> Cobb Tuning
 Old 01-26-2013, 11:29 AM   #1
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
So, AP Logs are in a standard CSV format (comma separated values)
Knowing nothing else about what you're working with aside from the assumption that Cobb AP Manager and ATR are successfully installed I would suggest that you try saving an excel file as a csv file from within excel and then opening it again. This tests your ability to do csv files, to save and open that format.
In theory, if CSV is available as a save to format, and you can open that file you just saved, then you should be able to open log files.
If you still blue screen when opening cobb ap log files, then attach one here and let us take a look at what your playing with.
Okay I got a lil bit further now. So for some reason excel 10 on this win8 computer can't open/save the logs in unicode txt file like on my win7. It only saves (without giving weird message) as excel workbook file.
So what I did was open excel and drag/drop the log into excel. It opened up perfectly. When I go in and save it to anything other than excel workbook file it saves it all weird.
Now I just need to figure out how to do it so it can open up the logs automatically like my win7.
datalogs exentix MazdaSpeed 3/6 - ECU Computer Tuning 5 06-09-2012 04:32 PM
new ms3, new datalogs evolizzee 2010 MS3 - ECU Computer Tuning 7 06-27-2011 08:23 AM
Datalogs after MAF Cal mazdaspeed joel
Cobb ATR Support
21 05-04-2011 12:04 PM
Another Datalogs Zak MazdaSpeed 3/6 - ECU Computer Tuning 4 09-18-2009 01:53 PM
Datalogs bova MazdaSpeed 3/6 - ECU Computer Tuning 15 03-26-2008 11:59 AM
Page generated in 0.23362 seconds with 21 queries
