> Cobb Tuning
 Old 11-30-2012, 04:38 PM   #1
MZRSPEED's Avatar
Posts: 550   (View Stats)
Default Cobb AP not loading maps
Just started happening tonight, and i was wanting to see if it's happened to other members, and if so what caused it.
I went to load an ots map, and it does all the normal stuff, "communicating with ecu" then "loading and verifying map files" then just gets stuck on the cobb logo and nothing else comes up. I tried unplugging, reloading maps..ect.
Any info is appreciated, i'm hoping it doesn't require me to have to send it in for repair....
I will be calling Cobb monday, i just wanted to get some insight from fellow members.
***UPDATE
For anybody with this issue in the future, i found the fix on about the 10th page in the Mazda section on the Cobb forums. There seems to be a bug in the system that doesn't show often, but is related to "custom" tunes loaded in to the accessport that causes the screen to freeze and the maps not to load.
First, delete ALL "custom" tunes from your accessport, then just reload them and it should work fine. It is a easy fix, but after a few days of google searches i found nothing, so hopefully this will come up if searched.
The Following User Says Thank You to MZRSPEED For This Useful Post:
Lex (12-02-2012)
 Old 12-02-2012, 08:06 AM   #2
MZRSPEED's Avatar
@Raider; could you move this to the cobb tuning vendor forum, please?
 Old 12-02-2012, 12:46 PM   #3
Danwelford's Avatar
Posts: 24   (View Stats)
Danwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to allDanwelford is a name known to all
Just had exact same problem too
Cobb AP / CS Tip & Sri /Sure Flow M3 /Solid Shifter Bushes / SSP / REM Inserts / Forge BPV
Danwelford is offline   Reply With Quote
The Following User Says Thank You to Danwelford For This Useful Post:
MZRSPEED (12-02-2012)
Cobb OTS maps ? Cyan 2010 MS3 - ECU Computer Tuning 17 09-10-2012 01:20 PM
Cobb AP maps and TPS Mattius604 2010 MS3 - ECU Computer Tuning 3 05-29-2012 04:40 PM
can BNR stage 1 use cobb OTS maps? numbnuts22715 MazdaSpeed 3/6 - ECU Computer Tuning 7 01-02-2012 01:17 PM
really confuse on the cobb AP maps.. help :/ Sniper2606 MazdaSpeed 3/6 - ECU Computer Tuning 5 10-26-2009 07:15 PM
Page generated in 0.23973 seconds with 21 queries
