> ERZPerformance
ERZPerformance ERZperformance specializes in import performance parts. Since 2003, we offer the best customer service and the lowest price. We are the authorized dealer for Cobb, Greddy, HKS, Tanabe, and more
 Old 02-22-2011, 07:45 PM   #1
ERZperformance's Avatar
Posts: 589   (View Stats)
ERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the worldERZperformance is the leader of the world
Groaned at 18 Times in 18 Posts
Default Cobb Accessport , BOV, Intake,
Cobb Accessport , BOV, Intake, ( Ca resident please add 10.25 sales tax to all orders)
Please pm or call if you have questions.
Accessport , Intake, Downpipe, BOV
POWER. FLEXIBILITY. CONTROL. The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications.
Tuning flexibility ranges from simply loading one of the included performance maps designed for common modifications, all the way to complete custom map authoring using our powerful AccessTUNER software. Extract maximum power from virtually any modification while retaining the driveability and sophistication inherent in the OEM ECU.
Netting a + 11 HP and + 16 lb. ft. gain, the C.A.R.B. certified COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains!
The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems.
COBB Tuning announces the immediate availability of the COBB Turbo Inlet Hose for the MazdaSpeed 3. This sleek, high temperature silicone hose replaces the clunky plastic OEM piece. The interior features a uniform lining and incorporates a true taper design, eliminating any sudden neck-down in diameter found on lesser designs. The end result is a smooth, unrestricted path from the intake to the turbo inlet, adding power and improving engine responsiveness.
The COBB XLE BPV is a compact and lightweight by-pass valve that is capable of holding very high boost pressure without leaking. Its unique design allows for extremely fast venting of boost when actuated. It is designed to operate in multiple venting modes and can be quickly reconfigured using simple hand tools. Innovative engineering and precision manufacturing result in a compact package able to fit in the confines of a tight engine bay.
COBB Tuning has outdone itself with the COBB 3” Downpipe for the 2010+ MAZDASPEED3,which is a study in engineering design and artistic execution. The COBB 3” Downpipe replaces a very restrictive element in the Mazdaspeed3 exhaust system. Considerable effort was spent designing a flow path with the fewest number of direction changes and minimal degrees of bend in order to eliminate restrictions. This beautifully fabricated downpipe delivers significantly improved exhaust flow, resulting in faster turbo response time and power gains across the entire rev range, while still protecting the environment with its highly efficient custom catalytic converter.
ERZ Performance
1680 west winton ave 3
Hayward CA 94545
800-363-8599
Best regards
Thomas
http://www.erzperformance.com
http://www.cntracing.com
Become our facebook fan
ERZperformance is offline   Reply With Quote
 Old 05-06-2011, 09:22 PM   #2
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
Got my Accessport today from ERZ. Thomas replies faster to PM's than most and the unit got here in one day. Thanks man!
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
 Old 05-06-2011, 10:19 PM   #3
Yes sir free overnight shipping from us.
ERZ Performance
Hayward CA 94545
800-363-8599
Best regards
Thomas
 Old 05-20-2011, 05:25 PM   #4
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Ordered my AP late Wed night. Shipped out Thu and received it early Fri. This guy is legit. Will definitely do business with again I hope.
Thanks for the great service and best price on AP ANYWHERE!
 Old 05-20-2011, 05:34 PM   #5
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
how much for a cobb bpv?
 Old 05-21-2011, 03:13 PM   #6
You got PM
ERZ Performance
Hayward CA 94545
800-363-8599
Best regards
Thomas
 Old 05-22-2011, 11:53 PM   #7
Thanks for all the order guys.
ERZ Performance
Hayward CA 94545
800-363-8599
Best regards
Thomas
 Old 04-10-2012, 01:35 PM   #8
yomyster67's Avatar
Posts: 262   (View Stats)
yomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond repute
I'm looking for an accessport but can't send you a pm yet (not enough posts).
can you pm me?
thanks.
yomyster67 is offline   Reply With Quote
 Old 09-27-2012, 02:52 PM   #9
saranya's Avatar
Posts: 34   (View Stats)
saranya will become famous soon enough
interested in the cobb bpv, anything tempting? thanks.
2008.5 Crystal White Speed3
saranya is offline   Reply With Quote
 Old 10-18-2012, 02:12 PM   #10
nicobush's Avatar
Posts: 9   (View Stats)
nicobush is just really nicenicobush is just really nicenicobush is just really nicenicobush is just really nicenicobush is just really nice
Discussion with ERZ for a GFB Blow off.
I thank ERZ for his patience.
Because French which speaks English, that must not be easy to read.
Mazda 3 MPS Gen 2 2010 : Black windows - Team Dynamics Pro Race 1.2 Black 8x18 - Black custom paint - Test Pipe OBX Racing- Intern pump autotech - TMIC Corksport - Remap by njaka - Denso ITV22 - Corksport Motor Mount Insert - EGR Block - Solid Shift JBR- Short Shift Damond Motorsport - SRI Corksport Short stage I - Custom CAB Corksport - Turbo inlet HTP 2.5" - BOV Go Fast Bits TMS Respons - Catadioptre LED Corksport - Bypass Valve Silicone Corksport - Banjo Bolt - Mud flap - Front up bar Ultra Racing - Redline tuning hood gaz springs - Draw tite Trailer Hitches - Triple pillar pod and Prosport gauges - Scangauge - 30 % VTA dump map.
nicobush is offline   Reply With Quote
Page generated in 0.30972 seconds with 26 queries
