 Old 04-26-2019, 08:26 PM   #1
TDubTheSubBub's Avatar
Posts: 82   (View Stats)
TDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of light
Default XSPower Manifold, Coating?
Just wondering what people think about ceramic coating my new XSPower v3 ewg manifold? Guessing voids warranty, but engine bays temp are insane and I assume the exhaust manifold with no shields aint gonna help
TDubTheSubBub is offline   Reply With Quote
 Old 05-01-2019, 12:32 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
I would totally get it coated if its not too expensive. But test fit the manifold before you do!
 Old 05-01-2019, 08:49 PM   #3
I test fit it already. It'll work but the heater core hoses are maybe 1/2 inch from touching it. That's a no bueno for me. Gonna get it ceramic coated and possible make a custom heatshield for the hose area. Gonna chop off that stupid inspection pipe I keep hitting
The Following User Says Thank You to TDubTheSubBub For This Useful Post:
Thor Hammer (05-02-2019)
 Old 05-02-2019, 08:52 AM   #4
Posts: 2,235   (View Stats)
The heat shield would probably be the most efficient way...
I bet Thor was talking about test fit in general but i would mention linearity check also. Some of these manifold had bent or not plane surface if you read the reviews. (V3 should be fine but...) If it need to be planned, they would stcratch the coating in the process....
 Old 05-02-2019, 11:52 AM   #5
Groans: 211
Indeed I was.
Ceramic Coating Intake Manifold mrmonk7663 2010 MS3 - Engine, Transmission & Driveline 12 01-28-2012 01:40 PM
Ceramic coating anyone? jlefebvre123 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 02:21 PM
Page generated in 0.25733 seconds with 22 queries
