Miata MX-5
> Miata - General Questions
 Old 04-16-2019, 05:15 AM   #1
HenryBraxton's Avatar
Posts: 1   (View Stats)
HenryBraxton is an unknown quantity at this point
Default Help needed, mk1 mx5 clutch engagement
Hello, bit of an emergency here. Currently in Germany with a mk1 eunos (we're from the UK, visiting the nurburgring). The clutch is engaging at the floor, and is intermittently failing to disengage even with your foot right into the firewall. I've had a slave cylinder go before and was convinced this was the issue. Took it to a garage who speak no English and they have replaced both the slave and the master cylinder.
The clutch is still broken. We have some tools with us and we're going to try bleeding it ourselves but I can't see that a garage could fail to bleed it properly. Failing that we're giving up and going home, having only done a lap each, which is a bit of a bummer.
Any thoughts for stuff to check that's a relatively simple fix? We're handy enough to bodge something if we have to.https://solitaire.onl/ https://9apps.ooo https://bluestacks.vip/
HenryBraxton is offline   Reply With Quote
 Old 04-16-2019, 06:11 AM   #2
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
You might want to post on a Miata forum which is the U.S. name for the MX5
Anywho it does sound like either the slave isnt extending all the way or the master isnt pushing enough fluid. Bleed the whole thing again. If bleeding doesnt help check that the parts they exchanged are the correct ones. If none of that helps sorry but you'll need to drop the tranny to check the clutch.
 Old 04-26-2019, 06:14 PM   #3
ThorOtheBIG's Avatar
Posts: 56   (View Stats)
ThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura about
This started happening while you were on a track?
Definitely too late for this, but:
Bent throwout fork?
Throwout bearing no longer staying connected to fork?
ThorOtheBIG is offline   Reply With Quote
 Old 04-28-2019, 06:16 AM   #4
RazerX's Avatar
Posts: 9   (View Stats)
RazerX has a little shameless behaviour in the past
sad story bro.... if u will need a clutch plate in future, I can advise you a good source with good prices, but in another country, so u will need to wait.
RazerX is offline   Reply With Quote
 Old 05-10-2019, 06:24 PM   #5
seoking's Avatar
seoking is an unknown quantity at this point
9Apps Cartoon HD Vidmate
The master can be notoriously hard to bleed on these cars, so I'd check that and see if you can get a good bleed on it. Also, maybe check the flex line that runs down to the slave? Sometimes they can bulge or leak and not give you enough movement on your clutch fork.
seoking is offline   Reply With Quote
Harsh Clutch Engagement BrandonM MazdaSpeed 6 - Engine, Transmission & Driveline 9 02-23-2017 07:05 PM
Clutch pedal engagement changes every drive Absolut1l MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 09-17-2015 07:47 PM
Clutch Pedal Engagement radioflyer MazdaSpeed 3 - Engine, Transmission & Driveline 26 01-24-2015 01:02 PM
Clutch engagement point? Dat8687 2010 MS3 - Engine, Transmission & Driveline 20 12-02-2013 09:03 PM
Raising the Engagement Point on my Clutch riott MazdaSpeed 3 - Engine, Transmission & Driveline 30 02-15-2011 07:56 AM
Page generated in 0.25944 seconds with 24 queries
