| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
(Thread Starter) | Not Ranked : 0 score After changing both the OL/High throttle tables (Knocking and Not Knocking) to the same values along with the Unknown timing map, the actual timing of the vehicle does not match these command tables at WOT. Attached are the map file along with the log file. If I increase the timing in these tables, it also has no effect on actual timing indicating this is not an offset issue. The ATR version is: 1.9.1.0-3024 The AP FW version is: 1.6.5.0-2992 The vehicle is a 2010 MS3
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 12-13-2011 at 12:09 PM. |
| The Following 5 Users Say Thank You to Lex For This Useful Post: | BlueStreak (12-14-2011), Dano (12-12-2011), djuosnteisn (11-08-2012), evidence (12-27-2011), rfinkle2 (12-13-2011) |
(Thread Starter) | Not Ranked : 0 score Bumpity bump COBB. Also can anyone else running ATR for the 2010 (newest version) verify this?
The only time I've run into a problem similar to what you are describing is when I had the closed loop max load tables set pretty high. One of the closed loop max load tables definitely has an effect on timing. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Lex (12-12-2011) |
(Thread Starter) | Not Ranked : 0 score They're all set to 1.0
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (12-12-2011) |
| Not Ranked : 0 score |
| Not Ranked : 0 score Lex I have a 2010 in my station and don't recall this becoming a problem with the latest AP/ATR, so I'll take a closer look at his logs when I get the next round back...hes up in the east coast and getting wetter and wetter all the time so it may be a while.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score Thanks guys, perm tuning ftw
__________________ 2010 ms3-sold ww evo x -385/360 |
| Not Ranked : 0 score Is this zbrit's car @Lex? |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Lex (12-13-2011) |
| Not Ranked : 0 score is the unknown timing map, MAX A/B timing? maby i missing something because this is a genpu only thing but im sure you have your max tables set accordingly right?
(Thread Starter) | Not Ranked : 0 score Yes, this is zbrit's car. His max timing values are much above what the car is commanding. Dano, take a look closely at the car you're tuning - it may not be obvious and if you get a chance the map I posted up. Maybe something I overlooked. Hi timing is not terribly low, it just won't move up. I will make a map with a lot lower timing to see if it moves down shortly.
| The Following User Says Thank You to Lex For This Useful Post: | djuosnteisn (12-13-2011) |
(Thread Starter) | Not Ranked : 0 score Uploaded the timing tables instead of the entire map to make things a little easier to see. It seems that overall timing is between OL and CL maps (the knocking and not knocking tables are identical). I just sent him a map with OL and CL maps being identical. We will see if this resolves the issue. In the Gen1 speeds, at WOT only the OL timing tables are used.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (12-13-2011) |
I'm 99% sure all 4 of those tables are the same in all ots maps. | |
![]() COBB has gone through several versions of the timing maps and how they dealt with them over the various maps.
(Thread Starter) | Not Ranked : 0 score Hey COBB, I figured out your problem Your 2010 Gen2 timing tables are scaled to the Gen1 axes. So, the 2.19 load value corresponds to the 2.00 value on the gen1 table. If you look at the log, at 6500 RPM he is running 1.61 load. In the Gen2 table he should be running somewhere around 16* of timing and he is actually running 13.5* If you however use the axes of the Gen1 maps, you will see that the 1.61 load value is between row 7 and 8. Now back to the Gen2 map, row 7 and row 8 at 6500 RPM are 13.5 and 14* You can play this game with other values. at 5000 RPM he is running 2.0 load and 6*. He should be running 8.5*. However the bottom most row (2.19) is 6* which lines up with the bottom most row on the Gen1 which is 2.0 load.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 12-14-2011 at 03:00 PM. |
| The Following 9 Users Say Thank You to Lex For This Useful Post: | atvfreek (12-14-2011), charlesfist (12-29-2011), Dano (12-14-2011), djuosnteisn (12-14-2011), FreeFlyFreak (12-16-2011), LiEast (01-11-2012), rfinkle2 (12-14-2011), RichieRichness (12-15-2011), silvapain (12-14-2011) |
In the latest version of atr, 3 additional lines of resolution were added in the ignition tables. i.e. 2.06, 2.13 and 2.19. Did the latest version of atr for gen1 add these (or 3 additional axes)? Thanks for the research Lex. | |
(Thread Starter) | Not Ranked : 0 score No, then gen1 ATR only has the y-axis go up to 2.00 load. Rob, is this the first version to introduce the higher resolution? If this is the case, I would be even more suspicious and if you're tuning a 2010+ car would be careful until the issue is resolved. The saving grace is that you end up running less timing than you want instead of more.
Groans: 136
Tapadatass
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | Lex (12-14-2011) |
(Thread Starter) | Not Ranked : 0 score Can someone please change the thread title fail to: Timing does NOT follow tables bug - 2010 MS3 ATR
I'm going to post up my high throttle knocking table. It contains up to 2.19 load values. (This latest version of ATR is the first to do so) | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Lex (12-14-2011) |
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (12-14-2011) |
I change all of my tables to identical values and incorporate the max tables to prevent table hopping. @Lex, and @silvapain, I attached a datalog to the post containing my ignition table. This is from the testing being done for an e85 mix (with Cobb's e85 scaling). | |
Groans: 239
| Not Ranked : 0 score yes sir
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #24 | ![]() |
| Not Ranked : 0 score I just realized this (my example) may not help much due to the .25 degree increments between load values that I use. EDIT: Lex sees what he needs to see. LOL |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score At 6k RPM you should be running 19* and you are running 18*. Thanks for confirming by posting up your map and log.
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Those extra 3 rows caused havoc with my tune and kr. When you resave the map in atr it shifts the whole table down three rows. So I had my timing table set at 2.0 load and vertically interopolated. Then once my map resaved it was running close to 2 more degrees of timing across the board. Because it was still on the 2.0 axis that is now 3 rows up. Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score I would match their actual loads with the timing table and wait for COBB to fix it because when they do, timing will jump up for these guys and cause KR/issues.
![]() | | #31 | ![]() |
| Not Ranked : 0 score @atvfreek, how far do you bump timing up per decrease in load value? i.e. .5 degree per line of load resolution needs to be addressed, but hopefully won't cause too many problems. |
![]() | | #32 | ![]() |
Tappin
| The Following User Says Thank You to atvfreek For This Useful Post: | rfinkle2 (12-14-2011) |
![]() | | #33 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score I noticed this issue In my car also. My car doesn't run the timing commanded, all my tables are the same except the max tables which are higher. I am logging 10 deg always at 6k my tables command 11.5, although no matter where I set it, it always runs 10 Hopefully this issue is fixed as I am leaving a bit of HP on the table.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following 3 Users Say Thank You to G26 For This Useful Post: |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Any word from cobb yet? I feel like going in to Cobb SoCal and notify them too!
![]() | | #35 | ![]() |
If you can get in touch that would be great as well - after all - the more people that raise the issue the better.
| The Following User Says Thank You to Lex For This Useful Post: | Zbrit00x (12-15-2011) |
![]() | | #36 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
-David@COBB | |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks David. Also note that it is the latest release of ATR that has exposed this issue. Previous versions have the Y-axis only going to 2.00 load just like in the Gen1 software.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (12-16-2011) |
![]() | | #38 | ![]() |
It will be fixed in the next release. -David@COBB | |
| The Following 5 Users Say Thank You to Cobb Tuning For This Useful Post: | djuosnteisn (12-27-2011), Lex (12-16-2011), rfinkle2 (12-16-2011), RichieRichness (12-16-2011), silvapain (12-16-2011) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks David, when should we expect the next release/fix? I have a few people with Gen2 cars waiting on timing changes and I don't want to put the higher timing values in the higher load sections to compensate for this in the current version/
| The Following 2 Users Say Thank You to Lex For This Useful Post: | rfinkle2 (12-16-2011), RichieRichness (12-16-2011) |
![]() | | #40 | ![]() |
Groans: 39
| Not Ranked : 0 score Awesome, should this affect those with very similar to OTS timing already? As in cause KR issues etc? Or can I just copy/paste my values over to the new table when the fix comes out?
| Smoothing timing tables | superskaterxes | Cobb ATR Support | 39 | 12-05-2012 01:13 PM |
| Share your E85/Cobb AP timing tables? | bnoon | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 08-16-2011 03:50 PM |
| Any risk when setting throttle req load tables high to force boost by gear tables? | 08Anamoly | Cobb ATR Support | 5 | 03-29-2010 08:52 PM |
| Chicago 2010: Bad Timing Dept. - Prius MotorWeek Drivers' Choice winner; Toyota declines JDM award | Haltech | Automotive News | 0 | 02-11-2010 08:10 AM |
