 Old 10-28-2016, 08:08 PM   #1
MazdaSpeedster's Avatar
Posts: 128   (View Stats)
MazdaSpeedster is just really niceMazdaSpeedster is just really niceMazdaSpeedster is just really niceMazdaSpeedster is just really nice
Default VVT Failure...
Well Hello Everyone,
I am sad to report that my VVT actuator has failed and I am pretty sure that my engine is fucked. It is an '06 Speed6 with 182,000 on the clock so it has been a pretty good run. I was driving down the road the other night at about 40mph and the car just lost all power. The tach jumped around for second or two and then the car died. I tried to start it back up but it has no compression. It also threw a P0340 code. I had it towed to my mechanic and he took the attached pictures. At this point, I really don't think that I should throw a bunch of money at the car as I am pretty sure that the pistons had an up close and personal meeting with the valves. My question is, has anyone experienced this and been lucky enough to revive the car by just installing a new VVT kit and had no other internal engine damage as a result of the initial VVT failure? If not, I have the following options:
A. Keep the car and part it out
B. Junk it
C. Purchase a VVT kit, install it and hope that there is not more internal engine damage
Based on the pictures and my explanation of what happened, what do you guys think?
MazdaSpeedster is offline   Reply With Quote
 Old 10-28-2016, 08:39 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Can't your mechanic take a look at the piston tops with a scope and see if it looks damaged?
I'm not an expert, but the pictures looks like damage from chain stretch or tensioners. You might just need to overhaul the timing parts, ie. VVT, chain, guides, etc
 Old 10-29-2016, 05:32 PM   #3
cardoc4u's Avatar
Posts: 46   (View Stats)
cardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud of
verify the vvt solenoid is bad before you replace it, that code could be set from the worn timing chain and guides
2012speedy3: cobb sri,tip, accessport, rmm, aem wmi, tbe(with meow),fuel pump innards,fmi
self-tuned @ 309whp/326tq
13.522 @105 mph
cardoc4u is offline   Reply With Quote
 Old 10-29-2016, 06:56 PM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Either it is just a bad vvt and you spend 1000$ on a vvt job. But this is on a motor with not much time left before it needs a rebuild(180k is super high milage for a turbo motor) or spend 4-5 k and put a fresh motor in there and enjoy the car for a long time. No matter what you are in for a chunk of change.
MECP
2012 BM
Rfinkle tune in progress
 Old 10-29-2016, 09:54 PM   #5
ToyBeaux's Avatar
Posts: 5   (View Stats)
ToyBeaux will become famous soon enoughToyBeaux will become famous soon enough
It might be worth your time to do a leak down test on it now, there is a chance it can be saved. It wont have compression if the timing slipped but you can roll the crank 90 degrees past TDC, break the cam bolts loose, and manually close the valves by rotating the cams for the leak down. I've had a few engines come in like that and were fine after a timing job, relatively speaking for a high mileage engine
ToyBeaux is offline   Reply With Quote
The Following User Says Thank You to ToyBeaux For This Useful Post:
Vansquish (11-01-2016)
 Old 11-01-2016, 07:48 AM   #6
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Pretty damn good post
The Following 3 Users Say Thank You to meicalnissyen For This Useful Post:
MS3Shadow (11-01-2016), ToyBeaux (11-01-2016), Vansquish (11-01-2016)
 Old 11-06-2016, 07:46 AM   #7
joshuajcrouch's Avatar
Posts: 61   (View Stats)
joshuajcrouch has a spectacular aura aboutjoshuajcrouch has a spectacular aura aboutjoshuajcrouch has a spectacular aura about
I'm curious, did you have any fair warning before this happened? Did you have any chain noise at start up?
joshuajcrouch is offline   Reply With Quote
 Old 11-09-2016, 04:32 PM   #8
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
you might be ok still, at worst you'll have a few bent valves. do a compression check first obviously.
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
 Old 11-16-2016, 02:36 AM   #9
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
This happen to me. Borescope and try to see if the valves hit the pistons. do a compression test. if they are good, you can always remove the cylinder head and see how much damage to the piston, you can replace the pistons, get the cylinder head rebuilt.
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Project_dog is offline   Reply With Quote
 Old 11-27-2016, 03:26 PM   #10
cjbevington's Avatar
Posts: 27   (View Stats)
cjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to behold
Depending on how curious you are, you could also check valve lash. If you bent a valve, it would become shorter. As a result, your lash would become very large. Obviously, a bore scope would tell you all this too but if you don't have one and you want to know soon that should do the trick!
cjbevington is offline   Reply With Quote
 Old 10-03-2017, 05:08 PM   #11
inixratedini's Avatar
Posts: 3   (View Stats)
inixratedini is an unknown quantity at this point
OK in the same boat here. I have a 07 MS3 @ 50K miles it failed while i was driving @ 30mph. I recently bough this car.
I'm about to pull the trigger on the edge auto sport timing kit. I"m just curious if i should purchase the vvt solenoid also. The oil was a bit a on the dirty side.
inixratedini is offline   Reply With Quote
 Old 10-03-2017, 05:51 PM   #12
Nickhxc4life's Avatar
Nickhxc4life will become famous soon enough
I just did the VVT repair myself. Started getting chatter at idle and at startup. have 200k on the motor. Those marks on the inside are from the chain slapping because the vvt had failed. There is a sensor on the vvt and chances are when it went your ecu caught it before it got to bad and threw your car in limp mode which would explain your sudden loss of power. I'd say check out your valves with a boroscope and if they're ok I would pony up and get the VVT job done. I wouldn't call the motor a total loss just because of those marks. If you get the VVT job done those marks won't affect the functionality of any parts.
Nickhxc4life is offline   Reply With Quote
Second VVT Failure? spikeanoid MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 09-03-2014 11:32 AM
PCV Failure EvoFire MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-04-2014 05:04 PM
3rd VVT Failure JumpingJackson MazdaSpeed 3 - Engine, Transmission & Driveline 41 06-22-2011 11:12 AM
Failure Dave092 Mazdaspeed3/6 General Discussion 18 05-06-2011 09:24 AM
WTF do I have to do to fix my RMM after PMM failure. Adam is so pro MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-18-2009 08:23 PM
Page generated in 0.32782 seconds with 32 queries
