 Old 08-30-2018, 02:42 AM   #1
mirak's Avatar
Posts: 3   (View Stats)
mirak will become famous soon enough
Default Weird problem - engine in a few seconds turns itself off
Hello everybody, i believe you could help me...
I have Mazda 6 MPS 2006 with a weird engine problem:
Cold start is ok, engine is running about several minutes, when it get a little bit warm, then "dies" (turns itself off). I can start it again withnout problems, but after a few seconds engine dies again. Then again, and again... Engine goes into high revs without any problems (when is running)...
Anybody idea, what could do this problem?
- tank is in a half
- cranshaft sensor replaced
- throttle body replaced
- air mass sensor replaced
mirak is offline   Reply With Quote
 Old 08-30-2018, 04:41 AM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Do you have a method of data logging?
Also, you can search this site quite a bit better by using the below in whatever search engine.
site:www.mazdaspeedforum.org/forum "Search term here"
 Old 08-30-2018, 05:33 AM   #3
mirak's Avatar
Yes, I have Delphi (Autocom) diag tool. No DTC errors. Something to focus on measuring data? Now, after almost 20h engine runs about 5 min mins and then died again. Then start, engine runs 15s, suddenly no reaction on gas pedal and engine turn itself off...
 Old 08-30-2018, 09:51 AM   #4
sailnaked6842's Avatar
Posts: 100   (View Stats)
sailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond repute
Gonna have to Accessport and log because with as many things as it could be we'll all waste tons of time and probably your money trying to figure it out. Just for shits I'd check your fuel pump and anything you replaced before it started acting up
Secondly, want to post an intro?
sailnaked6842 is offline   Reply With Quote
 Old 08-30-2018, 11:19 AM   #5
mirak's Avatar
SOLVED
Fuel Pump resistor - located under the air filter box. A lot of corrosion and overheat, cables damaged. I´ve just tried to bypass this resistor - just connected these two wires together.
Everything seems to be OK now, 45km driven and no more problems at all...
Pictures attached
The Following User Says Thank You to mirak For This Useful Post:
JSmith (08-30-2018)
Weird misfire problem Speed3Pedro Mazdaspeed3/6 General Discussion 34 08-27-2016 08:40 AM
Weird problem Woodyspeed3 Gen2 MS3 General Discussion 5 06-05-2015 08:04 PM
Weird Problem danfbh CX-7 > Issues & Troubleshooting 12 06-11-2014 03:09 PM
Another weird problem with shifting into first Mazdaspeed3KHP 2010 MS3 - Engine, Transmission & Driveline 6 05-20-2013 09:15 PM
Weird start up problem Mazdaspeed3KHP 2010 MS3 - Engine, Transmission & Driveline 17 05-20-2013 10:57 AM
Page generated in 0.25632 seconds with 23 queries
