Ap v3, change units of measure independently on each gauge? Any chance that we could have the ability to independently change each gauge unit of measure rather than having it in ALL metric or all in imperial? ie: Would be good to have the choice personally for all pressure in PSI, and temp in Celcius for us heathens with a lack of human brain calculator power that live outside the United Dome of Americanos. :) |
They've said before that they won't support this request :( |
Thats quite a shame.. until then i shall continue to work out what a kilopascal is and why it even is in existance, and imagine my coolant and bats being the boiling temperature of... ..brine. ... |
Quote:
Yes it's annoying... But still easier than using metric for pressure |
Wonder why they won't try it, Ultragauge can do it per gauge but that doesn't log, possibly it would fuck up the APs ability to log with different units Actually latest update has option to do celcius with psi boost etc...well done Cobb |
I think it would require more code that they are not willing to put into the unit for a request that is not very popular. And yes, once you start customizing units on one screen you start having to change things elsewhere and next thing you know you are running into unit conversion problems and need to write a lot of code. Metric or Imperial, your call. ;-) |
Just updated firmware it now has the option to use Celsius with PSI instead of Faranheit, It's in the gauge display settings select UK option. |
MMMMMAAAAAAAAAAAAAAAAAAAADDDDDDDDDD |
Quote:
Quote:
And very glad I am! Wonder when that was introduced, nothing in the firmware notes... |
What Firmware is it? Im currently running v1.7.1.1-8400 which was updated back on the 5/19/14, or 19/5/14 for normal people outside the Dome lol. *EDIT never mind, found it , it mysteriously appeared with (UK) next to Imperial. nice Quote:
Quote:
| All times are GMT -7. The time now is 12:04 AM. |
