> Cobb Tuning
 Old 01-15-2012, 02:46 PM   #1
deek's Avatar
Posts: 687   (View Stats)
deek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the world
Default any chance for a stage 1 fmic+intake map
Like the title states, wondering if it's possible to run a stage one map with Cobb fmic and injen cai. Looking for more functionality without upgrading fuel pump and other mods.
Haven't bought front mount yet due to not having ots tune for it. Also will I have any clearance issue with fmic piping and injen cai
2010 Dodge Ram 1500
6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5
deek is offline   Reply With Quote
 Old 01-15-2012, 02:58 PM   #2
dspider's Avatar
Posts: 119   (View Stats)
dspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud of
check out the calibrations on the cobb site . there should be something there for u .
[SIGPIC][/SIGPIC][/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out.
dspider is offline   Reply With Quote
 Old 01-15-2012, 03:47 PM   #3
deek's Avatar
already looked there, only one for ic is stage two with tip. Want stage one no tip
2010 Dodge Ram 1500
 Old 01-17-2012, 09:26 PM   #4
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
solution: get TIP
it's fun to do bad things
 Old 01-17-2012, 09:48 PM   #5
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Neutral  :  +2 score
So your willing to pay $1000+ for a front mount, go thru a pain in the ass install and not gain very much from it because you cant push your car to the limit due to lack of fuel... But you dont want to spend $350 ,2 hours for fuel pump internals and another $110 and 30min. on a test pipe and gain a whole lot more ponies? I dont get it?
But to answer your question im sure you can get an etuner to make you a custom map.
TEAM LUXURY
 Old 01-18-2012, 12:08 AM   #6
deek's Avatar
can't due test pipe will void warranty.
Did think about what you said, can do tip and fuel pump internals though. And it makes sense 515 for say 40hp vs 500 for maybe 10 hp. Plus think fmic voids warranty
2010 Dodge Ram 1500
The Following User Says NO Thank You to deek For This Un-useful Post:
SWAY (01-18-2012)
 Old 01-18-2012, 02:50 AM   #7
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Nothing Voids your warranty.. Just will void a warranty claim and possibly red flag your VIN. I would suggest stocking out for any dealer visits regarding warranty work. A CAI and tip will very well void a warranty claim also.. You would most likely be able to get away with the HPFP internals.
Spoofmastafly is offline   Reply With Quote
 Old 01-18-2012, 05:31 AM   #8
Groans: 549
dude, slow down. TIP =/= test pipe. TIP = turbo inlet pipe. on the AP it is TIH which is turbo inlet hose. that is just the rest of the intake. test pipe = exhaust.
 Old 01-18-2012, 08:28 AM   #9
deek's Avatar
I know that maybe you should read all of the responses. Maybe you quoted wrong guy. Other guy said test pipe, I've never mentioned wanting nor am I getting a test pipe. I do however want to purchases a tip as in turbo inlet hose/pipe to finish my intake
No tip/tih will not void warranty since I purchased vehicle with cai already on it.
2010 Dodge Ram 1500
 Old 01-18-2012, 08:56 AM   #10
No tip/tih will not void warranty since I purchased vehicle with cai already on it. Can't prove interanals were there or not if needed warranty work, only way would be to pull apart specific. So should be good going stage 2 and if needed pull ap and bring in.
Got that in writing right?
 Old 01-18-2012, 09:02 AM   #11
deek's Avatar
not in writing but i did call the warranty company and they said tip is fine. guy also said exhaust is fine as long as you don't alter any o2 sensors. Which on a side note i believe a test pipe would not, correct me if im wrong.
this is my specific extended warranty co, i cant speak for all
only way an intake would void anything (ie turbo) would be if a piece flew off of it and into turbo causing turbo to fault.
2010 Dodge Ram 1500
SWAY (01-18-2012)
 Old 01-18-2012, 10:57 AM   #12
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
This thread is fucking fail, I'm fully bolted and still have my warranty. Nut the Fuck up!!!
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
The Following User Says Thank You to SWAY For This Useful Post:
Sid3wayS (01-18-2012)
 Old 01-18-2012, 11:04 AM   #13
deek's Avatar
thread went off topic, but thanks found my balls, they were hiding in your mom's mouth ;-) but I got em back . gonna order test pipe, fuel pump, tip and cbe, run stage 2 and call it a day.
2010 Dodge Ram 1500
The Following User Says Thank You to deek For This Useful Post:
SWAY (01-18-2012)
 Old 01-18-2012, 11:08 AM   #14
Sid3wayS's Avatar
Groans: 97
Saved the fumble and ran for a touchdown. G/L with installs.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
deek (01-18-2012), mazdaspeeding (01-18-2012)
 Old 01-18-2012, 11:12 AM   #15
jman46's Avatar
Posts: 3,169   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groaned at 26 Times in 20 Posts
You can save your money on a CBE and put it towards other better mods. You won't gain much, if any from it.
'06 F350 Lariat PSD - 458whp/818wtq
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485whp/435wtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is offline   Reply With Quote
 Old 01-18-2012, 11:18 AM   #16
deek's Avatar
thats last on my list honestly, talked to cobb, according to them your "spose" to run a cbe for stage 2, not super important. gain 5-10 hp nothing serious. but i do love the sound of hks cbe, makes the girls wet
2010 Dodge Ram 1500
 Old 01-18-2012, 11:33 AM   #17
jman46's Avatar
You can run stock exhaust with the both resonator's deleted and it sounds disgusting, that's what I have.
'95 SHO MTX - sold
 Old 01-18-2012, 11:43 AM   #18
deek's Avatar
that's what im running now
2010 Dodge Ram 1500
 Old 01-18-2012, 01:35 PM   #19
jman46's Avatar
But you haz stock dp.
'95 SHO MTX - sold
 Old 01-18-2012, 01:41 PM   #20
Groans: 549
do everything you said except forgo CBE in favor of upgraded intercooler action and call it a day.
and add custom tune.
Stage II with DP, HPFP, FMIC, RP mrmonk7663 2010 MS3 - ECU Computer Tuning 11 09-22-2011 05:50 PM
They took out stage 1 fmic? jayd MazdaSpeed 3/6 - ECU Computer Tuning 2 09-06-2011 09:19 AM
In the Meantime, Should I Run Stage 2 + FMIC? ms3brendan MazdaSpeed 3/6 - ECU Computer Tuning 10 06-28-2010 02:16 PM
Stage 2, fujita intake AP map? buttons
Cobb Access Port/Maps
3 01-05-2009 12:49 PM
Stage 2 + SF v102 FMIC Datalogs aaronc7
59 08-22-2008 02:28 PM
Page generated in 0.39518 seconds with 26 queries
