Mazdaspeed Forums
-   ERZPerformance (http://www.mazdaspeedforum.org/forum/forum/f517/)
-   -   07-09 Mazdaspeed3 Performance Brake Pads Posi Quiet, Hawk (http://www.mazdaspeedforum.org/forum/forum/f517/07-09-mazdaspeed3-performance-brake-pads-posi-84004/)
ERZperformance 06-21-2011 09:42 PM
Posi Quiet
Posi Quiet pads are a great budget minded replacement because they manufactured using the same positive molding process utilized by OEM manufacturers. This process assures consistent friction material density throughout the pad, resulting in even wear and performance characteristics throughout the life of the brake pad. Posi Quiet pads feature precision cut backing plates and mechanically attached shims, small details that ensure proper fitment in the caliper and virtually eliminate noise associated with pad vibration.
An additional scorching process forces any impurities out of the friction material and pre-burnishes the pads to speed up the pad break-in process.
http://www.jscspeed.com/images/catal...5081_thumb.jpg
Front Pads part number 104.09152 = 40.00 plus shipping
Rear Pads part number 104.10950 = 37.00 plus shipping
StopTech Performance
StopTech now offers the same pads that they include with their balanced big brake upgrades as OEM replacement pads for your stock calipers. StopTech Performance pads are a great option for those that are looking for a good all around street pad that may see limited track time. Designed with a higher heat tolerance and temperature range, the StopTech Performance pads will out perform most other OEM quality pads on the street or track.
StopTech Performance pads are designed to be used on the street with very limited track use.
FITMENT:
Mazdaspeed3 2007-2009
http://www.jscspeed.com/images/catal...5087_thumb.jpg
Rear Pads Part number 309.10950 = 49.00 plus shipping
Hawk Performance Ceramic
Hawk Performance Ceramic brake pads were developed for those enthusiasts who want to improve stopping power without the annoying side effects sometimes associated with more aggressive pads. Hawk Performance Ceramic pads are engineered with a linear friction profile for maximum performance while reducing NVH (noise, vibration, and harshness) for a smoother ride and ultra-low brake dust accumulation. In addition, you can expect Hawk ceramic brake pads to provide increased pad and rotor life and a more responsive ABS braking system. Hawk Performance Ceramic pads are intended for street use only
FITMENT:
http://www.jscspeed.com/images/catal...5084_thumb.jpg
Front Pads Part number HB549Z.702 = 75 plus shipping
Rear Pads Part number HB571Z.605 = 60.00 plus shipping
Page generated in 0.16702 seconds with 11 queries
