![]() | | #41 | ![]() |
![]() Join Date: Nov 2010 Location: Benbrook, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
Groaned at 18 Times in 14 Posts
| Not Ranked : 0 score Sent from my XT926
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch |
| The Following User Says Thank You to aggierandy For This Useful Post: | Code Monkey (02-24-2014) |
![]() | | #42 | ![]() |
-- long-nosed crank -- no power doors, mirrors, etc But I was looking at anything 91-97 and it just happened that this one came at the price I could not refuse. ![]() Here is a video of an instructor doing a 2:02 in his 1.6 Miata at the TWS, I think my best time in the Mazdaspeed is about 2:05 so far. ![]() I talked to the guy and the Miata has: "Megasquirt fill intake and exhaust tune not completed yet. poly diff and suspension bushings. AST coilovers and no chassis stiffening. 1.6 open diff slowing me down with 4.10 ratio. 225 nt01's and 15X9 wheels." Thus, I am not worried about the car not performing at the track, and so far it has been great driving around town, you rev that sucker to 7500 and go to 60 in 2nd, immediately puts a stupid grin on your face.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following User Says Thank You to Code Monkey For This Useful Post: | aggierandy (02-24-2014) |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score Even Miata keys have aids.... Here is my horn hook up. ![]() Drove around town a bit and the wheel does get in the way of seeing the instrument cluster, @El_Diablo; I can only see the speed up to 40mph, then the wheel gets in the way. Again, it is only temporary, some day I will be going for racing seats and bolting them to the floor.
![]() | | #44 | ![]() |
| Not Ranked : 0 score Being 6'2" doesn't help, I can't see the top of my speedo or tach either. Guess it doesn't really matter as long as I'm not speeding and I can see 5k+ so I know I'm not sitting on redline.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Code Monkey (03-02-2014) |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Picked up a set of used 15x8 UL's.
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Installed SuperMiata competition motor mounts today, 70 duro. ![]() There are only two motor mounts on the Miata, but the install took twice the time it would take me to swap all the three motor mounts on the speed6. Managed to do the driver side without taking the header off.Have not driven the car on the street yet as I finished the install late and was too tired, but at idle the license plate shakes against the bracket and makes a metallic sound. The mounts should be broken in in 500 miles or so. Noticed that I have two cracks in the front of the engine, those are some plastic covers so probably nothing major. I was also planning to swap the clutch master cylinder this weekend but Rosenthal Mazda sent me a slave by mistake so I will have to wait until next week when I get the correct part from them. Edit: I just went for a ride and OMG, the car is completely changed. The whole front feels super soild, the shifting is crisp, the license plate like crazy at idle, the engine makes new at idle, the rear view mirror vibrates a bit at 3500 rpms. Best mod so far.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 04-06-2014 at 05:25 PM. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | aggierandy (04-05-2014) |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Performed a foamectomy today. The biggest bitch was a single screw on a side of the seat, I had to use a dremel to accommodate a flat head. I only cut out the foam from the back of the bottom, did not touch the back rest. The mod dropped my position by just a tad over half an inch, I could barely see the 40 mph mark on the speedo before, now I can almost see the 60 mph mark. I also slapped the 15 x 8 UL's on the car, I think they look beautiful. I drove a bit around town and front tires would rub on aggressive sharp turns, I either need a fender roll or stiffer springs.
![]() | | #48 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score You will need a fender roll. No need for springs until you can pair them with a proper damper. I assume it's on OEM Showa, or some lack lust replacement. Why did you go with a x8 wheel? Do you really think a B6 powered, open diff'd Miata needs that much wheel/tire? I would be trying to save as much weight as possible if I were you, while still having an opportunity to find the limits and handling characteristics of the car. I ran x6.5 w/ 195/50 tires on my NA and never thought for a second I needed more tire. Let alone some that were below 300 treadwear. I would have died of boredom. Anyhow, time for a rollbar, you have a track wheel setup, might as well complete the look & make it track ready. When you learn to drive this fag-ride proper, you should have no problem getting under 2 mins @ TWS in the real racecar.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following User Says Thank You to Neverlift For This Useful Post: | Code Monkey (04-27-2014) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score I said "springs" but I will be getting coilovers of course. ![]() Power mods will come in time so why not jump straight to 15x8 given I got them used for real cheap from a fellow track junkie.
![]() | | #50 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Why not run them? Because you would benefit more now from running a tire that will actually allow you find the limits of the car. Shelf them, run something cheap, skinny, and light in the meantime until you cannot go any faster on that setup. This is the drag racer equivalent of a 400whp car that runs 13s, and thinking more power will net you 12s. It's just a suggestion, I'd be embarrassed if 1.6 open diff'd Miatas ran faster times than my racecar & would be doing what I could to correct that. Meaningful seat time.
| The Following User Says Thank You to Neverlift For This Useful Post: | Code Monkey (04-28-2014) |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is local instructor at the TWS running 2:01.90 in his 1992 Miata -- open diff, AST coils, some mild power mods and tune with the attached dyno graph. The wheels are 15x9 with 225 NT-01's. TWS -- 1.6 Miata For comparison, the best Spec Miata time is 1:58.xx.
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Went to the dyno today. I am pretty happy with the results. @EyeKon; @S-hendrix; the dyno is low enough to accommodate your car.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 05-01-2014 at 04:20 PM. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | Chief_Wiggum (03-23-2015) |
![]() | | #53 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score Nice Sent from my LG-LS980 using Tapatalk
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
| The Following User Says Thank You to Koke382 For This Useful Post: | Code Monkey (05-01-2014) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score Nice numbers, is this on stock turbo?
![]() | | #55 | ![]() |
| The Following 6 Users Say Thank You to Code Monkey For This Useful Post: | aggierandy (05-07-2014), Chief_Wiggum (03-23-2015), CorkSport (05-30-2014), Manuel (01-22-2015), Mazdazilla6 (05-02-2014), redneck4Christ (02-12-2015) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score How do you like those mounts? I'm thinking mine have left the building. Also does your car have two radios?
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Code Monkey (05-30-2014) |
![]() | | #57 | ![]() |
![]() Yeah, some weird setup the seller had, I am going to yank them both and put a blank plate in there at some point.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Mazdazilla6 (05-30-2014) |
![]() | | #58 | ![]() |
And I have a blank in mine but I want a cubby hole instead. If I buy one soon I can shoot you the blank fo free.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() | | #59 | ![]() |
![]() I may take the blank, at some point I will probably be running gauges in there but this is still far far away.
![]() | | #60 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
The Spec Miata races are always close and crazy. -Derrick | |
| The Following User Says Thank You to CorkSport For This Useful Post: | Code Monkey (05-30-2014) |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Long time no see. Parents came and went, the Flying Pig is almost done, and I can finally focus on the Miata. I got a used BossFrog double hoop roll bar with a harness bar and two 16" Kirkey intermediate seats with a 20-degree layback. The roll bar is missing some hardware and I have to wait until next weekend to finish the install. Will be ordering harnesses on Monday -- still deciding between Crow, RaceEquip, and G-Force (cannot afford Schroth or Safecraft at the moment). Also got a manual steering rack -- will be deleting the a/c system as well which will eliminate one accessory belt. Picked used Bilsteins R-pkg and talked to Shaikh at FCM. He recommended 500/400 springs, which will give me ride frequencies of 1.9/2.1 Hz. The springs will arrive with coilover springs and perches, custom bump stops (30 and 36mm), upper mounts, and spring isolators. A coilover setup on a budget. Shaikh recommended leaving the RSB stock and a Spec Miata FSB (already ordered). Will replace control arm bushings at the same time to save on alignments. With all this done, I will only have brakes left to get the Miata track ready. I should be able to drive the Miata at least once at the TWS before the track closes.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Dralphy (11-29-2014), rymanmazda (11-28-2014) |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score Realized I better remove the a/c components from inside the cabin before I bolt the seats down, so here we go, before and after. ![]() I left the heater in and Mazda has a nice kit that makes bypassing or replacing the evaporator a breeze. I also removed the condenser and the a/c lines, and used little plates to plug orifices on the a/c compressor. The compressor will be gone together with the power steering in a few weeks.
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score The roll bar is in! The thing is solid, and it is a pain in the dick to drill the holes for the rear plates. Still have to install the harness bar and then I will bug my welder about custom seat brackets and the widening of the transmission tunnel on the driver side. Sitting on the fucking floor pan with my back straight I just touch a broomstick between the top of hoop and windshield. When I lean back a little I get just 2" of clearance. The seats will have to be bolted to the floor in the back and raised a bit in front for a nice layback and roll bar clearance. Also, said fuck it and went with Schroth Profi II-6 harnesses. ![]() The soft top is out and is not going back in, the thing weights 48.2 lbs (incl. the set plate). When I get rid of the a/c compressor and the power steering, I should be at probably 70-80 lbs of weight saving total, even with the roll bar in.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 12-08-2014 at 09:43 PM. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | rymanmazda (12-07-2014) |
![]() | | #64 | ![]() |
Groans: 1,143
| Not Ranked : 0 score The rollbar has at least 10lbs on the softop. In regards to the transmission tunnel, I have always just taken a BFH (big fucking hammer) to it for installs I have done where the owner needed it. Same with the wheel well/parcel shelf behind the seats for more clearance for those above 6'. How does the 320mm steering wheel feel? I have never driven a Miata with anything smaller than 330mm. I had a 320mm that the PO installed in my MR2, and I just replaced it with a 330mm. I couldn't make quick enough counter corrections with the 320mm for some reason.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() Last edited by Neverlift; 12-08-2014 at 07:45 PM. Reason: Inserted quote, corrected my fail |
| The Following User Says Thank You to Neverlift For This Useful Post: | Code Monkey (12-08-2014) |
![]() | | #65 | ![]() |
The stock wheel is 370 mm, the one in the picture is 350 mm, I have another one that is 330 mm and it feels great, 330 is definitely the way to go, an even smaller wheel would feel weird.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Easter Bunny (12-08-2014) |
![]() | | #66 | ![]() |
![]() Join Date: Sep 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
| Not Ranked : 0 score Just saw this, jealous of those 6UL's. I have my eye on a set of used 15x9's, I need more tire (ran 205's last season). If you're still running into leg room issues, look into the momo 280mm wheel. I have one and love it, I'm 6'2" and with a 350 flat bottom my hands still hit my knee on hairpins, with the 280mm no more issues at all. It's like a go kart.
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD |
| The Following User Says Thank You to Tyhackman15 For This Useful Post: | Code Monkey (12-16-2014) |
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok, let's get the party started. Shit ordered so far and going into the car soon or already there: Code: BossFrog double hoop rollbar Kirkey seats Schroth Profi II-6 harnesses I/O Port seat back braces -- 949Racing UL 15x8 +36 205/50 Toyo RA1 (track) - TRMotorSport C1M 15x7 +30 195/50 Direzza II (street) -- AWR motor mounts IL Motorsports bushings -- manual steering rack a/c delete -- Bilstein R-pkg 500/400 7" SSS springs FCM coilover sleeves & perches FCM 30/36mm bump stops FCM upper mounts FCM spring isolators SuperMiata endlinks 24mm Spec Miata FSB -- 1.8 front brakes Sport rear brakes Wilwood proportioning valve Centric rotors Carbotech XP8 pads SuperMiata ss brake lines I had to take the cat heat shield out to narrow the transmission tunnel and knew that the cat would be sitting really close to the modified transmission wall. The fix is simply to swap the cat for a test pipe but some moron had the catalytic converter welded into the exhaust -- there are no flanges left, just the cat welded on one side to the "front exhaust pipe" and on the other to the catback. Looks like a new header and catback are in my near future. We also had to cut a bit of a leg of the roll bar for the eye bolts to go in. Fabrication will continue during the week.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Neverlift (01-18-2015) |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score Small change of plans re: suspension. I talked to Shaikh and he talked me into coilovers. I will be running his FCM Elite 3040 coilovers with 600/450 springs. Should be ready "in a month", hahahhaha. Also, got the IL Motorsports bushing today from Flyin' Miata, they are 30-40% stiffer than stock bushings. This completes my purchases with regard to suspension bits for the time being. The welder has not showed up since last time but I had the last two weekends busy, will call him tomorrow and see what's up, it would be great to finish the seats this weekend or so.
![]() | | #69 | ![]() |
(Thread Starter) | Not Ranked : 0 score Started tearing into the car today. Removed the a/c compressor and the power steering. Total weight reduction with lines, brackets, and bolts is 29.6 lbs, which puts the total at 68.7. Still have to swap the manual steering rack in and shed another pound or two. Ordered a Raceland header to fix my fucked up exhaust and once it arrives Tuesday I will see what to do about the catback part. Will probably stick to a 2.25" exhaust with a resonated test pipe. My welder finally texted me that his welder was broken, but he should have one by next weekend and we can finish installing the seats, sigh....
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cleaned up the area around and under the engine and pulled the remainder of the exhaust. Yep, this long turd is one piece thanks to a welded in cat.
![]() | | #71 | ![]() |
(Thread Starter) | Not Ranked : 0 score Because two dicks in the mouth are better than one....
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #72 | ![]() |
![]() Join Date: Feb 2014 Location: PHX, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I heartily approve of the color choice. Plans for the second miata?
__________________ 2006 Liquid Platinum Metallic MS6 Sport 71 Nova LSx/T56 |
| The Following User Says Thank You to hookemdevils22 For This Useful Post: | Code Monkey (02-25-2015) |
![]() | | #73 | ![]() |
![]() Meanwhile, I got my FCM coilovers for the red Miata, spring rates are 600/450. My initial plan was to buy a "coilover kit" from Shaikh -- upper mount kit, custom bump stops, coilover sleeves, spring perches, and springs (500/400). I paid for the kit on October 15 and have not heard anything for a while. I contacted Shaikh on January 28 and he "forgot" about my order. But he is a smooth talker and talked me into going a coilover route (at a discount) with a promise that if sent him my shocks for a revalve, he would finish my setup in 2 weeks (ha!). He got the shocks on February 4th and I just got the coilovers back, February 25, not bad for Shaikh! Now I have everything I need suspension-wise to tear into the Miata, just waiting for a warmer weather. Yesterday I bought a 20-ton press from Harbor Freight for control arm bushings, @phate; oh hai! I also got a testpipe today, which completes my exhaust setup: Raceland header, Enthuza test pipe, and Cobalt catback! Oh, and I have no idea why Miata owners tend to have so many spare keys. The red Miata came with eight keys, this one with six.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 02-25-2015 at 05:08 PM. | |
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (02-25-2015), phate (02-25-2015) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Warmer weather? Fuck you in your Texas ass.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Code Monkey (02-25-2015) |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^ Hopefully that's not an empty promise.
![]() | | #76 | ![]() |
| Not Ranked : 0 score It's as empty as you will feel after I pull out.
![]() | | #77 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Pulling out? About the most Anti-American thing you could do.... after all, we never pulled out of Afghanistan.
| The Following User Says Thank You to Neverlift For This Useful Post: | Code Monkey (03-03-2015) |
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the manual steering rack in and the Raceland header. Had to extend the o2 sensor, used posi-tabs and wrapped the wire in self vulcanizing tape and then cool tape.
![]() | | #79 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the passenger side suspension bushings pressed in and out last week and started putting everything back together on that side. Installed rear brakes from a 1.8 "Sport" Miata (2001-2005), the rear rotors are 10.9" compared to 1.6's 9.1". This mod required hacking up the heat shield. In the front, I am about to install brakes from a regular 1.8 Miata, the rotors are 10" compared to 1.6's 9.25". Fat Cats on all corners, spec Miata FSB, new eccentric bolts, new ss brake lines. Will install the proportioning valve next week. Also finished the exhaust, I have a Raceland header, Enthuza 2.25" test pipe, and 2.25" Cobalt cat back with a stupid big exit. Obviously cannot drive the car at the moment, let it idle for a bit and revved the shit out of it a few times, the sound is nice, not too loud, and there is a shitload of smoke every time I let off gas. Also washed the yellow Miata and rinsed off the Flying Pig, shit was getting dirty (pollen season).
| The Following User Says Thank You to Code Monkey For This Useful Post: | Chief_Wiggum (03-30-2015) |
![]() | | #80 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lookie what I picked up today. ![]()
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | dale_gribble (04-02-2015), MBalik (04-02-2015) |
| Got raped by this... | Neuspeed | Mazdaspeed3/6 General Discussion | 33 | 05-15-2011 09:19 AM |
| I got raped... | BudUMfan | Street Racing Stories ( Bench Racing ) | 13 | 04-10-2011 10:19 PM |
| Got raped by a Charger SRT-8 | OMGWTFHAX | Street Racing Stories ( Bench Racing ) | 67 | 02-07-2009 10:42 AM |
