![]() Join Date: Jul 2018
(Thread Starter) | Not Ranked : 0 score Hi guys, interested in doing a trackday with my MS6, 82K on the clock. It has a high pressure fuel pump, I think a japspeed intake and some aftermarket exhaust system I don't know what it is. I've heard the rear diff mounts should be done - is this a case that they wear out and need replacing or they will cause catastrophic damage when they fail? Either way, apart from tires and pads, is there any real damage that gets done by tracking this car? (ignoring shitty driver skills lol) thanks Last edited by JackDG; 09-27-2018 at 03:33 AM. Reason: typo |
| Not Ranked : 0 score No, but you may end up like me.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Thor Hammer (09-28-2018) |
(Thread Starter) | Not Ranked : 0 score I'll start credit card applications now then ![]() |
| Not Ranked : 0 score If you're just wanting to have fun, I would suggest detuning it a little. Run spring pressure boost. I've had issues with adequate intercooling with both stock and aftermarket TMICs. Extended runs at WOT and long straights will have your BATs soaring. Add a gallon or two of E85 to the tank too and I'd say you're ready for a fun weekend. I wouldn't concern yourself with diff mounts at a trackday since you shouldn't be launching...ever.
Groans: 211
Brakes and brake fluid are most critical. High temp fluid and stainless lines will keep it from boiling. Your brakes will get hot and boil stock fluid. Then no brakes! Run a pad like Hawk, EBC reds, etc. As far as mounts, I would say the most benefit is had from an aftermarket rear motor mount (RMM). The rear diff mount you car read about on here all day long. The stock bushings are weak and give way. Some have had them snap. Some bolts on the front diff mount have sheared. I never had a problem before upgrading my rear diff mount. Is it necessary for a trackday? No. Get good tires and drive within your, and your cars limits!
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() Join Date: Dec 2016 Location: Mississauga, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score slap some hawk HPS or HP+(if you dont mind infinite brake dust and noise) on the car, some decent fluid, decent tires, and send it. if youre a once in a while kinda track guy thatll do just fine. if youre going to be going often, then theres much more to consider. Ive done a track day in a car with OEM pads and fluid, let me tell you, NOT fun. ALSO, oil. bring extra. check it in between sessions and before driving home. maybe even change it before if youre close to an oil change anyways.
__________________ 2011 ms3 Cobb AP, Forge bypass valve, HPFP internals, Cobb downpipe, Custom fmic w/mishimoto core, Cobb RMM, Cobb EBC, KW coilovers, whiteline RSB, stop tech fluid, stop tech SS brake lines, hawk HP+ pads, ACT 6 puck clutch, ATP 3071r, HTP 3.5" intake, Damond catch can, TunedbyNishan |
| Watch this autonomous rally car destroy a dirt track | Haltech | Automotive News | 0 | 05-27-2016 07:50 AM |
| First time taking the speed to the track | omgvance | Drag Racing | 11 | 04-17-2014 10:44 AM |
| Taking the speed3 to the track! | etonna | Drag Racing | 1 | 07-24-2012 10:29 AM |
| Video: Aussie racer objects to track conditions by... taking over? | Haltech | Automotive News | 0 | 08-25-2011 11:00 AM |
