> CX-7 > Issues & Troubleshooting
 Old 01-25-2018, 01:07 AM   #1
dynoiasi's Avatar
Posts: 2   (View Stats)
dynoiasi is an unknown quantity at this point
Default Cannot turn off alarm
Hello,
I have a strange problem regarding the alarm system in my Mazda CX-7 2008, EU version, keyless entry (card type).
At the moment I am not going to focus on why the alarm sometimes goes off when I normally unlock the car via the keyless entry button on the door, while having the entry card with me. This happened a few times, not often, and I have yet to find a pattern when this false trigger occurs.
My biggest problem, which is also strange, is that once triggered in this way I cannot stop the alarm from sounding. I can start the engine, either with or without the mechanical key, I can lock/unlock normally the car via the remote, I tried all sorts of things and the key is definitely correctly recognized, everything works ok but the alarm buzzer sounds every 10 seconds.
The only solution I have found to turn the buzzing off is to remove the battery power for a while and then reconnect.
There's some strange design there to keep the alarm condition after the key is correctly recognized and the engine can be started. However I wonder if anyone else has the same problem and, eventually, a solution.
Thank you very much for your time,
Florin
dynoiasi is offline   Reply With Quote
 Old 01-25-2018, 09:25 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Probably time for a new BCM.
 Old 01-27-2018, 10:22 AM   #3
dynoiasi's Avatar
That's a possibility, although at the moment I am still hoping for a happier ending of this....
In the meantime I had the chance to connect a tester to the vehicle. The only DTC's I found in memory which might be relevant were on the GEM module:
B1318 - Battery volage too low and
U0100 - Lost communication with the PCM
Also there was a "Lost communication with the PCM" on the 4x4 module.
I don't know whether these are to be concerned about or are simply caused by low voltage on cranking or even appeared when I disconnected the battery to stop the alarm... I guess I'll have to poll on DTC's some more on these modules. And of course, there's also the fact that I did not scan with a professional Mazda tester, but a general Launch X341 with very old software...
Anyway, the good news is no DTC's on the PCM and BCM on this 40.000 miles vehicle. I'll post here if I find anything else on this, thanks!
Alarm randomly going off g00s3y 2010 MS3 - Troubleshoot/Diagnostics 5 08-05-2015 08:10 AM
Driver's turn signal - flashes on alarm but doesn't work with turn signal? xcoldricex MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-23-2014 08:50 PM
Alarm Keeps going off mkey66 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 04-29-2012 03:09 PM
Akerson: Opel will take time to turn profit, end '4-alarm fire' Haltech Automotive News 0 04-24-2012 05:20 AM
My new car alarm... _Toxic_ MazdaSpeed 3/6 - Car Audio & Electronics 5 10-21-2009 10:20 PM
Page generated in 0.23845 seconds with 21 queries
