Like Tree4Likes
  • 1 Post By Payne Racing 67
  • 1 Post By Raider
  • 1 Post By 93silvergt
  • 1 Post By silvapain
 Old 10-27-2012, 06:43 AM   #1
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
Default When In Doubt Check It Out!
Guys, I cannot stress this enough...ive heard of a few blown motors lately, all with the same situation. The car was acting up, so the person did a pull and ZZB! When in doubt, check it out. Stop and inspect for any suspects under the hood. If nothing is suspect feel the clutch for vibes. If its ok, drive it home very carefully and get it to the shop asap. If there are vibes in the clutch pedal theres a good chance you have a bent rod, so get it towed! Such a simple step can be so crucial and save you thousands and a lot of headaches. NEVER go WOT if it doesnt feel right! @Raider maybe this should be a sticky?
Sent from my GS3
K.Mah likes this.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following 7 Users Say Thank You to Payne Racing 67 For This Useful Post:
amggilly305 (06-17-2013), grazamataz (03-01-2014), Jh8909 (10-27-2012), jracer (10-27-2012), jucca (12-22-2013), speedy308 (10-27-2012), warlockfan92 (11-08-2012)
 Old 10-27-2012, 07:14 AM   #2
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
that's what people don't understand is, these cars have enough powa to literally tear them selves apart, if something is over looked ...
this is a boosted car!, not a n/a car witch you can get away with murder and they will hardy never come apart ....
a boosted car is not going to put up with any shit for hardy anytime
2 good hard pulls, with a fair amount of kr on a boosted car, and your going to be picking your junk up out the street, and at the very least a bent rod...
at 104000 2 bent rods
tuned by nishan
The Following 3 Users Say Thank You to rigor For This Useful Post:
86AmishMs3 (10-27-2012), jracer (10-27-2012), Payne Racing 67 (10-27-2012)
 Old 10-29-2012, 06:53 AM   #3
ok, so drain the oil, drain the coolant, and do a pull. Got it.
Thread stuck.
ANMVQ likes this.
amggilly305 (06-17-2013), darkcherry (11-10-2012), jmhinkle (01-07-2013), kgb (01-27-2015), Payne Racing 67 (10-29-2012), William.Fraim (11-06-2012)
 Old 10-29-2012, 07:10 AM   #4
Thread stuck.
Exacary!
Sent from my GS3
 Old 10-29-2012, 07:10 AM   #5
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
Thread stuck.
I like to let the freon out, weight reduction. And gets me high/dead.
CaseyBueno likes this.
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
The Following User Says Thank You to 93silvergt For This Useful Post:
 Old 10-29-2012, 07:17 AM   #6
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Worse high for the money.
Ask me how I know.
 Old 11-04-2012, 04:54 PM   #7
twincitySPEED6's Avatar
Posts: 276   (View Stats)
The vibs in the clutch I'm still not certain on that. Are they very noticeable? I feel very light ones in mine seemed normal as my previous car did the same. I've also noticed it a while ago when I first came to research through this forum and that was about 25,000 miles ago
SOLD - 2007 Mazdaspeed3 210k
Current - 2007 Mazdaspeed6
 Old 11-04-2012, 05:20 PM   #8
Its natural to feel some, especially with motor mounts. If theres a bent rod itll really be noticeable and gradually get worse
Sent from my GS3
The Following User Says Thank You to Payne Racing 67 For This Useful Post:
twincitySPEED6 (11-05-2012)
 Old 11-04-2012, 05:27 PM   #9
manila's Avatar
Posts: 1,767   (View Stats)
Just curious if you had a bent rod would it show in your logs? For example, while doing a log would it show up in the KR table?
I've noticed a small amount vibes after my TP install, but those could possibly be from the movement of the TP? I have the SURE TP and it doesn't use hangers.
'12 MS3 Black Mica w/ Tech
 Old 11-04-2012, 05:38 PM   #10
Yeah thats related to the TP...it depends how bad it is. If the rod is pretty bent yes it should show in the logs
Sent from my GS3
The Following 2 Users Say Thank You to Payne Racing 67 For This Useful Post:
manila (11-04-2012), Notorious AMA (01-08-2014)
 Old 12-25-2012, 08:54 PM   #11
cowboyup31078's Avatar
Posts: 29   (View Stats)
cowboyup31078 has a spectacular aura aboutcowboyup31078 has a spectacular aura aboutcowboyup31078 has a spectacular aura about
i just replaced 2 bent rods in my ms6. i didnt know it until i thought i had a bad piston ring. come to find out i had a bad injector seal on #4 piston and 2 bent valves and a soon to be leaking head gasket.
cowboyup31078 is offline   Reply With Quote
 Old 12-25-2012, 09:14 PM   #12
And you werent getting any KR/clutch vibes???
Sent from my GS3
 Old 12-26-2012, 11:19 PM   #13
no i didnt get anything. and then i had a bad rough idol. that was all
 Old 01-06-2013, 10:34 PM   #14
Evan002's Avatar
Posts: 69   (View Stats)
Evan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud of
Groaned at 12 Times in 2 Posts
Ok I've been trying to figure it out, what is a TP?
Evan002 is offline   Reply With Quote
 Old 01-06-2013, 10:46 PM   #15
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
TP = Test Pipe. It's the section of the exhaust containing the second catalytic converter.
Tapadatass
Evan002 likes this.
Evan002 (01-07-2013)
 Old 01-07-2013, 12:32 AM   #16
Evan002's Avatar
Tapadatass
Thank you for clearing that up for me
 Old 01-25-2013, 08:39 PM   #17
well finally got all of it running great and then my timming chain tensioner took a dodo.
 Old 06-17-2013, 01:42 AM   #18
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Not engine stuff but I heard a wub-wub driving back from the gym the other day, so I turned down my dubstep and it was still going wub-wub. Pulled over immediately and my front left wheel had half the lugnuts so loose I could unscrew them with my fingers. I check them bi-weekly. I'd driven ~500 miles last weekend but that's scary as hell how loose they were. I keep a 150 ft-lb torque wrench in my car for this kind of stuff so I hit them all with an 85 and the sound went away. Crisis averted but it coulda been a really shitty day if I didn't pull over right away.
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
The Following User Says Thank You to SeeMeGovan For This Useful Post:
2ndGenM$3 (04-09-2018)
 Old 07-26-2013, 10:20 PM   #19
JBerry's Avatar
Posts: 21   (View Stats)
JBerry is a splendid one to beholdJBerry is a splendid one to beholdJBerry is a splendid one to beholdJBerry is a splendid one to beholdJBerry is a splendid one to beholdJBerry is a splendid one to beholdJBerry is a splendid one to behold
Thought I did check everything out the day I lost my engine. The crown of my third piston cracked off and was floating around in the cylinder. I also found I had a cracked turbo. Shit balls for shitty days.
I reject your reality and submit my own!
JBerry is offline   Reply With Quote
 Old 02-16-2014, 06:18 AM   #20
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
Will the vibration be extremely noticeable? Sometimes just driving on crappy roads make it hard to tell what is really vibrating.
bunta is offline   Reply With Quote
Report: Nissan GT-R future in doubt? Haltech Automotive News 0 07-27-2012 12:50 PM
Hayes expects auditors to express doubt on solvency Haltech Automotive News 0 04-21-2009 10:10 AM
REPORT: Lewis Hamilton's future with McLaren said to be in doubt Haltech Automotive News 0 04-07-2009 11:50 AM
Is Pininfarina's future in doubt after CEO's death? Haltech Automotive News 0 08-08-2008 05:50 PM
Page generated in 0.41625 seconds with 32 queries
