![]() | | #321 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
![]() | | #322 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
(Thread Starter) | Not Ranked : 0 score Smooth is fast!
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #323 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lesson Learned. Rival-S tires must be treated like race tires. Parked the miata for 2 weeks and they took the epoxy coating off of my floor.
| The Following 9 Users Say Thank You to Ziggo For This Useful Post: | aaronc7 (06-18-2016), Code Monkey (06-15-2016), Crarrs (06-15-2016), MS3Shadow (06-15-2016), Neverlift (06-15-2016), Nliiitend1 (06-15-2016), Pu Manchu (06-19-2016), redneck4Christ (06-15-2016), Tomas (09-18-2016) |
![]() | | #324 | ![]() |
![]() Join Date: Nov 2011 Location: Crowley, TX
| Not Ranked : 0 score Daaaang! |
![]() | | #325 | ![]() |
(Thread Starter) | Not Ranked : 0 score Its so stinking hot. Got out and ran this past weekend. Didn't place as well as I have in the past, placing 5th. I usually pick up time with each of my runs, but the tires got overheated and I just couldn't improve with my last two runs. Need to be able to run better times with fewer runs. https://youtu.be/gQdWyg4dbjk
| The Following User Says Thank You to Ziggo For This Useful Post: | Code Monkey (07-18-2016) |
![]() | | #326 | ![]() |
(Thread Starter) | Not Ranked : 0 score Like I said, last run got a bit slippery.
![]() | | #327 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score I gotta read this... just picked up a 90 miata with a 93 motor, I need to clean my lifters and do Rotella swap with a good filter. Also are u tuned with tht header? How loud is the car with tht header? Sent from my SM-G930V using Tapatalk
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #328 | ![]() |
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by MS3Shadow; 07-24-2016 at 07:20 PM. |
| The Following User Says Thank You to Ziggo For This Useful Post: | Code Monkey (07-25-2016) |
![]() | | #329 | ![]() |
(Thread Starter) | Not Ranked : 0 score Another event in the books, finished 5th in T class, but was really not a good performance. I could never find time on this course, and I was pretty far off pace from the fast folks. Lots of off camber stuff and mid turn bumps. Picked up a full face SA2015 helmet in prep for doing track stuff as my 2005 helmet is out of date. I also picked up this bad boy on the cheap in prep for doing more track work. Can take a better selection of repair tools and if I cord a tire I wont be stuck driving home on it. Can also transport purple crack to and from events if I decide to start the addiction next season.
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | Code Monkey (08-22-2016), Crarrs (08-22-2016), Mauro_Penguin (09-06-2016), Pu Manchu (08-22-2016), redneck4Christ (08-22-2016) |
![]() | | #330 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score I like that trailer |
| The Following 3 Users Say Thank You to aaronc7 For This Useful Post: |
![]() | | #331 | ![]() |
(Thread Starter) | Not Ranked : 0 score Getting better at this nonsense: Full speed Slide 1/4 speed Slide Trailer worked well. Excited to stop wasting heat cycles on the tires. I am still struggling to find time. I know I should be faster, but I am just not. Got 3rd in T class this time, but thats because there were only 4 entries.
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | Cheapspeed (09-04-2016), Code Monkey (09-04-2016), Mauro_Penguin (09-06-2016), Nliiitend1 (09-07-2016), Pu Manchu (09-05-2016), redneck4Christ (09-05-2016) |
![]() | | #332 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
__________________ 3rd rebuild on the way...maybe... | |
![]() | | #333 | ![]() |
![]() Join Date: Jul 2016 Location: Arroyo Grande, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 27 Times in 10 Posts
| Not Ranked : 0 score Looks like a fun project car. You should contact the Miata Club. The have thousands of members. They could be a good resource.
__________________ Mazdaspeedchris |
![]() | | #334 | ![]() |
Groans: 370
| Not Ranked : 0 score "the miata club" |
![]() | | #335 | ![]() |
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #336 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh yes.
| The Following 3 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #337 | ![]() |
| Not Ranked : 0 score Oh My. At least it is better than the guy that had green apples on one door panel and plaid on the other. and the dash. and the hood and front fenders... |
![]() | | #338 | ![]() |
| Not Ranked : 0 score Do all miata drivers go off the deep end?
| The Following 6 Users Say Thank You to Cheapspeed For This Useful Post: | Code Monkey (09-06-2016), Mauro_Penguin (10-13-2016), MS3Shadow (09-06-2016), Nliiitend1 (09-07-2016), redneck4Christ (09-06-2016), Ziggo (09-06-2016) |
![]() | | #339 | ![]() |
| Not Ranked : 0 score |
![]() | | #340 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm just getting started, I can put a pirate flag in the useless antenna hole in the trunk and maybe a giant skull and crossbones stenciled on the hood? If I get really crazy I could make a figurehead where the nose emblem goes and put some cannon ports on the sides!
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Cheapspeed (09-06-2016), Mauro_Penguin (10-13-2016) |
![]() | | #341 | ![]() |
| Not Ranked : 0 score Will you wear an eye patch while driving?
![]() | | #342 | ![]() |
(Thread Starter) | Not Ranked : 0 score A little bit more semi-functional bling. I'm sealing up the radiator area so the hood latch needed to go and added the vents too. After dealing with heat issues on the 3, I don't want to have to worry about it on this thing. I sized up the undertray parts and got them squared away and they are off to be anodized right now. Both of the mount holes on the passenger side for the side of the tray have sheared off bolts in them, nice and rusty, so that will be fun to deal with. Will break out the left handed drill bits and hope that takes care of it.
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | aaronc7 (09-12-2016), Code Monkey (09-12-2016), Mauro_Penguin (10-13-2016), Nliiitend1 (09-15-2016), redneck4Christ (09-13-2016), WetzMS3 (10-11-2016) |
![]() | | #343 | ![]() |
(Thread Starter) | Not Ranked : 0 score Best run in the afternoon @ 57.285 which was more than a second faster than my morning run after disconnecting the rear swaybar for the afternoon runs. So much more rear grip really lets me swing the car around which confidence and get on the throttle much earlier. The car is slower to transition meaning I need to make my inputs earlier, but I am very satisfied with the change. My last run I spun just before where I slide a bit in this video, I was just trying to push it to see where the limits are. I'll get faster as I get used to having ALL THE GRIP. The car will still rotate just fine on throttle lift, but now it will hook up on exit and understeer if the weight is balanced rearward, which actually lets me steer with the throttle.
| The Following 7 Users Say Thank You to Ziggo For This Useful Post: | aaronc7 (09-18-2016), Cheapspeed (09-17-2016), Code Monkey (09-18-2016), Mauro_Penguin (10-13-2016), Nliiitend1 (09-18-2016), Pu Manchu (09-19-2016), WetzMS3 (10-11-2016) |
![]() | | #344 | ![]() |
| Not Ranked : 0 score Is this fucking pirate tramp faster than your MS3 yet? The rivals - did not like them at all when I ran 24 hrs at VIR on a Miata. Just can't handle any heat at all. I'd go RS3s over those shits hands down.
__________________ |
| The Following 4 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #345 | ![]() |
(Thread Starter) | Not Ranked : 0 score With no boost I'll never run faster lap times in the Miata than the speed, you just can't overcome being down by 200hp, but on the fun scale its tilted way towards the miater. The rivals would probably be one lap wonders on the track. I spray them down after each auto-x run, but they are worth a full second over the hankooks on a 60 second auto-x run. I'm kinda conflicted about my next set of tires. What I want are some 245 A7s, but that pricetag. If I will be doing more track I will probably go with the maxxis VR1s, more auto-x would be another set of rivals Sent from my SAMSUNG-SM-N910A using Tapatalk
| The Following User Says Thank You to Ziggo For This Useful Post: | Neverlift (09-19-2016) |
![]() | | #346 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looks like the miata is getting DD status for a bit while I sort this mess out.....
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Code Monkey (10-11-2016), WetzMS3 (10-11-2016) |
![]() | | #347 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score BC quality at it's finest! ![]()
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club Last edited by Nliiitend1; 10-11-2016 at 10:32 AM. Reason: . |
| The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post: |
![]() | | #348 | ![]() |
![]() | | #349 | ![]() |
(Thread Starter) | Not Ranked : 0 score ![]() I can be racecar now? Sent from my SAMSUNG-SM-N910A using Tapatalk
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | aaronc7 (02-22-2017), Code Monkey (02-22-2017), Neverlift (02-22-2017), Pu Manchu (02-23-2017), redneck4Christ (02-24-2017) |
![]() | | #350 | ![]() |
![]() Join Date: Jun 2014 Location: SoCal-Hesperia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score haha like the stickers on the windshibby
__________________ 2012 Mazdaspeed3- // Cobb SRI // CNT 3" Stainless Catback // Cobb Air box // Cobb AP // Autotech HPFP Internals // Cobb RMM // Eibach Lowering Springs // Cobb Shift Weight // Cobb Exhaust Hangers // Cork Sport TMIC // CorkSport F/R Brake Pads // SS Brake lines // SURE TIP (I know... its junk) // CorkSport CF Hood Scoop // Cobb Catted Downpipe // One Resonator Delete // JBR Rear Sway Bar // Track Wheels & Tires // 17x7.5 +45 Offset Sparco Assetto Gara Rims // 225/45ZR-17 BFGoodrich G-Force Rival Tires // |
| Ziggo's Miata of the Day | Ziggo | Miata - Track Cars and Racing | 112 | 07-12-2014 04:12 PM |
| Ziggo's Boost Tuning Thread | Ziggo | MazdaSpeed 3/6 - ECU Computer Tuning | 192 | 07-06-2011 01:08 PM |
