Like Tree56Likes
 Old 08-03-2011, 06:14 AM   #41
bbarnhill's Avatar
Posts: 271   (View Stats)
bbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the world
you dont have to edit the log to get rid of the decel portion. The TPS trimming feature gets rid of that. Thats why TPS is a required field.
Brad Barnhill
VIRTUAL DYNO
The ONLY way to graph your runs.
www.bradbarnhill.com/projects/VirtualDyno
bbarnhill is offline   Reply With Quote
 Old 08-03-2011, 03:07 PM   #42
fjames's Avatar
Posts: 1,058   (View Stats)
Originally Posted by bbarnhill View Post
you don't have to edit the log to get rid of the decel portion. The TPS trimming feature gets rid of that. Thats why TPS is a required field.
That doesn't seem to work with a multi-gear log. I assumed it would cut off the second gear but it doesn't - picks it up when you go back to full throttle. Be nice if it just picked up the first gear in a log and ignored everything after ... or even better maybe a check box for 2 gears, with rescaling the chart and whatever
I always thought this was a phone app so ignored it. Finally looked and nice job, donation on the way.
 Old 08-03-2011, 03:13 PM   #43
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That's my only complaint about the program. I usually do 3 4th gear runs in a single log, wipe out the irrelevant non-WOT data, and analyze from there. I have to trim even further and save each run to its own file if I want to use it in virtual dyno.
 Old 08-03-2011, 05:23 PM   #44
fjames's Avatar
Of course, since it's time based, if you really wanted to use VD as a tool, you'd have to be sure use the same piece of road for logging. Even a rough surface can mess it up I think, and undulations, and uphill one time and down the next etc.
Where i live there are no flat roads really, and I don't worry about it for normal logging, just go to the same area each time. But if I want to make a dedicated VD log, I have to find an exact spot to start that gives me room for 4th gear and no undulations or changes in angle of the road.
If I find that exact spot though, it would be nice to be able to "combine" logs and go ahead and shift without having to do extra housekeeping later.
 Old 08-03-2011, 05:31 PM   #45
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I don't tune with VD...it ain't like that....you still tune with the logs.
I use VD to compare if I am making a difference over my base map. I also use the same piece of road...2 flat stretches from 1 on ramp to the next off ramp.
I use it like I would at a dyno...car rolling below 2000rpm, with no throttle (in fact, stab the brakes with right foot for good measure), then floor the accelerator til redline.
In one of my conversations with Christian@Cobb, he told me that the 335 guys use something like a 30 - 90 roll and time it to the tenth of a second to gauge if they're making more power. Using VD is similar to that except you add a lot more parameters to it to make it more scientific.
-- Mario Andretti --
 Old 08-03-2011, 07:02 PM   #46
fjames's Avatar
Exactly, for repeatability with it, you must use the exact piece of road. If you do, it's a useful comparison tool when tuning, at least it should be.
I was trying to say that when normal logging, I don't worry so much because I'm the one interpreting the numbers, not some software. But with VD doing the math, you have to give it consistent inputs.
 Old 08-04-2011, 04:31 AM   #47
bbarnhill's Avatar
I dont think VD will ever take multiple pulls in the same log and decipher which is a run which just messing around, and taking gear into account isn't really feasible since all the loggers it supports do not record gear. It was a big enough hassle when I went to requiring TPS. People REALLLLLY chewed me over that one. On a normal dyno you would record a run then start a new run to make a pull. Thats how we did it on the 2 4-wheel superflows we had at Hypertech when I worked there. I tried to mimic the use of a real dyno as much as possible.
Brad Barnhill
VIRTUAL DYNO
The Following 2 Users Say Thank You to bbarnhill For This Useful Post:
AZSPEED3 (08-05-2011), rigor (04-01-2012)
 Old 08-04-2011, 06:03 AM   #48
brad i sent you a PM. for some reason i am missing the columnnames.xml file.
anyone willing to send me their file?
 Old 08-04-2011, 06:33 AM   #49
EDIT: NM im behind a proxy at work but as soon as i disabled it i was able to get the cars/colums updates and everything is kosher now.
 Old 08-04-2011, 07:07 PM   #50
fjames's Avatar
I don't think VD will ever take multiple pulls in the same log and decipher which is a run which just messing around, and taking gear into account isn't really feasible since all the loggers it supports do not record gear. It was a big enough hassle when I went to requiring TPS. People REALLLLLY chewed me over that one. On a normal dyno you would record a run then start a new run to make a pull. Thats how we did it on the 2 4-wheel superflows we had at Hypertech when I worked there. I tried to mimic the use of a real dyno as much as possible.
As far as what I wrote earlier I think you're misinterpreting it. My basic point was that if you can trim the "before" on throttle position, maybe you could trim the "after" as well. That way, those of us that routinely do multiple gear logs could just drop them in, instead of having to edit them as we do now.
I.E. it would just grab the first set of full throttle rows and ignore everything else.
The Following User Says Thank You to fjames For This Useful Post:
Fobio (08-04-2011)
 Old 08-04-2011, 10:19 PM   #51
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Or you can manipulate the data yourself. Transfer to excel, make pretty, copy and paste to a text document and roll.
You could do it by gear. It would be should extremely feasable if the user wanted to actually make their data pretty for the program. Unfortunately everyone wants your program to do this for them.
Drop a 100 in all tps entries that they want recorded. Then the user can create a column with the number gear 1,2,3,4,5,6 and then your program uses if scenarios and caluclated by what number it finds.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 08-04-2011 at 10:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-05-2011, 10:19 AM   #52
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I too am missing the columnnames.xml. I ran the install and started the application but the file didn't generate. Why would a proxy setting have anything to do with an application that doesn't require internet connection?
Is there a template/update that It pulls from a server?
RichieRichness is offline   Reply With Quote
 Old 08-05-2011, 10:22 AM   #53
does require an internet connection AFAIK.
thats how it gets its updates i think
 Old 08-05-2011, 11:42 AM   #54
Driver
Fobio's Avatar
Groans: 44
for you guys missing files, just a note, that the files you're looking for is in a different folder than the actual install folder inside "Programs"...
that column file is actually in the "Program Data" fodler in C:, then under "Virtual Dyno".
 Old 08-05-2011, 11:56 AM   #55
Groans: 35
nope
 Old 08-05-2011, 12:11 PM   #56
nope
do you have an internet connection when you first open the program thats not blocked by anything?
 Old 08-05-2011, 12:31 PM   #57
Groans: 35
Not at the moment but i'll try when I get home...and im sure it will work. I'm just saying...why the fuck did this file not already come installed when you run the .exe? lolz
 Old 08-06-2011, 07:28 AM   #58
bbarnhill's Avatar
It comes after the install with the first update. It requires an internet connection on install. It is required on the first startup to get the column definitions, and car definitions. It cuts out a HUGE maintenence nightmare of updating the installer with each car definition thats added. I have the process automated to build the car definitions into a zip file which is downloaded from the server on startup. Its quick, and works on 99% of all machines.
Also I am fairly certain it uses port 80 right now which is the normal HTTP port to contact the server for updates. I will force this in the next release so that everyone knows what port its going to communicate on.
Brad Barnhill
VIRTUAL DYNO
RichieRichness (08-08-2011), Teal (09-30-2011)
 Old 08-06-2011, 07:33 AM   #59
bbarnhill's Avatar
Dont get me wrong ... you dont have to have an internet connection after the first startup as it tries to check for any updates and sees that there is no connection and it just goes on. The first load has to do it just because all the files are in the installer (for my sanity).
Brad Barnhill
VIRTUAL DYNO
The Following User Says Thank You to bbarnhill For This Useful Post:
rigor (04-01-2012)
 Old 08-06-2011, 11:46 AM   #60
jman46's Avatar
Posts: 3,169   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groaned at 26 Times in 20 Posts
Pretty cool program!
'06 F350 Lariat PSD - 458whp/818wtq
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485whp/435wtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is offline   Reply With Quote
 Old 08-06-2011, 11:51 AM   #61
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
Holy hell. Those numbers are high. My best has been 316hp/349tq
Lol whats going on with your boost line? Looks like it is trying to double back
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
 Old 08-06-2011, 11:51 AM   #62
Burn69's Avatar
Posts: 143   (View Stats)
Burn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to behold
Groaned at 7 Times in 4 Posts
Looks like a nice program, have we been able to verify repeatability of accuracy yet?
2012 Speed3 w/ Tech. / SURE Full3 Aeros & TIP Combo / SURE Shortcut w/ Counterweight / SURE TorqR3 RMM / SURE AGS Shift Knob / COBB AP Programmer / CNT CBE Blue Tip / UR Test Pipe / RallyArmor Flaps / SPC Rear Camber Arms / MORE (coming soon).....
Burn69 is offline   Reply With Quote
 Old 08-06-2011, 11:58 AM   #63
I've been using the program for about 2 months now. In that time, I've gotten DP and TMIC. Also switched over from OTS stage 2+ map to the boost tuning beta map.
In my experience, the program seems pretty consistent.
I started with around ~255/280 average before w/o the DP/TMIC, on the load tune.
Now, I'm seeing ~300/325 average with the DP/TMIC on boost tune.
09 MGM Sport
 Old 08-06-2011, 12:27 PM   #64
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Yeah same here, good results. Have done many dyno pulls with the virtual dyno and get very similar results.
AZSPEED3 is offline   Reply With Quote
 Old 08-06-2011, 03:01 PM   #65
jman46's Avatar
That's because Dusty is tuning my car . That is my "all time" high so far without my DP, my average numbers though are 312/331.
'95 SHO MTX - sold
 Old 08-08-2011, 07:07 AM   #66
bbarnhill's Avatar
Guys this isnt the first forum its been released on Its been tested in the Evo and Subaru, and GM worlds. Everyone is skeptical till they get it compared to their dyno ... then they are sold on it. Ive got some runs somewhere of a car in kansas that dynoed 701, 702, 703 back to back and then ran a pull on the street and VD showed 700hp. Ive seen them compare 300hp cars all the way to 800hp cars on this thing. All with the same results.
It DOES require a good log though. If you go get a log on a bump road, with wheel spin or a slipping clutch ... dont expect a miracle out of VD it wont fix that run. Itll look like crap
Brad Barnhill
VIRTUAL DYNO
Bucker (09-04-2011)
 Old 08-09-2011, 06:49 AM   #67
Realgib3's Avatar
Posts: 2,443   (View Stats)
Yeah I took a log grom from Pearl_Ms3's dyno thread and the vd was within like 3whp and 5wtq of his dyno...
AZSPEED3 (08-10-2011)
 Old 08-09-2011, 08:07 AM   #68
bbarnhill's Avatar
Thanks Realgib3 ... Ive got this thing on SEVERAL forums and every forum goes through ... "is it accurate" phase ... they all launch a huge test thread on it ... they all come to the same conclusion.
Brad Barnhill
VIRTUAL DYNO
Realgib3 (08-09-2011), rigor (04-01-2012)
 Old 08-09-2011, 09:38 AM   #69
Realgib3's Avatar
Yeah I dont doubt it. I'm thoroughly impressed so far
 Old 08-09-2011, 09:50 AM   #70
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
The most important thing when using a tool like this is that its consistent, not that its 100% accurate (though its pretty close for me). I've been really happy with the program.
 Old 08-09-2011, 07:56 PM   #71
bbarnhill's Avatar
Its as consistent as the logs are. Some people dont know how to log properly. By that I mean picking the road to log on, they think I can compensate for torque converters, and slipping clutches. Im just not a miracle worker.
Brad Barnhill
VIRTUAL DYNO
Realgib3 (08-12-2011)
 Old 08-09-2011, 08:46 PM   #72
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
My guess is it's from FFS while logging. If the VD program is picking up the actual pedal position, it will analyze all the data through the shift.
Here's a log of mine from a couple weeks ago. Looks great.
Edit: this is with the stock CDFP and TMIC.
 Old 08-10-2011, 12:53 AM   #73
WOAH
09 MGM Sport
 Old 08-10-2011, 07:04 AM   #74
silvapain's Avatar
Groans: 136
WOAH
Why did you use smoothing 1? Just curious; all the dynos I've ever run on use smoothing 3 so that's what I used.
- Tapadatass
 Old 08-10-2011, 07:25 AM   #75
somethings def wrong with your load curve worstepever
 Old 08-10-2011, 07:30 AM   #76
daafisch's Avatar
Groans: 58
I've had my curves come out like this when I've hit a bump during the log.
The Following User Says Thank You to daafisch For This Useful Post:
jman46 (08-10-2011)
 Old 08-10-2011, 09:04 AM   #77
jman46's Avatar
Agreed, I loaded up a log I did on a shit back road that wasn't the smoothest and it said I had like 420hp and like 485tq......I only wish!
'95 SHO MTX - sold
 Old 08-10-2011, 10:40 AM   #78
It was a flat road.
I know it's an anomaly because no way I'm making that power.
09 MGM Sport
 Old 08-10-2011, 04:12 PM   #79
bbarnhill's Avatar
yeah thats definately a bump in the road or something like that ...
Brad Barnhill
VIRTUAL DYNO
 Old 08-10-2011, 04:30 PM   #80
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
I think this thing is a lot more accurate than the PTuning dyno.
VD sheet
Ptuning Dyno dynamics sheet
RichTuned
BlueDmnSpeed is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/virtual-dyno-85289/
Cobb Dyno - Colorado Mazda Club This thread Refback 11-21-2011 11:22 AM
Mazda Owners Club SA • View topic - Virtual Dyno This thread Refback 09-09-2011 04:44 AM
Virtual Dyno Program kyoo Mazdaspeed3/6 General Discussion 58 08-01-2011 08:57 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.59499 seconds with 35 queries
