> Cobb Tuning
 Old 04-02-2011, 09:10 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Rad fan adjustment in ATR ??
Anyone have any luck with the rad fan temp control ? I adjusted mine in ATR to come on at 195 .. But doesn't seem to work ..
I was told it doesn't work yet in atr ..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
kgb (05-19-2011)
 Old 04-03-2011, 08:37 AM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Didn't work for me either; they know about it though.
jracer (04-04-2011)
 Old 04-08-2011, 09:04 PM   #3
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
Mine doesn't seem to be working either.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
jracer (04-12-2011)
 Old 05-12-2011, 10:21 PM   #4
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
does this work now? my ect's have been hovering around 215* during idle since my fmic install.
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 05-12-2011, 10:51 PM   #5
Enki's Avatar
Groans: 189
Nope, mine is set to 190 and I still see temps climb till 220 before it kicks in.
JohnMS3 (05-13-2011)
 Old 05-26-2011, 01:27 PM   #6
kgb
kgb's Avatar
Posts: 808   (View Stats)
Groans: 88
I've been emailing Travis at Cobb to see if they are aware and can repeat this issue. He said he will let the team know about our concerns. I also gave him the link to this thread.
FYI..I am selling my HT tune soon and getting a FMIC so I just wanted to push this along.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
 Old 05-26-2011, 01:51 PM   #7
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
If you look at the x axis values you will see they are Baro pressure. A value of 1.04 is 30.71 in hg which is pretty high pressure. I don't think most people will see atmospheric pressure that high to enable the temp settings. maybe Cobb can adjust the baro scale lower to more prevalant pressures....
FORZDA 1 is offline   Reply With Quote
The Following User Says Thank You to FORZDA 1 For This Useful Post:
Enki (06-30-2011)
 Old 05-26-2011, 04:20 PM   #8
kgb
kgb's Avatar
Groans: 88
Here's what Travis sent me:
"Ok, I got the final word on the rad control. Sadly, this function still is not operating as expected. We will be looking into fixing this, but I don't have a date on it. That said, rad control is only really something you need at idle or very low speed. Are there overheating issues with these cars?"
I told him that our cars don't OVER heat per se but I think that these cars may get hotter than other comparable turbo 4 bangers.?.?.
I guess we'll see.
The Following User Says Thank You to kgb For This Useful Post:
jracer (06-02-2011)
 Old 06-30-2011, 05:07 PM   #9
Enki's Avatar
Groans: 189
Now running the beta version of both ATR and APM. Updated my map, saved to 190 deg F. and still no love. A log is attached.
I've also found one thing that does trouble me a fair bit; it used to be that when the car was above some unknown temperature threshold and was shut down, the radiator fan would kick on balls deep for a few seconds to cool down the water a fair bit. I've just realized it has not done this for quite some time (possibly since I started flashing with the AP).
The attached log shows the fan kicking on at a "high" 217 deg, and shutting off when it reaches a "low" 213. I shut the car down @ 217 and there was no audible sound from the radiator fan.
 Old 07-02-2011, 08:08 PM   #10
Enki's Avatar
Groans: 189
Per response from Cobb, it's apparently still an issue with Gen 1.
 Old 07-02-2011, 08:25 PM   #11
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
isnt there a known bug with ATR in that even set to standard with degrees in F, its actually still reading C? try setting the equivalent to 195 in Celsius and see how it works out maybe? if anything your fan will just run continuously till you change it back, right?
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
 Old 07-02-2011, 08:50 PM   #12
Enki's Avatar
Groans: 189
Already did that, the only thing that changed is that my fan now comes on when I shut the engine down.
 Old 07-02-2011, 10:27 PM   #13
Same here, I tried the new BETA ATR and set my fan at 90.56C (~195F) and my fan doesn't kick in.
 Old 07-02-2011, 11:01 PM   #14
bummer. well im sure Cobb is hard at work figuring it out. Theyre good to us
'12 Ford Focus SEL
 Old 09-02-2011, 11:29 AM   #15
jracer's Avatar
Groans: 89
Any update on this yet ???
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 09-02-2011, 01:00 PM   #16
Enki's Avatar
Groans: 189
Running the latest, still no workie so far as I can tell.
 Old 09-05-2011, 06:33 PM   #17
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
something about the fan having a separate controller
 Old 09-05-2011, 08:09 PM   #18
Enki's Avatar
Groans: 189
That sounds about right; there's quite a bit of electronics attached to it.
 Old 09-05-2011, 08:14 PM   #19
08cosmic3's Avatar
Posts: 2,920   (View Stats)
subbing for more.
 Old 09-05-2011, 09:54 PM   #20
Enki's Avatar
Groans: 189
I think what Cobb might have to do is trick the fan controller into thinking the AC is on at the preset temperature; the tables they have are probably for engine-off operation of the fan (hot shutdown and rapid cooldown).
 Old 09-18-2011, 01:21 AM   #21
jwilson0514's Avatar
Posts: 54   (View Stats)
jwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura about
Dam I would really love to have this option available!! Especially if u live some were Hott. I see the rad fan controls avaliable in ATR but like u guys were saying doesnt work.
jwilson0514 is offline   Reply With Quote
 Old 11-05-2011, 08:03 PM   #22
radbrad's Avatar
Posts: 538   (View Stats)
Still no update?
07Speed3
 Old 11-06-2011, 01:19 AM   #23
Enki's Avatar
Groans: 189
Still doesn't work.
 Old 11-06-2011, 09:29 AM   #24
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
Bummer. I have really long driveway (~15+ speed bumps) and by the time I park in my garage and shut it off my rad fan comes on and stays on. I'd like some control over this ie have the rad fan come on as I climb up my speed bump hill so my temps don't get so high.
Danish is offline   Reply With Quote
H & R Rear Coilover Adjustment Msicks2829 MazdaSpeed 3/6 - Suspension & Brakes 20 12-24-2010 12:41 PM
Window adjustment turboneil MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-12-2010 12:53 AM
Front camber adjustment? joe149 Auto-X / Road Racing / Time Attack 22 05-07-2010 07:04 PM
How often to coils need adjustment KayWhy MazdaSpeed 3/6 - Suspension & Brakes 4 09-28-2009 06:17 AM
BOV adjustment help Nazarite Mazdaspeed3/6 General Discussion 10 03-23-2009 08:32 AM
Page generated in 0.39708 seconds with 32 queries
