| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() | | #41 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
![]() | | #42 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | himurax13 (08-22-2013) |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Sent from my iBro 5 using tapatalk, Bro!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | rfinkle2 (08-22-2013) |
![]() | | #44 | ![]() |
![]() Join Date: Jul 2012 Location: West Palm Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
__________________ "under construction" |
| The Following 2 Users Say Thank You to 2012FailWheelDrive For This Useful Post: | El_Diablo (08-22-2013), killer-ms3 (08-25-2013) |
![]() | | #45 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score I'll try it on my way home tonight.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #46 | ![]() |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
and anyone who has ever seen me run from a roll, if we don't agree on starting off at a certain gear, you best believe I'm starting off one gear lower. I'd rather spin tire, be at full boost and bang up right away than try to build boost. | |
| The Following 3 Users Say Thank You to Voltron For This Useful Post: |
![]() | | #47 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score I've actually found ffs shifting without using it in the ap will get you better times, the bump in rpm between shifts seems to help. I picked up .2 with the same mph, consistent launches, only changing from lifting to full throttle during shifts... just tappa it in...
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
| The Following User Says Thank You to udntknw For This Useful Post: | rfinkle2 (08-23-2013) |
![]() | | #48 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Back on track because interested; what are the down sides? Possible tranny damage if grindage Way faster clutch wear... These two seem pretty big? I only ffs 2-4th when I'm racing someone that I know will be a solid race.
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
![]() | | #49 | ![]() |
I wouldn't know. I granny shift everywhere. LOL. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | MS3G35 (08-23-2013) |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2011 Location: Mechanicsburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,966
Groans: 80
| Not Ranked : 0 score You guys act like disconnecting SWAS is hard...I haven't hooked mine back up since I disconnected it, screw adding a switch.
__________________ CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS 285whp/321wtq-93 E85 tune in progress |
| The Following User Says Thank You to MS3G35 For This Useful Post: | rfinkle2 (08-23-2013) |
![]() | | #51 | ![]() |
Groans: 769
| Not Ranked : 0 score Its not hard but it sucks to have to loose power steering because of it. This car is my daily driver and by March will likely be my wife's daily driver so power steering is not something I care to live without.
| The Following User Says Thank You to El_Diablo For This Useful Post: | rfinkle2 (08-23-2013) |
![]() | | #52 | ![]() |
Groans: 80
| Not Ranked : 0 score I daily drive mine, it doesn't happen often and it's not that big of a deal when it does, the car I had before this one didn't have power steering either so i guess I am just use to it.
![]() | | #53 | ![]() |
I was hesitant as well, but the loss of power steering is almost unnoticeable and only @ very low speeds. If you have a tune on the car, I honestly feel it may be safer to unplug it for your wife because I've had people stumble / hiccup pretty badly when trying to pull out in traffic. | |
![]() | | #54 | ![]() |
Groans: 769
| Not Ranked : 0 score Rob, while I tend to agree I'm hoping somebody will have the knowledge to complete my SWAS fix circuit. I know how to do it but not the components needed to get the job done. If someone would step up we could make this a DIY kit or I'm sure someone could make some money off of it. It's a very simple circuit.
![]() | | #55 | ![]() |
| The Following 4 Users Say Thank You to GODspeed7 For This Useful Post: |
![]() | | #56 | ![]() |
@ms3blackmica; wanna make a "mad scientiest swas kit" and a few bucks? LOL. | |
![]() | | #57 | ![]() |
Groans: 122
| Tell me about it... Thanks a lot Rob.
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | rfinkle2 (08-23-2013) |
![]() | | #58 | ![]() |
![]() Join Date: Sep 2012 Location: Perth, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
will give it a test. Hopefully same rules apply fit AUST versions.
__________________ SG9 XT: VF34 P20, Tomei headers, STI intercooler HSD coilovers, Brembos and much more... | |
![]() | | #59 | ![]() |
Groans: 77
| Not Ranked : 0 score fuck that. ffs all day all night. lift shifts against me are a bad idea. |
![]() | | #60 | ![]() |
Groans: 122
Gas cap light is a screw looking thing going into the side of the car. lol And if you don't hold it long enough, it will not illuminate.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | DAN MPS 3 (08-23-2013) |
![]() | | #61 | ![]() |
![]() | | #62 | ![]() |
Didn't drive it, so will test it tomorrow.
![]() | | #63 | ![]() |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | DAN MPS 3 (08-23-2013) |
![]() | | #64 | ![]() |
Groans: 77
@rfinkle2; @ms3blackmica; | |
| The Following User Says Thank You to Voltron For This Useful Post: | ms3blackmica (08-23-2013) |
![]() | | #65 | ![]() |
| Not Ranked : 0 score Sent from my iBro 5 using tapatalk, Bro!
![]() | | #66 | ![]() |
| Not Ranked : 0 score I don't know each of the model year's swas activity with all of the button tricks tbh. I ask most of the guys / girls to unplug it to avoid and interruptions from it. |
![]() | | #67 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
Hoping Cobb releases an On/Off Toggle.
__________________ www.tunedbynishan.com | |
![]() | | #68 | ![]() |
Groans: 769
| Not Ranked : 0 score For my 2011 the button method doesn't work. I've tried multiple times and multiple ways. Thats what everyone keeps telling me but its just a voltage reducer really... Basically taking a 5v signal and turning it into a .75-1.25v signal and then just solder it in.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson Last edited by El_Diablo; 08-23-2013 at 10:47 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to El_Diablo For This Useful Post: | ms3blackmica (08-23-2013) |
![]() | | #69 | ![]() |
I know what you are talking about and I have seen it work on some Gen 2's. Perhaps it was something from the factory that they tried? However, many Gen 2's need to unplug the sensor to remove SWAS including Teddy.
![]() | | #70 | ![]() |
| Not Ranked : 0 score I'm sorry I thought we were all on the same page. The guy from AUS I thought had a 2012. The button trick only seems to work for 2012 and 2013. Does it not work on your 2012 @Voltron Locos; Sent from my iBro 5 using tapatalk, Bro!
![]() | | #71 | ![]() |
![]() Join Date: Feb 2012 Location: Dana Point, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,483
Groans: 107
Groaned at 9 Times in 9 Posts
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Defi Boost gauge *Product is advertised as ID300 | |
| The Following User Says Thank You to Keko For This Useful Post: | DAN MPS 3 (08-23-2013) |
![]() | | #72 | ![]() |
Groans: 77
![]() | | #73 | ![]() |
| The Following 5 Users Say Thank You to rfinkle2 For This Useful Post: | CWP_MS3 (08-23-2013), Easter Bunny (08-24-2013), El_Diablo (08-23-2013), GODspeed7 (08-23-2013), himurax13 (08-23-2013) |
![]() | | #74 | ![]() |
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score There is some other elaborate process that you can do also. Holding down the tcs and brake before starting it for so many seconds, then start and it disables that feature. Not sure if that is exact process, I do not remember, but did it once before.
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
| The Following User Says Thank You to cshunter For This Useful Post: | rfinkle2 (08-23-2013) |
![]() | | #75 | ![]() |
| Not Ranked : 0 score So either way on my MPS 3 (2012 MY13) it seems that I can hold the TCS either before starting the car or while driving and it plays the game. I didn't exactly go all out on public roads but on 2 corners every morning it normally decides to be MR.Buzzkillingtons if I push a little to hard, and today it seemed to not to cut in... Maybe it is psychological, maybe I wasn't aggressive enough or maybe it does work. Will try it again on the way home I guess and see if I can get it to kick-in and cut power. Won't know 110% until I throw it around a track any excuse to race I guess.
![]() | | #76 | ![]() |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Just hold the button down for 10 seconds or so after you start it and forget about it. If you can't turn it back on, then you know you're good.
__________________ |
| The Following User Says Thank You to Spec For This Useful Post: | DAN MPS 3 (08-23-2013) |
![]() | | #77 | ![]() |
| Not Ranked : 0 score If this does work it will be one of the best investments on the car! My last few track days have been great but if you try to get on the power early and jump out of a corner it just cuts you down ![]() Cheers to the MSF crowd for sharing this info!
![]() | | #78 | ![]() |
| Not Ranked : 0 score Mine does that if I just push it once. Push and hold until you can't turn it back on, you can roast the tires until you slide of the track.
![]() | | #79 | ![]() |
Slide of the track and die... LOL Sent from my iBro 5 using tapatalk, Bro!
![]() | | #80 | ![]() |
__________________ | |
| Flat Foot Shifting Calculator & How To Set | aaronc7 | Cobb ATR Support | 35 | 01-28-2014 08:47 PM |
| Knock Retard with Flat Foot Shifting | JFord | Gen2 MS3 General Discussion | 9 | 05-15-2013 01:37 PM |
| Knock while flat foot shifting with AP. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 04-19-2011 08:35 PM |
| Launch Control and Flat Foot Shifting | Mazdasp33d | Cobb Access Port/Maps | 38 | 08-06-2009 09:22 AM |
