> Cobb Tuning
 Old 08-26-2013, 12:42 AM   #1
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Default Change V3 bar gauge resolution
Just wondering if it's possible to change the resolution shown on the bar gauges in the V3?
For boost I have -98.91 to +98.91 psi
As much as I wish I could run 100psi and go super fast, I don't see that as being likely...
Picture:
 Old 08-26-2013, 12:44 AM   #2
Should add, it's like this for boost, whether I have 1/2/3/4 or 5 gauges showing...
Sent from my Galaxy Nexus using Tapatalk 4
 Old 08-26-2013, 04:27 PM   #3
Donut's Avatar
Posts: 131   (View Stats)
Donut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the world
Probably should change the unit displayed on the scale to something more realistic, I would really like to have -/+ 629kPa of boost!
2004 Mazda RX8 - Bone Stock - SOLD
2010 Mazda 3 MPS
K&N SRI | GFB BPV | Cobb TIH | Cobb AP v3 - Freektuned |CS Internals|OBX Cat Back + Test Pipe | JBR 70a RMM | JBR RSB|JBR EGR block off plate|JBR SSP + Solid Bushings |Denso ITV 22| Ultra Racing Front Strut Bar| Ultra Racing Rear Strut Bar | Bridgestone RE002 225/40/R18 Tyres|CS Brake Pads|H&R Lowering Springs| DBA T3 Slotted Rotors |Goodridge SS Braided Brake Lines
Non performance parts: 35% Tint | Blacked Emblems | Painted Wheels |JBR Heavy Shift Knob | CS Tow Plate |
Donut is offline   Reply With Quote
 Old 08-29-2013, 03:49 AM   #4
How do I do that?
I can't find any option to change it anywhere... Even changing to metric/etc didn't help
@David@COBB; @Evan@COBB; any ideas?
 Old 08-29-2013, 05:26 AM   #5
Mistersix's Avatar
Posts: 2,585   (View Stats)
I Liked the graph at first until i realized this. Pretty much makes it useless really. My boost gauge goes to 30 which makes a lot more sense. My guess is Cobb has some fine tuning to do on the V3.
 Old 08-29-2013, 04:36 PM   #6
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
Any update to this issue? The bar graph is essentially useless as of now...
Danish is offline   Reply With Quote
 Old 08-29-2013, 05:01 PM   #7
That's the most confusing thing... Everyone seems to have different graphs on theirs... Seen one person with 0 to 16, mine is just nuts...
 Old 08-29-2013, 05:03 PM   #8
Matrix311's Avatar
Posts: 2,133   (View Stats)
Mine gets delivered this afternoon. I'll mess with it and if i find a solution i'll post up.
MizzyMS3 (08-30-2013)
 Old 08-29-2013, 06:26 PM   #9
Mistersix's Avatar
0-16? Thats silly. Even OTS maps target more than that.
 Old 08-30-2013, 06:40 AM   #10
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
Mine comes it today as well. When I get a chance this weekend ill futz with it and see.
KayWhy is offline   Reply With Quote
 Old 08-30-2013, 06:48 AM   #11
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
what really useless is the resolution on the kr bar gauge. it goes from 0-90..... i was going to use it as something to catch my eye while doing a pull incase i got kr but with such a high resolution it's worthless.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
Mistersix (08-30-2013)
 Old 08-30-2013, 06:49 AM   #12
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
I should be getting mine today (granted FedEx just leaves it on my doorstep) and I'll see what I can figure out as well
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
 Old 08-30-2013, 09:25 AM   #13
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
How do I do that?
I've fixed it for the next release. I've cut the limits for +/- in half, as some people in the community are pushing up to 40 PSI, etc. The new limits will be roughly +/- 50 PSI. It was a carryover from V2, but the V3 actually uses the min/max to generate the bar graph whereas the V2 does not.
-David@COBB
The Following 2 Users Say Thank You to Cobb Tuning For This Useful Post:
mazda dude (10-04-2013), Mistersix (08-30-2013)
 Old 08-30-2013, 09:28 AM   #14
-David@COBB
@David@COBB; what about the kr bar gauge? can you chop that down to say 6 or 7?
 Old 08-30-2013, 09:40 AM   #15
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
One more reason to love my DashDaq. I can set resolution to whatever I want.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 08-30-2013, 07:27 PM   #16
Mistersix's Avatar
Agreed. A knock graph of 50 still doesn't make much sense. Even 10 would be a stretch.
-David@COBB
Awesome. Love me some Cobb.
 Old 08-31-2013, 10:54 AM   #17
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I've seen 14.5* kr.
You need to read as much kr as your max wot timing table reads.
"Exclusivity" - CP-enis
Demodded.
The Seals
Mistersix (08-31-2013)
 Old 08-31-2013, 11:48 AM   #18
Mistersix's Avatar
Thats true. But if the graph goes to 6 or 15 and maxes out, either way you know you got and issue.
 Old 11-10-2013, 06:55 PM   #19
aaron88's Avatar
Posts: 277   (View Stats)
I apologize for digging up an older thread, but has COBB or anyone else figured out how to change the resolution of the boost bar gauge?
My AP V3 has the latest software up to date, but the bar gauge is still reading out to +-98.91 psi like the OP.
'08.5 CWP MS3 GT
 Old 11-10-2013, 07:30 PM   #20
still not updated @Cobb Tuning; any update on the ETA?
 Old 11-11-2013, 05:15 AM   #21
Mistersix's Avatar
I'd like to see this update happen as well.
 Old 01-28-2014, 01:44 PM   #22
aaron88's Avatar
Any ETA on this? Seems like it should be a pretty simple fix, no?
'08.5 CWP MS3 GT
 Old 01-28-2014, 01:48 PM   #23
Patty-Wack's Avatar
Posts: 885   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
I was in the process of upgrading to the V3. I guess I'll wait...ha. subbed.
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
 Old 01-28-2014, 02:41 PM   #24
aaron88's Avatar
Not a deal breaker in my eyes, but it would be nice to have some sort of answer or update.
'08.5 CWP MS3 GT
 Old 01-28-2014, 02:52 PM   #25
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Cobb is quietly picking up their clothes off mazdaspeed's bedroom floor, and tip toeing out the door to BMW's house.
The Following 5 Users Say Thank You to Agent_Orange For This Useful Post:
bstover17 (01-28-2014), Koke382 (01-28-2014), Mauro_Penguin (03-20-2014), Mistersix (03-20-2014), SarcasticOne (01-28-2014)
 Old 03-17-2014, 06:41 PM   #26
aaron88's Avatar
Just a FYI: there was an update on 3/5/14 via Accessport Manager that addresses the boost gauge resolution issue.
Much appreciated @Cobb Tuning;
'08.5 CWP MS3 GT
The Following User Says Thank You to aaron88 For This Useful Post:
 Old 03-20-2014, 05:23 AM   #27
Mistersix's Avatar
Got the update. Gauge makes a whole lot more sense now.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f506/change-v3-bar-gauge-resolution-153748/
Cobb V3 boost gauge messed up!!! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-27-2013 02:17 PM
APV3 bar graph fail - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 08-31-2013 08:53 PM
Change gauge color? tymoto21 MazdaSpeed 3 - How-To's 10 01-17-2013 02:07 PM
Squeaky Seat Resolution PiKA West 2010 MS3 - Troubleshoot/Diagnostics 66 11-24-2010 10:08 AM
smoking problem - possible resolution? bova MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-03-2009 02:49 PM
Pelosi Shoots Down Jackson Resolution Haltech Celeberty Smut 0 07-09-2009 10:00 AM
Page generated in 0.45378 seconds with 34 queries
