| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: Aug 2013 Location: Barstow/Rialto, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
__________________ 2013 White Pearl MS3 JBR SSP/bushings/RMM/EGR delete Corksport 3ID Intake/Radiator Cobb APV3/AT Internals Grimmspeed 3 port EBCS/Matt Damond CC FMIC W/DIY Sprayer CPE DP |
![]() Join Date: Oct 2013 Location: FL -IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score Was wondering the same thing with no luck on finding any answers |
![]() Join Date: Jul 2011 Location: New York
Rep Power: 131 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 76
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score What changed between this and v231 on any of the maps? |
![]() Join Date: Sep 2013 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score if you select "Download Map Notes" you can see: v233 - Revised map names for staged package support. v232 - World Market 2009 - 2012 MAZDASPEED3 / Mazda3 MPS /MAZDASPEED Axela only. Corrected a small fueling error in the WOTfueling tables.
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
| The Following User Says Thank You to ihasmazda For This Useful Post: | SarcasticOne (01-12-2015) |
![]() Join Date: Jun 2009 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
__________________ Go Fast Parts: ETS 3.25" TMIC, Cobb TIP, COBB SF Intake, Racing Beat CBE, Cobb AP, Ultimate Racing Resonated TP, AT Internals, COBB XLE BPV Other Stuff: Denso ITV22, CS LED Kit, DDM 35w HID kit w/ TRS Lenses, Cobb shift weight, CS Urethane exhaust hangers, Bilstein sports, CP-e stage II RMM, Whiteline F/R Endlinks, Rays Forged Mazdaspeed Wheels, TWM Big Type R Knob, CS AL skid plate, CS shifter bushings, CS RSB |
| The Following User Says Thank You to Bujwazay For This Useful Post: | SarcasticOne (01-12-2015) |
| Not Ranked : 0 score I checked out that pdf and it seems like cobb only states the difference between Base map, 91 octane map, and stage 3. It just so happens to be that the OTS maps are v233. I don't think that pdf is illustrating what's new for v233. | |
| Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps | FreeFlyFreak | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 08-18-2011 11:03 PM |
| FFS and v 101 maps | cm-jp1 | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 10-05-2009 11:31 AM |
| Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) | steven88 | Cobb Access Port/Maps | 8 | 10-15-2008 06:48 AM |
| New v.102 maps are available now! | 94jedi | Cobb Access Port/Maps | 148 | 08-20-2008 02:05 PM |
