Like Tree56Likes
 Old 06-25-2013, 01:44 PM   #841
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
bumping an older thread oops but I have a question:
@bbarnhill;
When entering SAE options. For barometric pressure, should it be based of our altitude or should we be entering the current barometric pressure? Because basing it off my current altitude (2200 Ft) I end up getting a barometric pressure of 27.72 in/Hg. When I search up the current pressure it comes our to ~29.6 in.Hg. This is a big difference when plugging in these numbers. like 20-30 whp difference...
Performance:
Stratified Tune in progress
 Old 06-25-2013, 01:49 PM   #842
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You should use your current pressures. If you have a local weather station, you can probably get up to date info from them.
-06 MS6
-Corn fed 07 MS3 - Sold
ms3blackmica (06-25-2013), Swinger13 (06-25-2013)
 Old 06-25-2013, 09:14 PM   #843
bbarnhill's Avatar
Posts: 271   (View Stats)
bbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the worldbbarnhill is the leader of the world
its your local barometric pressure. You can obviously correct using SAE but I recommend using it without SAE correction because what VD will put out as a graph will be what your car makes not what it 'could' make at some place that you are not. Thats just my two cents that depreciate daily.
Brad Barnhill
VIRTUAL DYNO
The ONLY way to graph your runs.
www.bradbarnhill.com/projects/VirtualDyno
bbarnhill is offline   Reply With Quote
The Following 3 Users Say Thank You to bbarnhill For This Useful Post:
atvfreek (06-26-2013), Realgib3 (06-27-2013), Swinger13 (06-25-2013)
 Old 10-14-2013, 05:44 AM   #844
atvfreek's Avatar
Posts: 7,787   (View Stats)
Originally Posted by bbarnhill View Post
Here is the release of the full version of the standalone HP/TQ graphing application that reads Evoscan logs, and doesnt require Excel or copy and pasting your data.
The interface is pretty self explanatory. You can drag your CSV files to the panel on the left, then enter the appropriate data in the box that appears and your graph should appear. There are several graph options and those can be accessed from the menu at the top. There are only a few cars in the data file as of the initial release but as soon as a few more people test it and get me data on other vehicles I will add more.
The link to the page is http://www.bradbarnhill.com/projects/VirtualDyno/
Click Here to download the latest version
Feel free to let me know what you think and suggestions on improvements. I know I am opening myself up to a lot of criticism but thats the only way to make this app better.
Thanks to all of you that have helped support this application through development and to all of those who have waited patiently for it.
Many thanks to some who have contributed over and over to its development:
Mellon Racing
Boosted Tuning
Also if you would like to donate to the project feel free. I dont require payment as I rely on donations to keep the project alive. If you are a tuner please consider who keeps you in business and who develops software to support you. Donate a little per tune to your free tools community that supports you so well.
Click here to donate
I'm having an issue with VD and windows XP. When I try to open it, it says Virtual Dyno has encountered a problem and needs to close, then asks if I want to send an error report. Any ideas?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 10-14-2013, 07:47 AM   #845
Boost_creep's Avatar
Posts: 829   (View Stats)
Have you tried removing and re-installing it?
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following User Says Thank You to Boost_creep For This Useful Post:
shnouz (11-08-2013)
 Old 10-14-2013, 08:07 AM   #846
atvfreek's Avatar
Yup same thing
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 10-14-2013, 08:23 AM   #847
JgamB's Avatar
Posts: 2,566   (View Stats)
Uninstall again, and then run a regedit and search for the word "dyno". Delete all folders fully associated with Vdyno and the keys only in other folders. You can press F3 to find next, should be about 6 folders/keys to remove.
Try reinstalling after that.
atvfreek (10-14-2013), silvapain (10-14-2013)
 Old 11-06-2013, 08:38 AM   #848
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Downloaded the lastest version, but have no cars to select, list is empty. What Im doing wrong?
jucca is offline   Reply With Quote
 Old 11-06-2013, 09:51 PM   #849
MS6219's Avatar
Posts: 144   (View Stats)
MS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond repute
Worked perfect for me.
06 MS6 GT W/NAVI Freektuned 411AWHP 397AWTQ W/3 gal E85, 93oct: 351AWHP 365AWTQ BNRs3, magnaflow CBE, eBay catless down pipe, CX-racing FMIC, Autotech internals, turbosmart dual port bpv, sure Full3 Aeros, grimmspeed 3 port EBC, ITV22, JBR EGR delete, JBR 80 TMM, JBR 80 PMM, SURE RMM, SURE Dreadnaught, CS short shift plate, 3 bar MAP w/PNP harness, block8head vent pod w/depot boost gauge, AP, ZZB...
06 MS6 GT W/NAVI CS stage II sri, JBR RMM, turbosmart dual port bpv, ultimate racing tp
MS6219 is offline   Reply With Quote
 Old 11-07-2013, 06:51 AM   #850
jucca's Avatar
Don't know what I'm missing here, I tried on my home Mac, same thing happening, have tried now on work PC log from another member from this forum and same thing, I'm trying to expand car list, bu it's empty. Look at ScreenShoot:
Can someone try my datalog, will attach to this post. Thanks
here is SS in VD with datalog from another member:
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
 Old 11-08-2013, 12:27 AM   #851
maddocx240's Avatar
Posts: 823   (View Stats)
same issue I told you I was having. but I have windows 7. I don't know what the problem is. did you get the issue sorted out? actually just tried going to the virtual dyno website and its down.
 Old 11-08-2013, 12:54 AM   #852
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Uninstall, then do a fresh install and see how this works.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
rfinkle2 (11-12-2013)
 Old 11-08-2013, 05:21 AM   #853
atvfreek's Avatar
You are going to laugh, but I literally just got a new computer. Lol That other was was spent anyway, so I finally said fuck it.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 11-08-2013, 08:29 AM   #854
maddocx240's Avatar
So its working with the new computer? Cause like I said the website was down when I tried to download it last night.
I tried that before and it didn't work. So I don't what's up. I'm gonna try from my cousins computer and see what happens.
Last edited by maddocx240; 11-08-2013 at 08:29 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-08-2013, 08:37 AM   #855
atvfreek's Avatar
Yup i was able to download it and it is working fine.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 11-08-2013, 01:29 PM   #856
maddocx240's Avatar
Your new cpu runs Windows 7?
 Old 11-08-2013, 01:36 PM   #857
moomooz12's Avatar
Posts: 378   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
Did you set your profile up for a speed3?
Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR BSD || JBR 88 Trilogy Mounts|| JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs || Swift springs || JBR RSB
|| Snow Performance//Devils Own WMI
Self Tuned @ 330whp/352wtq 10/19/2013
moomooz12 is offline   Reply With Quote
 Old 11-08-2013, 02:08 PM   #858
atvfreek's Avatar
Yessir
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
maddocx240 (11-08-2013)
 Old 11-09-2013, 10:47 PM   #859
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
I'm having the same issue with VD, I just reinstalled windows and VD and it seems like it is not installing the cars list.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline   Reply With Quote
 Old 11-10-2013, 01:02 PM   #860
jucca's Avatar
cannot setup anything, empty list even there
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 11-11-2013, 09:05 AM   #861
jrlms6's Avatar
Posts: 1,436   (View Stats)
jrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the world
I just updated to the version 1.2.5 from one of the first versions (1.2.1), and am having that same problem. No drop down of cars to choose from.
Certainly a bit frustrating but I'm hoping to find a fix relatively soon. I've tried uninstalling and reinstalling, but with no such luck.
2006 Mazdaspeed6 GT - SOLD
Titanium Gray Metallic
SURE Aeros | SURE Sidewinder
Forge V1 | CPE TMIC
Magnaflow CBE | Corksport DP | TXS RP
COBB AP | Autotech Internals
JBR SSP | JBR Shift Weight | JBR Knob
Denso ITV22
2012 MS3 w/Tech - Hit and traded
Velocity Red Mica
COBB SRI | COBB TIP
2006 Mazdaspeed6 GT - Totaled
Liquid Platinum Metallic
CS Stage 2 | COBB AP | CPE HPFP
2006 Mazdaspeed6 GT
Black Mica
CS Stage 2 | CS BPV | CS TBE
COBB AP | CPE HPFP | CPE TMIC
DM RMM
jrlms6 is offline   Reply With Quote
 Old 11-11-2013, 11:59 AM   #862
fywdyl's Avatar
I noticed there's a 1.2.6 beta version, but not sure how to get it.
@bbarnhill;
2010 Black Mica MS3
Mods to date:
Mods to come:
 Old 11-11-2013, 08:13 PM   #863
bbarnhill's Avatar
The different versions arent going to correct the drop down being blank. I think what is causing this issue is the fact that they moved the virtualdyno server the other day and it wasnt able to pull the car definitions. If you open windows explorer and put %appdata% in the address bar it will take you to the application data folder. In there you will see Virtual Dyno's folder. Go in there and delete everything from that folder including the Cars folder. This will cause VD to redownload all the cars.
Brad Barnhill
VIRTUAL DYNO
The Following 4 Users Say Thank You to bbarnhill For This Useful Post:
atvfreek (11-11-2013), Boost_creep (11-12-2013), fywdyl (11-12-2013), ms3blackmica (11-11-2013)
 Old 11-11-2013, 08:42 PM   #864
nojjy's Avatar
Posts: 238   (View Stats)
nojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the world
I've uninstalled and re-installed vd twice, and deleted all files from %appdata% folder and still no cars in the drop down. Now what?
nojjy is offline   Reply With Quote
 Old 11-11-2013, 09:57 PM   #865
jrlms6's Avatar
Second that. Still nothing for me after doing the above as well.
Forge V1 | CPE TMIC
Denso ITV22
Velocity Red Mica
COBB SRI | COBB TIP
2006 Mazdaspeed6 GT
Black Mica
DM RMM
 Old 11-12-2013, 06:05 AM   #866
jucca's Avatar
Don't have Cars folder under that location. I saw when strarting VD app, it says no internet connection or similar, it really goes that part fast so cannot say what is exact message. However, deleted everything on that location, nothing happend.
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
The Following User Says Thank You to jucca For This Useful Post:
jrlms6 (11-12-2013)
 Old 11-12-2013, 02:32 PM   #867
nojjy's Avatar
Everything is working for me now. Must have got the issues resolved.
 Old 11-12-2013, 06:05 PM   #868
maddocx240's Avatar
What about the issue with "virtual dyno has encountered a problem and needs to close', any ideas on that. Its not opening at all for me.
 Old 11-14-2013, 01:18 PM   #869
fywdyl's Avatar
Works fine now too.
2010 Black Mica MS3
Mods to date:
Mods to come:
 Old 11-21-2013, 06:27 PM   #870
jucca's Avatar
Still not working for me, neither on Mac or PC
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 11-16-2016, 06:02 PM   #871
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Man I dont think this KC bbq is gonna compare to Memphis style bbq. Its just not going to be the same but Im going to give it a fair shot.
Man as fast as you are to draw I dont want to step in front of you You keep up the good work.
fuck me I just sent a tech Q to someone who hasn't logged on in 6 months
does this shit work with versatuner ??
I have E101
which is computer for fuck off
What did I eff eup
 Old 11-16-2016, 08:02 PM   #872
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Does VT save to a .csv format?
If so then you can make it work. It needs to see a valid time, RPM, speed data columns (TPS, boost and AFR is nice and can be used too). VT might give any of those parameters a non-standard name in the .csv file, but you could easily rename a column to "RPM" or whatever so it auto recognizes it.
meicalnissyen (11-21-2016)
 Old 11-17-2016, 09:57 AM   #873
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Yes, you can use VT logs in VD.
There is even a VD-specific export option (export as "Virtual Dyno compatible CSV) within the VT software.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 11-21-2016, 10:39 AM   #874
So, did save as in Libre, to a csv, reopened vd, redid the prifile hit file and load run, selected the csv 3rd gear and git E110
Is thsi a delimiter issue mebbe?
Oddly, when i closed the error boz, i flashed, made me pick the car over agai, and voila
Says 222 hp@5306 rpm
 Old 11-21-2016, 11:06 AM   #875
Peckin at tge phone here
240 adding my ass
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/virtual-dyno-85289/
Cobb Dyno - Colorado Mazda Club This thread Refback 11-21-2011 11:22 AM
Mazda Owners Club SA • View topic - Virtual Dyno This thread Refback 09-09-2011 04:44 AM
Virtual Dyno Program kyoo Mazdaspeed3/6 General Discussion 58 08-01-2011 08:57 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.55639 seconds with 37 queries
