> Cobb Tuning
 Old 02-27-2012, 08:31 PM   #1
Default 2009 MS3s still have WGDC drop over 80% Injector Duty
This issue was resolved in the other year speeds (MS3 and MS6) by toggling the boost based tuning checkbox to ON.
In the 2009 MS3s toggling the boost based tuning does not resolve this issue and WGDC still drops when injector duty exceeds 80%.
@David@COBB, there was probably some omission in the 2009 MS3 ATR release. Can you please double check?
Thank you!
File Type: jpg 2009 MS3 WGDC drops with IDC over 80%.jpg (74.8 KB, 123 views)
 Old 02-27-2012, 09:38 PM   #2
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Thank you!
What type of calculated loads is it experiencing near the 80% IDC? Is this 93 or E85?
-David@COBB
 Old 02-27-2012, 09:40 PM   #3
-David@COBB
He is around 2 - 2.1 load when he first hits 80% IDC. This is on E85, but a mild mix 3/9. I've done several similar tunes and the Boost Tune toggle addressed the issue in other model years.
 Old 02-27-2012, 09:47 PM   #4
Turn off all the WGDC compensations to force it to run your commanded WGDC (I would lower the WGDC a bit across the board when doing this). See if it pulls it then. We might be running into a safety case of sorts like I had in a previous thread - "Tales of the ECU".
-David@COBB
 Old 02-27-2012, 09:51 PM   #5
-David@COBB
I really dislike running just from the table - that's basically a fancy manual boost controller.
This was resolved like I said before - very similar scenario - in the other speed years by toggling the boost tune toggle and changing NOTHING else. Is it possible something was omitted for the less common 09 speeds?
 Old 02-27-2012, 10:18 PM   #6
I can check tomorrow, but I don't believe it is any different from the previous years logically. What may be problematic is that they may have changed a limit or calibration of something that year only.
-David@COBB
The Following User Says Thank You to Cobb Tuning For This Useful Post:
Lex (02-28-2012)
 Old 02-28-2012, 09:07 AM   #7
Thanks David, please do check.
 Old 03-05-2012, 08:33 PM   #8
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
any updates on this david?
i'm currently sitting at ~75% IDC and am going to be upping the ratio of e85/93 from 3/9 to 5/7 so i'll probably have this problem arise seeing as i've got an 09.
thanks
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
WGDC Inconsistencies with Boost Tuning - Random flatline and no wgdc compensation phate 2010 MS3 - ECU Computer Tuning 38 02-10-2013 01:49 PM
No change in boost from 0% WGDC to 100% WGDC phate MazdaSpeed 3 - Engine, Transmission & Driveline 30 12-12-2011 03:27 AM
Injector % Duty Cycle holeinmypocket MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 04-14-2010 07:09 PM
SEMA 2009: Lingenfelter T/A Concept a throwback to the 455 Super Duty Haltech Automotive News 0 11-03-2009 01:00 PM
Rumormill: Ford may drop manual from Super Duty lineup Haltech Automotive News 0 04-12-2008 11:20 AM
Page generated in 0.29312 seconds with 23 queries
