 Old 05-08-2010, 05:36 PM   #561
ptperformance's Avatar
Posts: 4,123   (View Stats)
^ See post 553 John.
Part throttle blow-up is a misconception that you keep on perpetuating. Plenty of cars blow WOT. The bending/damage is done at high cylinder pressures. Once it's bent, the rod lets go at any time.
OK, say its not part throttle. Why is it then that guys can abuse their motors for endless miles under WOT, un-tuned, lots of knock and never blow? Several have had knock, several have pushed very hard on this motor with very big turbos and never blow? Why?
 Old 05-09-2010, 12:47 AM   #562
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
The title of this thread basically implies everyone's engine is destined to blow. It sounds like a scare tactic. I suppose it’s a good way to get attention but damn it’s a bit misleading to say the least.
ms3077 is offline   Reply With Quote
 Old 05-09-2010, 01:53 AM   #563
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I feel the need to repost one of my posts here...
315ftlb @ 2000rpm is not at all the same stress on the rods as 315ftlb @ 5000rpm. Its all about where on the stroke the peek cyl pressure is achieved. At low rpm our peak cyl pressure comes in very close to tdc so there is very little leverage on the crank and the cyl pressure required to hit 315ftlb is very high. As the rpm goes up, peak cyl pressure is reached further past tdc when the piston has more leverage due to the increased rod angle and as a result less cyl pressure is required to hit 315ftlb. However, on paper, if peak cyl pressure is achieved at the same point on the stroke, then the cyl pressure required to hit 315ftlb is the same regardless of rpm since torque is basically just a calculation of cylinder pressure and rod angle.
That is the reason I believe we are blowing at low rpm and not at high rpm. After further research, I am also starting to believe that we need to lock the ign timing down to a certain curve so that it isnt bouncing around all over the place. Predictability is key to building a high hp engine.
2006 Mazdaspeed 6
djuosnteisn (05-10-2010)
 Old 05-09-2010, 10:21 PM   #564
Why does your motor blow?
That sounds like a scare tactic to you? Sorry, but that was not the intent of this thread. How about that other thread, "The real reason your motor blows", what does that sound like to you?
There was no intention to "get attention" I have enough negitive to last a lifetime on this forums by other members that have never even owned or installed one of our parts, LOL.
I have seen several blown motors from the MS3/6 but the number of SRT4 motors that have blown compaired to the DISI motor is flat scary.
 Old 05-09-2010, 10:32 PM   #565
I think we need to take the time and check rod ratio's of these motors. This would give us a better starting point to determine if the SRT4 motor has more cyl pressure "leverage" on the crank than the DISI motor.
I agree with you on the timing and low RPM TQ numbers but I still feel that there is a single event that causes the motor to blow. If it were only low RPM WOT applications that caused the motor to blow... you would be able to duplicate the condition on all cars. I use to try and get my motor to blow (2nd motor) and no matter what I did, even 5th gear pulls at 25 MPH would not cause a motor failure or knock. I think that there might be something worth looking into with the timing, but yet again it should be repeatable on "all" cars, not just the handful that we see blowing up.
The oil in the intake after a motor bends rods has be concerened. Either the oil was there before the rods bent, or it was there after. I can figure out how the oil got there before, but after doesn't make any logic. The only way to get oil into the intake after a rod bending event would be to have the PCV system fail at that exact moment of the failure. Ring seal will not put oil deposits into the intake manifold, that is imposssible.
 Old 05-10-2010, 07:44 AM   #566
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
Originally Posted by ptperformance View Post
...... Ring seal will not put oil deposits into the intake manifold, that is imposssible.
Well, not directly of course, however, when the rings loose seal under boost, the crankcase pressure skyrockets and will likely fill and pressurize the PCV oil separator and cam cover breather until the driver lets off the throttle and the PCV opens under the part-throttle vacuum. Then the pressurized oil in the PCV tank is blasted into the intake manifold....
FORZDA 1 is offline   Reply With Quote
 Old 05-10-2010, 08:28 AM   #567
mrFanel's Avatar
Posts: 487   (View Stats)
mrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the world
So has anyone had a chance to compare a 1st gen to a 2nd gen? I am quite curious at this point... not too much of a big deal for me since the car is under wty, has 4K miles on it and the dealer I bought it from is pretty chill but still... this is a bit disconcerting and I would hope someone at Mazda would man up....
Question though... is the fundamental block design of the 2.3 DISI block the same as the regular 2.3 NA motor (without, I suppose, the strengthened components, but you get the idea)? Wouldn't... those blow as well? (Sorry if its a rhetoric question that has been answered as well )
mrFanel is offline   Reply With Quote
 Old 05-10-2010, 08:30 AM   #568
Speeeeeed
06Speed6's Avatar
If a intake valve is damaged and there is no piston in the bore...
No its almost completely different.
2006 Mazdaspeed 6
Last edited by 06Speed6; 05-10-2010 at 08:30 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-10-2010, 08:37 AM   #569
^ PCV box on the side of the block is very similar however.
 Old 05-10-2010, 09:16 AM   #570
[MSF STIG]
FORZDA 1's Avatar
Yup, that too
 Old 05-19-2010, 08:10 PM   #571
That is the best condition that I could see happening. But what about those that don't loose ring seal? I just got pictures of a car that didn't loose ring seal and guess what... ton's of oil inside the intake manifold. This is what confuses me when it comes to the oil in the intake on the DIZI motor.
They are different but very slight and you have to be sharp to catch the changes. I am not going to share what they are, until I have had the oppritunity to tear down a few more 2010's. One thing I can say without question... it appears that the bore diameter has changed. Confirmed this on two 2010 motors so far.
Other than the obvious reasons, LOL.
This goes back to my reasons for blown motors, PCV system is of a very poor design and under boost the box fills up and causes a sealed system. Then when you slam the throttle shut, open it up again under boost it creates the snap vacuum. If the box is 1/2 of the way full of oil when this happens it only complicates the problem of an already poorly designed system. But that is my therory and until I can prove it... its just therory.
The Following 2 Users Say Thank You to ptperformance For This Useful Post:
FORZDA 1 (05-19-2010), SpeedSixxx (05-20-2010)
 Old 05-30-2010, 03:38 PM   #572
Joern's Avatar
Posts: 19   (View Stats)
Joern has a spectacular aura aboutJoern has a spectacular aura about
hi PTP
how much longer will it be untill u are ready to sell your kit?
Joern is offline   Reply With Quote
 Old 06-01-2010, 10:01 AM   #573
Originally Posted by Joern View Post
hi PTP
Months, we need to make sure that its working 100% on several cars before we release it to the market. I don't need to take any heat from the haters because "one car" didn't respond well to the fix.
 Old 06-03-2010, 05:38 PM   #574
Joern's Avatar
can i join the testing? u will get the chance to test it on an european car..
The Following User Says Thank You to Joern For This Useful Post:
MPSdriver (06-09-2010)
 Old 06-06-2010, 05:39 PM   #575
Contact me via email or PM and we can discuss some options.
 Old 07-05-2010, 10:39 AM   #576
blacksin's Avatar
Posts: 18   (View Stats)
blacksin is an unknown quantity at this point
I've got a 2007 MS6 with 35,000 miles. My only mods are the AP with Stage 1 + SF 91, and the COBB SRI. My MAF has been calibrated (oddly enough, my AP shows +5 LTFT at idle with AC on, but it's being recorded as 8.42 in the spreadsheet. When my AC is off, the LTFT @ idle goes back down to +1 - +2).
I had my cruise control set @ 70 m.p.h. for about 25 miles in this record MD humidity. Pulling off the highway to a low throttle, vacuum state, I noticed the knock on my AP wiggin' out. I recorded the following:
Now I've lurked all around the forums, and I've seen so many theories. I've read all 15 pages of this oil theory. Some people tell me that this is "normal" because it's the car adjusting timing. Others say that the golden ticket is just adjusting the load for low throttle in ATR. Others say that this is phantom knock since the knock is going down to zero, and I should just "ride it out." This knock only happens when the car is warmed up and from a very slow start in vacuum. Like most other people, I don't have any knock during high throttle situations. To me, this isn't normal, and I want to find a way to make it stop. I've seen everything from "it's completely normal" to "you're car is going to die! AHHH!"
I guess I don't have much to add to this thread, other than just saying I hope this isn't the oil issue... but then again, some people say that the MS6 doesn't have the oil pop issue as much as the MS3... It just doesn't make sense to see that much knock when the acelerator position is only on 10-20%.... so confused....
blacksin is offline   Reply With Quote
 Old 07-05-2010, 04:52 PM   #577
Does your clutch pedal vibrate when you push it in? Something is wrong with your car or sensor considering you have knock all the time, which is bad!
 Old 07-05-2010, 08:04 PM   #578
blacksin's Avatar
Nope, my clutch pedal doesn't vibrate, and i'm not knocking all the time as the spreadsheet attached to my previous post shows, just @ that rpm in the pic, under vacuum, after cruising on the highway. I think I had a tank of bad gas 'cause i'm getting much less knock now. But I still have a few degrees right at that point of the rpm band with very light throttle. But again, no knock whatsover under medium to wot above 3000 RPMs... Plus, it's silent, no rattling or pinging whatsoever. I feel like if it was knocking that much, you would hear/feel/see something.
 Old 07-06-2010, 08:55 AM   #579
ReD BoY's Avatar
Posts: 523   (View Stats)
ReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the world
Groaned at 32 Times in 15 Posts
first of all, I didnt read through the middle 9 pages of comments to this thread... I read the first thinking there was only one and when I realised there were 12 pages I just skipped to the last one.
So my question may have already been mentioned, but this is what's on my mind... I know that people have talked of relieving the car of backpressure by eliminating cats enables the oil to leak past the turbo and cause the exhaust to smoke.
some argue that if you have a leak after you had a leak before and the cats were just hiding it.
you mentioned oil everywhere, could relieving backpressure increase this risk..? significantly?
by the sounds of it you're developing a fix, the supposed fix to having the catless pipes was a pill, an oil catch can, or switching to 40 wieght oil. Im not too technical and I dont really know why switching oild would help leaking but do any of these seem to be headed on the right track? Or is what you're doing now supposed to be the "all powerful" fix?
I think Im getting a full CorkSport turboback exhaust next week and I just want to know what Im risking.
thanks
---Stupid kid can haz car.
ReD BoY is offline   Reply With Quote
 Old 07-06-2010, 07:47 PM   #580
wcm250f's Avatar
Posts: 174   (View Stats)
wcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud of
hey ptp. just curious was there a specific reason why you got to tear down a couple 2010 ms3? or did something happen to the motor?
wcm250f is offline   Reply With Quote
 Old 07-07-2010, 02:26 AM   #581
thanks
I am going to say yes that the reduction in back pressure causes the oil pressure to overcome the seal in the turbine side of the turbo, or we just have a horrible oil return system that backs up with oil because of the PCV system.
The pill that we made has solved 99% of all oil burning issues.
I ordered new parts from the dealer to see the differences when we started a forged motor build for a customer. The very first thing that I caught was the drivers side nipple off the valve cover was smaller inside and a few other changes that made me go hmmm.
When I pulled the motor down I wanted to be sure that I was seeing the proper things so I decided to order a few items up to verify. Pistons are different and rods weigh more then the older version.
 Old 07-07-2010, 04:41 AM   #582
wcm250f's Avatar
alright thanks. just wanted to see if you had any bad info about the 2010 ms3
 Old 07-09-2010, 03:15 PM   #583
Nothing yet.
 Old 07-09-2010, 06:47 PM   #584
turbospeed's Avatar
Posts: 113   (View Stats)
turbospeed has a spectacular aura aboutturbospeed has a spectacular aura aboutturbospeed has a spectacular aura about
the pcv hole is smaller thats all ive heard about the 2010
turbospeed is offline   Reply With Quote
 Old 07-12-2010, 07:08 AM   #585
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Why in the hell would mazda make a smaller diameter on the PCV for 2010 ?? If that's the case, what does Mazda know ?
 Old 07-12-2010, 01:35 PM   #586
PAM.srt4's Avatar
Posts: 249   (View Stats)
PAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond reputePAM.srt4 has a reputation beyond repute
you don't need a fix for the 2010, the oil burning problem was fixed by Mazda with the new year!!!!!!
PAM.srt4 is offline   Reply With Quote
 Old 07-12-2010, 05:52 PM   #587
pzr2874's Avatar
Groans: 146
Ok, so WTF were the fixes? Other than the oil burning issues?
If you're saying "a fix" was done.... And the oil issue was done... then we can ALL just order the new PCV system ?
 Old 07-12-2010, 06:36 PM   #588
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
hopefully poeple can see that the 2010 speeds arent blowing cause they dont have many playing at home dyno tuner with the software yet thanks to a lack of support for the moment which is probably a good thing.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
 Old 07-13-2010, 08:57 AM   #589
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
with this problem being able to be proven i vote someone making an example of mazda and taking them to court for a recall like they did a few months back to hyundai for the tiburon clutches
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 07-14-2010, 02:43 PM   #590
pzr2874's Avatar
Groans: 146
Originally Posted by triplejumper18 View Post
Fixed
Funny shit...
BUT.... what I get out of what you are saying is that tuners are responsible for this(these) engines having problems. I disagree....
1-these engines had issues prior to many of the tuners
2-COBB and likes DO their R&D, they have WAY too much to lose from half-assing their products.
3-We wait and see what the GenPu have to show and go from there.
4-You would think FORD and Mazda would man-up and show some love for MS buyers.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/why-does-your-motor-blow-26996/
How much can 2.3 T stand - Page 5 This thread Refback 07-05-2012 12:23 PM
Another Monster Build? - Colorado Mazda Club This thread Refback 03-04-2010 08:12 AM
How much can 2.3 T stand - Page 3 This thread Pingback 12-25-2009 06:13 PM
OzMPSclub - Australia's fastest growing Mazda MPS forum - Blown engine theory This thread Refback 08-26-2009 02:00 AM
Mazda 3 MPS Blown motor theory (1st Gen) - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 08-14-2009 12:30 AM
2.3disi Turbo Engine Blow - Club Mazda This thread Refback 07-17-2009 03:47 PM
smoking but turbo seal good? PCV issues? - Mazda6 / Atenza This thread Refback 06-10-2009 01:39 PM
Why does our motor blow?... - Mazda6 / Atenza This thread Refback 05-22-2009 08:24 AM
MS3/ATR: partial throttle knock - TorontoMazda3 This thread Refback 05-13-2009 08:44 AM
Thinking of trading the GTI in for an MS3........ - Page 3 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 05-12-2009 07:38 AM
Tuoreimmat viestit This thread Refback 05-10-2009 12:16 PM
Mazda 3 MPS This thread Refback 05-10-2009 11:43 AM
Tuning a MPS - Page 2 - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 05-08-2009 04:19 PM
Thinking of trading the GTI in for an MS3........ - Page 3 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 05-07-2009 02:42 PM
Problems with the 2.0T - GenCoupe.com Forums Post #4 Pingback 05-04-2009 01:23 PM
It's time to know - Mazda6 / Atenza This thread Refback 05-02-2009 09:14 AM
The Official: Mazdaspeed 3 Thread - Page 88 - NASIOC This thread Refback 05-02-2009 08:31 AM
Blown motor theory - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Refback 05-01-2009 11:41 PM
Blown engine theory - OzMPSclub - Australia's fastest growing Mazda MPS community Post #4 Pingback 05-01-2009 11:30 PM
Why does your motor blow thread, look inside. ptperformance Mazdaspeed3/6 General Discussion 207 08-16-2009 12:01 PM
Why did Mark's motor blow? MarkyMark Mazdaspeed3/6 General Discussion 61 05-20-2009 01:33 PM
Will i blow? Grim MazdaSpeed 3 - Engine, Transmission & Driveline 26 02-20-2009 10:22 AM
Is my engine going to blow? toprock MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 01-19-2009 10:38 PM
Page generated in 0.66056 seconds with 35 queries
