> Cobb Tuning
 Old 12-13-2011, 08:47 PM   #1
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
Default why do i always lean out in the 55xx rpm range till redline.
hey all i have 0 problems with boost, my afr are spot on till like 52-5500 rpm then they star leaning. like if i request 11.8 it goes to like 12.1 which i know some say is safe but i dont like it. i think i am just gonna copy my wgdc to a ots map and redo maf cal? ideas, thanks
 Old 12-13-2011, 08:50 PM   #2
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
howbout a log?
FP?
 Old 12-13-2011, 08:57 PM   #3
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
take a wot log, take your actual afr and dived that by your target afr. then multiply that times the areas in your maf cal which are going lean, for example, say at 5800 rpm your at 12.1 and targetting 11.8. 12.1/11.8 = 1.025 say you're at 280 g/s, for that part of your maf cal just multiply by 1.025, same goes for rich say 11.4 actual, 11.8 targetted, 11.6/11.8 = .996
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
The Following User Says Thank You to speedms6 For This Useful Post:
skeeter149 (12-13-2011)
 Old 12-13-2011, 09:14 PM   #4
skeeter149's Avatar
Groans: 91
sorry log in a sec let me find one... oke log 1.05 is ots afr so we all know they should be in the 10's. and datalog 2 is requesting 11.8. thanks.
 Old 12-14-2011, 06:41 AM   #5
Bob Ross Fanclub
Tomas's Avatar
Update your AP. Your datalog rate is still the old slow one.
FP looks ok.
Your AFR looks to be between 11.9 and 12.2 across the rev range not just past 5.5K rpm.
Overall looks ok to me. If you want to richen up the mixture I would just do it via requested AFR.
skeeter149 (12-14-2011)
 Old 12-20-2011, 03:19 PM   #6
skeeter149's Avatar
Groans: 91
ok so i am requesting afr of 11.4 and seeing 11.8-11.9. iswhere else can i change afr besides the o/l c/l transitions in case i missed something?
 Old 12-20-2011, 04:31 PM   #7
When in open loop, you want to adjust your af ratio by maf volts, and make sure the issue happens consistently @ the same maf voltage.
Take your exhaust reading, divide it by commanded wot afr's to get the multiplier for the maf voltage you are correcting.
E.g., you mentioned you wanted to correct 12.2 exhaust readings from 11.8 commanded.
12.2 / 11.8 = 1.03 = multiplier to apply to the maf voltages that you want to correct.
I always remember it this way:
E/D = erectile disfunction = exhaust / dic(k)tated = correction factor.
Sorry, but I bet you remember it now too. LOL
ArcticSpeed3 (12-20-2011), atvfreek (12-20-2011), Easter Bunny (12-21-2011), skeeter149 (12-20-2011)
 Old 12-20-2011, 04:46 PM   #8
skeeter149's Avatar
Groans: 91
thanks fink heres a short log from yesterday, sorry i didnt go higher in rpm. but i was just wondering if you could walk me through the adjustment per the log. i am requesting 11.4 afr at the 1.25 load and 2500 rpm as per abilors guide through the range.
edit: ap is updated. also i did just move the coolant lines off my cold pipe so i dont know if the heat affects it but thats why my bats were so high.
ok fink lemme pull about 3 more so i can see if it is consistent and try and get a lower rpm as well. then can i email you and see if we come up with the same thing to change?
The Following User Says Thank You to skeeter149 For This Useful Post:
rfinkle2 (12-20-2011)
 Old 12-20-2011, 04:56 PM   #9
Interesting thing that I see here is gen1 cars usually have a -.16 in when in o/l, whereas your car has a .62
Does your closed loop max load D table reflect the 1.25 load value that you want to target 11.4 afr's with?
I see what you mean as far as leaning out some.
I'm sure we can get it worked out... just need more info.
 Old 12-20-2011, 05:04 PM   #10
skeeter149's Avatar
Groans: 91
500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000
1.10 1.10 1.10 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00
those are my max load d tables. there from the new ots map. is that a issue? and i had .16 but changed my maf cal. let me go back to the other cause this change did me no good and the other is only 5 different at top. this one maxes at 383 that one is 388 for example and i think i did always see .16 in ol. lemme check my first log with the other maf cal.
yep datalog 2 in post 4 has the .16. i think i need to just throw down a new maf cal for safety sake or can the current be saved?
 Old 12-20-2011, 05:24 PM   #11
Skeeter,
Your closed loop max load tables show that you want to enter open loop fueling @ 1, whereas your fueling maps (judging from posts above) are set up for a transition of 1.25.
Here is an example of how you might want your fueling tables to look if you are telling the ecu, "my max load I want you to stay in closed loop is up to 1.25". (note targeting 12.0 here, but you get the point)
 Old 12-20-2011, 06:21 PM   #12
skeeter149's Avatar
Groans: 91
ok fixed my max d table anything else i need to do?
 Old 12-21-2011, 06:39 AM   #13
Based on the strange ltft reading @ wot, and the leaning out issue, I would start with a fresh
maf cal. starting from an ots maf curve.
I.e. - no need to start entirely over, but you may want to copy and paste the ots maf curve into your map, drive for about 50 miles or so and give the maf cal another shot.
skeeter149 (12-21-2011)
 Old 12-21-2011, 12:54 PM   #14
skeeter149's Avatar
Groans: 91
sounds like a plan finkle. i will do that this week and then try and throw down a sick woorking maf cal lol
finkle is it cool if i have you kinda go over the maf cal i throw down so i can make sure its right. like send you the logs and get your advice before i make the changes? its gonna take me a minute to do the 50 miles but i think i can do it tomorrow.
 Old 12-21-2011, 01:08 PM   #15
Oh hell yeah.
pm' ing you now.
How much time from startup till blue temp light turns off? G26 Gen2 MS3 General Discussion 37 07-13-2012 07:44 PM
Wilbur Ross's IAC to delay IPO till early 2012, sources say Haltech Automotive News 0 09-09-2011 10:00 PM
Ford: Monthly sales pace won't return to 13M rate till late summer Haltech Automotive News 0 06-29-2011 10:00 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 10:10 PM
At his store, shop till you (gasp!) drop Haltech Automotive News 0 05-17-2010 03:00 PM
Page generated in 0.34214 seconds with 24 queries
