![]() | | #81 | ![]() |
![]() Join Date: Nov 2011 Location: Crowley, TX
| Not Ranked : 0 score |
| The Following User Says Thank You to redneck4Christ For This Useful Post: | Code Monkey (04-03-2015) |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Looks like a bedroom. Carpet was a dead give away. ![]() +1 to increasing chassis rigidity.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following 2 Users Say Thank You to Neverlift For This Useful Post: | Code Monkey (04-03-2015), redneck4Christ (04-03-2015) |
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, that's the guest bedroom.
| The Following User Says Thank You to Code Monkey For This Useful Post: | redneck4Christ (04-03-2015) |
![]() | | #84 | ![]() |
![]() Join Date: Nov 2011 Location: Montreal,QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score Bed sheets meet the HT color almost perfectly
__________________ 2007 Mazdaspeed 6 - CP-E CAI, CS Internals, Cobb AP (Custom 91 tune, 19psi), Test pipe, JBR RMM, Sure Juggernaught, H&R Coilovers, JBR SSP & Bushings, 17x8 w/235-45-17 tires (Hankook RS-3), Hawk HP+ pads all around, DBA 4000 discs, |
| The Following User Says Thank You to SpICeZ For This Useful Post: | Code Monkey (04-03-2015) |
![]() | | #85 | ![]() |
| Not Ranked : 0 score i thought you had taken it in there to make love to the hard top
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Code Monkey (04-03-2015) |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for an idea, I can be a little spoon.
![]() | | #87 | ![]() |
(Thread Starter) | Not Ranked : 0 score Getting close to being back on the road. Today, I did the suspension on the driver side, and finished the brakes on all 4 corners including bleeding. ![]() The only thing left is end links and then I am ready to roll the car and tighten up all the bushings under load. No idea if I will have time to do it tomorrow, if not Monday or Tuesday should be fine.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (04-05-2015), Neverlift (04-05-2015) |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score All right, the car is finally on all 4 wheels. I already rolled it back and forth and pushed down hard a few times on each corner; it is gonna chill overnight like that, then another set of rolls and pushes, then set the ride heights, and finally under the car to tighten everything up and do the end links. I am gonna bed in the brakes and then put about 50 miles on the car and then re-check all the bolts and go for an alignment.After that, back to the shop to weld the hole in the transmission tunnel and mount the seats and harnesses. ![]() Oh yeah, and I will be able to finally clean up the fucking garage, just looking at it makes me positively sick.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (04-06-2015), Neverlift (04-08-2015) |
![]() | | #89 | ![]() |
| Not Ranked : 0 score I know the feeling. My wife's NB has been torn apart and taking up the garage since November. And all I'm doing is a head gasket and going back together stock. |
| The Following 2 Users Say Thank You to redneck4Christ For This Useful Post: | Code Monkey (04-06-2015), Easter Bunny (04-06-2015) |
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, I am a little bit nervous, the car should be completely transformed handling-wise. Hopefully there are no brake fluid leaks.
![]() | | #91 | ![]() |
(Thread Starter) | Not Ranked : 0 score And she is alive, muahahahaha!!!! ![]() Test drive #1 lasted only 30 seconds as there was a horrible rattle from rear exhaust hitting the left axle, I went back to an old rubber hanger on the muffler so it was not pulling the connecting pipe as high and the rattle was gone. Test drive #2 lasted probably around 30 minutes and all went smoothly. Manual steering is a blast, the feedback is incredible -- combined with no alignment, one corded tire, no parking brake, no seatbelts, a mocked up seat, a heat shield stuffed between the seat and the hole in the transmission tunnel, made it an unforgettable drive. Some uneven roads were super sketchy, and after about 15 minutes my seat started heating up from the exhaust, by the time I got back home the seat was quite toasty. ![]() I am taking the car to the shop tomorrow to have the transmission tunnel welded and should be taking the car to the track in May. ![]() Some fun pictures: "This should stop exhaust heat from entering the cabin" Note how the seat is bolted to the floor, there are two bolts total for now."Racecar or not, my ass must be comfy" ![]() "Yes officer, I was wearing the seatbelt" ![]()
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 04-06-2015 at 06:38 PM. |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score I adjusted the ride height and holy shit, what a difference!!!! I measured center of the hub up to the fender lip and aimed at the following: Code: 12.25" 12.00" 12.75" 12.50" I think I dropped the car about 2" compared to the previous post. The car sits pretty low and there is no way I can sneak the jack in the front, I will have to use plates or ramps.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Chief_Wiggum (04-09-2015), Neverlift (04-08-2015) |
![]() | | #93 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Since all Miatas run 15s, ground to pinch weld would be the only measurement I can relate to lol. I believe Harbor Freight has a low profile jack (3 ton) that should get under there... that's what I used when I was 4.25"F, 4.5"R ground to pinch weld. I still have it, it even worked on my full size 4wd truck (2.5 tons) when I was checking wheel bearings.
| The Following 2 Users Say Thank You to Neverlift For This Useful Post: | Chief_Wiggum (04-09-2015), Code Monkey (04-08-2015) |
![]() | | #94 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, I will be looking for another jack, right now I have an aluminum racing jack from HF, I think it might be a low profile one, but obviously not the lowest it can be....
| The Following User Says Thank You to Code Monkey For This Useful Post: | Neverlift (04-09-2015) |
![]() | | #95 | ![]() |
![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 569
[IMG] [IMG]
__________________ 2008 MGM MS3 GT -- Prone to acts of jackassery Last edited by Chief_Wiggum; 04-09-2015 at 02:30 PM. | |
| The Following 3 Users Say Thank You to Chief_Wiggum For This Useful Post: |
![]() | | #96 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the car back from the shop with the transmission tunnel welded and the seat mounted, shit looks tits. ![]() Now onto mounting the seat back brace and harnesses.
![]() | | #97 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score I just got the same jack a few months ago...I still have to drive the vette up on to wood blocks to get under the car, but it's better than the whole ordeal I had to do previously. |
| The Following 2 Users Say Thank You to aaronc7 For This Useful Post: | Chief_Wiggum (04-10-2015), Code Monkey (04-10-2015) |
![]() | | #98 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score I just slide my crotch underneath and think of MSF.. instant 3 inch lift.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| The Following 2 Users Say Thank You to MSP6 For This Useful Post: | Code Monkey (04-10-2015), rymanmazda (04-11-2015) |
![]() | | #99 | ![]() |
(Thread Starter) | Not Ranked : 0 score Finally installed a seat back brace, the fitment is tight, pain in the ass. Later this week I will tackle the harness, and after that get an alignment and hit the track. ![]() Also rolled the front fenders and raised the front maybe an 1/8".
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #100 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the harness in, now alignment on Tuesday, then slap on the hard top, and I am ready to roll. ![]() The helmet does not clear the roll bar -- I think once the padding is a bit worn down and squished and I am strapped in, it should be pretty close. But there is no fucking way I will have a slightest of clearance, lol.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (04-19-2015), redneck4Christ (04-18-2015) |
![]() | | #101 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got an alignment so the steering wheel is finally straight. ![]() I was planning to go with the recommended 949Racing dual duty alignment (-2.0/-1.7 camber, 0 toe) but because the car is sitting low, the minimum camber in the rear the shop could do was -2.4 so I ended up going -2.7/-2.4. The car is chilling overnight on makeshift boxes, tomorrow I will crawl under and tighten the remaining suspension bolts, install the end links, put the skid tray back on, and I am ready to rock. ![]() Hard top will be bolted on whenever the mounts arrive, hopefully by the weekend. I have five road racing days left at the Texas World Speedway and hope to drive the Miata two of those days.
| The Following User Says Thank You to Code Monkey For This Useful Post: | redneck4Christ (04-22-2015) |
![]() | | #102 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Ugh, that alignment sucks. Sincerely, Me
| The Following 2 Users Say Thank You to Neverlift For This Useful Post: | Code Monkey (04-22-2015), Easter Bunny (04-22-2015) |
![]() | | #103 | ![]() |
(Thread Starter) | Not Ranked : 0 score Camber is right between 949Racing's dual duty and race specs.
![]() | | #104 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Why is the caster so low?
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score Close enough to 4, I will not cry over that. With a 350mm steering wheel I have no troubles turning the wheels. Will most likely get a second alignment after a track day so do not consider this final numbers.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Neverlift (04-22-2015), redneck4Christ (04-22-2015) |
![]() | | #106 | ![]() |
(Thread Starter) | Not Ranked : 0 score Buttoned up everything today and took her for a first drive with a hard top. ![]() Here's some pictures. There is less than a finger width between the roll hoop and the hardtop, everything fits perfectly. I was able to keep most of the interior trim. The parking brake is working too. I need to bleed the brakes and the clutch and we both should be ready for next Saturday.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Neverlift (04-25-2015) |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok, so I checked my pinch weld height. Per 949Racing, "Take measurement from forward most and rearmost straight area of lower unit body pinch weld at it's lowermost edge." So I guess this would be at the blue line here (not my Miata): Here is how my car is sitting. This is approximately 4": Front left: Rear left: Front right: Rear right: This is with no driver in the car, so when I put my fat ass in, front left will come down a bit to hopefully match front right. No idea if this is a tad too low, 949Racing recommends 3.75"-4.5" in front for their race alignment (and about .25" higher in the rear). The car feels fine and I do not scrape anything driving around town, I think I will not worry about it and just go and have fun.
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took the Miata to the track, details, including a video, here.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Neverlift (05-04-2015) |
![]() | | #109 | ![]() |
(Thread Starter) | Not Ranked : 0 score Dynoed the Miata today. The only "power" mod is the exhaust system: Raceland header, 2.25" test pipe, 2.25" Cobalt exhaust. Still on the stock intake and stock ECU. Previous dyno (stock car) is here, the best run was 98.5 whp / 96.9 wtq. Today the best run was 103.9 whp / 101.9 wtq, trolololol. The AFR goes pig rich in the upper rpms, to about 10.5, in a couple months I will be paging @Lex; for a Megasquirt, if I target 12 AFR or so at WOT, I may get closer to 110/110.
![]() | | #110 | ![]() |
(Thread Starter) | Not Ranked : 0 score Drove to Dallas today to pick up a spare long block -- $200, 177k, brand new OEM clutch, new water pump and timing belt. No valve cover, but I ordered it separately for $70 shipped. I need to replace the crank seal and need to source cam gears and I should have a whole spare engine. But why not build it first, right? ![]() The little shit is pretty heavy, carrying it from the truck to the garage was not that bad, but lowering it onto the tire was a bitch, it sucks getting old and weak. Now I need an engine stand.The F-350 averaged 14.125 mpg, ouch.
![]() | | #111 | ![]() |
![]() Join Date: Jun 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Now that's a lot of hard work.. |
![]() | | #112 | ![]() |
(Thread Starter) | Not Ranked : 0 score Put 10th anniversary rims on the yellow Miata, pimptastic! And that wheel gap compared to the red one!
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Chief_Wiggum (08-18-2015), Tyhackman15 (07-10-2015) |
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score Finally installed the passenger seat. This side did not require cutting the transmission tunnel so the install was more straightforward. I had my shop fab the front brackets and did the rest myself. Tomorrow I will reinstall the interior trim and the car is good to go.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Neverlift (08-13-2015), redneck4Christ (08-17-2015) |
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the Miata on the track again. Previous best lap was 2:10.931. Today I hit a 2.08.595 and had many 2:09 laps. ![]() I think this is the best I can do on this setup, IIRC, most spec Miatas run consistent 2:06-2:07's so I am not complaining. I need a few more hp to keep up with them. New crate 1.6 motors put down about 111 hp, I think, mine dynoed 103. Overcooked the tires last session, spun, and hit the curbing pretty bad, bent front passenger rim, surprisingly the tire is still holding air, I still need to crawl underneath the car and assess damage, but it drove straight on my way home, so hopefully I just need a new rim. Edit: Yep, just a new rim.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 08-16-2015 at 06:46 PM. |
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (08-20-2015), Neverlift (08-17-2015), redneck4Christ (08-17-2015), Tyhackman15 (08-16-2015) |
![]() | | #115 | ![]() |
Groans: 1,143
| Not Ranked : 0 score That's a wheel, but imma let you have a pass on this one.... Why do you not heel toe?
| The Following 2 Users Say Thank You to Neverlift For This Useful Post: | Code Monkey (08-17-2015), Easter Bunny (08-20-2015) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score wheel may be repairable
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not worth it. It is cheap made in China shit. I already got a used one for $70 and ordered a new one for $120 so I will have a spare for future misadventures.
![]() | | #118 | ![]() |
| Not Ranked : 0 score I would still spend 50 to fix it and have another spare.
![]() | | #119 | ![]() |
Groans: 1,143
![]() | | #120 | ![]() |
(Thread Starter) | Not Ranked : 0 score I rev match in my speed6 so I naturally do it in the Miata.
| Got raped by this... | Neuspeed | Mazdaspeed3/6 General Discussion | 33 | 05-15-2011 09:19 AM |
| I got raped... | BudUMfan | Street Racing Stories ( Bench Racing ) | 13 | 04-10-2011 10:19 PM |
| Got raped by a Charger SRT-8 | OMGWTFHAX | Street Racing Stories ( Bench Racing ) | 67 | 02-07-2009 10:42 AM |
