| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
(Thread Starter) | Not Ranked : 0 score I was told it doesn't work yet in atr ..
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following User Says Thank You to jracer For This Useful Post: | kgb (05-19-2011) |
Groans: 189
| Not Ranked : 0 score Didn't work for me either; they know about it though.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | jracer (04-04-2011) |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score Mine doesn't seem to be working either. |
| The Following User Says Thank You to 11cruzito11 For This Useful Post: | jracer (04-12-2011) |
![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 472
| Not Ranked : 0 score does this work now? my ect's have been hovering around 215* during idle since my fmic install.
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
Groans: 189
| Not Ranked : 0 score Nope, mine is set to 190 and I still see temps climb till 220 before it kicks in.
| The Following User Says Thank You to Enki For This Useful Post: | JohnMS3 (05-13-2011) |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score I've been emailing Travis at Cobb to see if they are aware and can repeat this issue. He said he will let the team know about our concerns. I also gave him the link to this thread. FYI..I am selling my HT tune soon and getting a FMIC so I just wanted to push this along.
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score If you look at the x axis values you will see they are Baro pressure. A value of 1.04 is 30.71 in hg which is pretty high pressure. I don't think most people will see atmospheric pressure that high to enable the temp settings. maybe Cobb can adjust the baro scale lower to more prevalant pressures....
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
| The Following User Says Thank You to FORZDA 1 For This Useful Post: | Enki (06-30-2011) |
Groans: 88
| Not Ranked : 0 score Here's what Travis sent me: "Ok, I got the final word on the rad control. Sadly, this function still is not operating as expected. We will be looking into fixing this, but I don't have a date on it. That said, rad control is only really something you need at idle or very low speed. Are there overheating issues with these cars?" I told him that our cars don't OVER heat per se but I think that these cars may get hotter than other comparable turbo 4 bangers.?.?. I guess we'll see.
| The Following User Says Thank You to kgb For This Useful Post: | jracer (06-02-2011) |
Groans: 189
| Not Ranked : 0 score Now running the beta version of both ATR and APM. Updated my map, saved to 190 deg F. and still no love. A log is attached. I've also found one thing that does trouble me a fair bit; it used to be that when the car was above some unknown temperature threshold and was shut down, the radiator fan would kick on balls deep for a few seconds to cool down the water a fair bit. I've just realized it has not done this for quite some time (possibly since I started flashing with the AP). The attached log shows the fan kicking on at a "high" 217 deg, and shutting off when it reaches a "low" 213. I shut the car down @ 217 and there was no audible sound from the radiator fan.
Groans: 189
| Not Ranked : 0 score Per response from Cobb, it's apparently still an issue with Gen 1.
![]() Join Date: Jan 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
Groaned at 50 Times in 30 Posts
| Not Ranked : 0 score isnt there a known bug with ATR in that even set to standard with degrees in F, its actually still reading C? try setting the equivalent to 195 in Celsius and see how it works out maybe? if anything your fan will just run continuously till you change it back, right?
__________________ '12 Ford Focus SEL |
Groans: 189
| Not Ranked : 0 score Already did that, the only thing that changed is that my fan now comes on when I shut the engine down.
| Not Ranked : 0 score Same here, I tried the new BETA ATR and set my fan at 90.56C (~195F) and my fan doesn't kick in. |
| Not Ranked : 0 score bummer. well im sure Cobb is hard at work figuring it out. Theyre good to us
Groans: 89
(Thread Starter) | Not Ranked : 0 score Any update on this yet ???
Groans: 189
| Not Ranked : 0 score Running the latest, still no workie so far as I can tell.
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score something about the fan having a separate controller |
Groans: 189
| Not Ranked : 0 score That sounds about right; there's quite a bit of electronics attached to it.
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score subbing for more. |
Groans: 189
| Not Ranked : 0 score I think what Cobb might have to do is trick the fan controller into thinking the AC is on at the preset temperature; the tables they have are probably for engine-off operation of the fan (hot shutdown and rapid cooldown).
![]() Join Date: Jan 2011 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 50
| Not Ranked : 0 score Dam I would really love to have this option available!! Especially if u live some were Hott. I see the rad fan controls avaliable in ATR but like u guys were saying doesnt work. |
![]() Join Date: May 2011 Location: Ft. Worth TEXAS
| Not Ranked : 0 score Still no update?
__________________ 07Speed3 TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. || |
Groans: 189
| Not Ranked : 0 score Still doesn't work.
![]() | | #24 | ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 249 Times in 46 Posts
| Not Ranked : 0 score Bummer. I have really long driveway (~15+ speed bumps) and by the time I park in my garage and shut it off my rad fan comes on and stays on. I'd like some control over this ie have the rad fan come on as I climb up my speed bump hill so my temps don't get so high. |
| H & R Rear Coilover Adjustment | Msicks2829 | MazdaSpeed 3/6 - Suspension & Brakes | 20 | 12-24-2010 12:41 PM |
| Window adjustment | turboneil | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 07-12-2010 12:53 AM |
| Front camber adjustment? | joe149 | Auto-X / Road Racing / Time Attack | 22 | 05-07-2010 07:04 PM |
| How often to coils need adjustment | KayWhy | MazdaSpeed 3/6 - Suspension & Brakes | 4 | 09-28-2009 06:17 AM |
| BOV adjustment help | Nazarite | Mazdaspeed3/6 General Discussion | 10 | 03-23-2009 08:32 AM |
