![]() Join Date: Jul 2017
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 16
Groans: 211
| Not Ranked : 0 score I would totally get it coated if its not too expensive. But test fit the manifold before you do!
(Thread Starter) | Not Ranked : 0 score I test fit it already. It'll work but the heater core hoses are maybe 1/2 inch from touching it. That's a no bueno for me. Gonna get it ceramic coated and possible make a custom heatshield for the hose area. Gonna chop off that stupid inspection pipe I keep hitting |
| The Following User Says Thank You to TDubTheSubBub For This Useful Post: | Thor Hammer (05-02-2019) |
| Not Ranked : 0 score The heat shield would probably be the most efficient way... I bet Thor was talking about test fit in general but i would mention linearity check also. Some of these manifold had bent or not plane surface if you read the reviews. (V3 should be fine but...) If it need to be planned, they would stcratch the coating in the process....
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| Ceramic Coating Intake Manifold | mrmonk7663 | 2010 MS3 - Engine, Transmission & Driveline | 12 | 01-28-2012 01:40 PM |
| Ceramic coating anyone? | jlefebvre123 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 07-16-2009 02:21 PM |
