to move away from you so (looking down at it) you would want to spin it right.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
__________________ Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds | |
| The Following User Says Thank You to Tuff Gong For This Useful Post: | tom10122 (03-08-2017) |
(Thread Starter) | Not Ranked : 0 score So everything is back together and i get an error code for heated oxygen sensor bank 1 sensor one, got the sensor in as tight as possible (not rediculous) so i dont really know wtf.... this ever happen to yall after downpipe/turbo install
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score is it plugged in? Did you not route the cable correctly and melt something?
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
(Thread Starter) | Not Ranked : 0 score Yeah routed it the same way it came on the car with those twisty clips on the downpipe, then under turbo then plugged in.... Ill double check on my next day off
(Thread Starter) | Not Ranked : 0 score Actually just got the p0031 and p0134 code ... Ill change it tonight .... I hope its not the harness that the sensor plugs into thats dead.
__________________ Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds Last edited by Tuff Gong; 03-09-2017 at 01:39 PM. |
| Not Ranked : 0 score Righty tighty, lefty loosey. Have known that since I was like 5 when I was "helping" my dad remove wheels from his 70's dodge van.
| Removing Shock/strut bolt | cole_slaww | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 07-14-2014 08:34 AM |
| Tips on removing intake duct... | deyomatic | 2010 MS3 - Engine, Transmission & Driveline | 8 | 08-03-2012 06:38 AM |
| Removing bolt that is stripped? | 79BlueSC | 2010 MS3 - Troubleshoot/Diagnostics | 9 | 07-27-2011 10:36 AM |
| st00pid fucking engine mount - RE: driver's side tranny mount bolt | phillyb | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 12-31-2008 12:44 PM |
