![]() Join Date: Nov 2014
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score 2010 Cx7 2.3T, 83k on the motor. Oil changed every 5k with Mobil 1. Engine sounds fine once running, but has developed a long crank. Almost always get a long crank 1st thing in the morning (temps dropping into the 30s and 40s) and often other times throughout the day. Can get it with a hot engine, cold engine. Seems slightly more frequent after sitting, but have experienced it in quick restarts (<10 min). Changed out the plugs - no change in long crank. Checked for CEL - none. I don't want to throw parts at it, but my first thoughts are CPS or fuel pump. Any ideas of where to start? Why I can't get a CEL? Thanks! Mode $06 report generated by Torque for Android ================================================ Vehicle VIN: JM3ER4WL5A0305XXX Vehicle Manufacturer: Mazda Vehicle Calibration ID: L3B Test report: ------------------ MID:$01 TID:$80 - O2 Bank 1 Sensor 1 Max: 0.99999Ratio Min: 0Ratio Test result value: 0Ratio PASS ---- MID:$01 TID:$81 - O2 Bank 1 Sensor 1 Max: 0.99999Ratio Min: 0Ratio Test result value: 0Ratio PASS ---- MID:$01 TID:$82 - O2 Bank 1 Sensor 1 Max: 0.99999Ratio Min: 0Ratio Test result value: 0.20703Ratio PASS ---- MID:$01 TID:$83 - O2 Bank 1 Sensor 1 Max: 0.99999Ratio Min: 0Ratio Test result value: 0.28515Ratio PASS ---- MID:$02 TID:$05 Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2 Max: 100ms Min: 0ms Test result value: 25ms PASS ---- MID:$02 TID:$80 - O2 Bank 1 Sensor 2 Test incomplete or dependant test failed -- MID:$21 TID:$80 - Catalyst Monitor Bank 1 Max: 255.99281Ratio Min: 1.56248Ratio Test result value: 17.99977Ratio PASS ---- MID:$31 TID:$83 - EGR Monitor Bank 1 Max: 655.34998kPa Min: 5kPa Test result value: 15.65kPa PASS ---- MID:$35 TID:$80 - Max: 10° Min: -327.67999° Test result value: 1.87° PASS ---- MID:$35 TID:$81 - Max: 327.66998° Min: -17° Test result value: 0.93° PASS ---- MID:$3a TID:$80 - EVAP Monitor (cap off) Max: 8,191.75Pa Min: -1,942.75Pa Test result value: -1,942.75Pa PASS ---- MID:$3a TID:$81 - EVAP Monitor (cap off) Test incomplete or dependant test failed -- MID:$3a TID:$82 - EVAP Monitor (cap off) Max: -1,942.75Pa Min: -8,192Pa Test result value: -1,942.75Pa PASS ---- MID:$3b TID:$80 - EVAP Monitor (0.090") Max: 910Pa Min: -8,192Pa Test result value: 369.25Pa PASS ---- MID:$3c TID:$81 - EVAP Monitor (0.040") Max: 8,191.75Pa Min: 30.25Pa Test result value: 61.25Pa PASS ---- MID:$3c TID:$82 - EVAP Monitor (0.040") Test incomplete or dependant test failed -- MID:$3c TID:$83 - EVAP Monitor (0.040") Max: 0.5 Min: 0 Test result value: 0 PASS ---- MID:$3d TID:$80 - EVAP Monitor (0.020") Max: 8,191.75Pa/s Min: -1,000Pa/s Test result value: -546.25Pa/s PASS ---- MID:$3d TID:$81 - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$41 TID:$80 - O2 Heater Monitor Bank 1 - Sensor 1 Max: 30Ohm Min: 0Ohm Test result value: 5Ohm PASS ---- MID:$42 TID:$80 - O2 Heater Monitor Bank 1 - Sensor 2 Max: 51Ohm Min: 0Ohm Test result value: 21Ohm PASS ---- MID:$a2 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a2 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a3 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a3 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a4 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a4 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- End of report. |
| Not Ranked : 0 score check plug gap. Aim for .024"
__________________ |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score also, check your battery, I noticed mine was taking longer to start in the AM when it got colder, once running and warm no issues. I replaced the battery (it was original from 2012) and it jumps to life in the morning now.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() Join Date: Dec 2013 Location: Waterloo Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score ^^ THIS |
(Thread Starter) | Not Ranked : 0 score Thanks all - I gapped the plugs when I installed them a month or so ago and the battery is <1 year old. Lots of juice there. Any other ideas? |
| Not Ranked : 0 score Just because the battery is not old it doesnt mean its not good. Test it with a volt meter during crank. Battery issues can cause all kinds of problems. It has to be eliminated as a possibility completely not just its only 1 years old. When trying to solve an issue you have to be very open minded and do alot of testing. Assuming is the worst. Leads nowhere Sent from my D6603 using Tapatalk |
| Not Ranked : 0 score It should not drop below 9 during crank. Sent from my D6603 using Tapatalk Then next thing i would do is plug obd and check fuel pressure after the car starts. Sent from my D6603 using Tapatalk Last edited by Vitamin M; 10-14-2016 at 11:38 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Vitamin M For This Useful Post: | qtrmile beast (10-14-2016) |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score Sounds to me like fuel or timing to me. If you battery was weak or too weak to start it then it will also be too weak to turn the motor as well and you will get a slow crank that will progressively get slower the more you crank it. plug he says it starts so it must be staying at or above 12v. Also if you crank sensor is bad then that can cause long cranks because it might not be sparking the plugs to ignite the fuel. It also looks like your having a problem with your 02 sensor? most likely your wideband. This shouldnt cause your car to not start but it can cause it to run crappy once started due to bad it sending a bad signal back tot he ECU about the AFRs..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Feel free to also do a compression test since I doubt you've ever cleaned your intake valves and or EGR valve and tube maintenance which is a must on these high mileage DISI L3K9 engines and could have filthy ass intake valves that lead to detonation if you ever get on it aggressively with that puddled into the intake ports.
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
Sent from my XT1575 using Tapatalk | |
| Hard Start, Long Crank, Rough Idle | red ghost | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 10-07-2014 11:24 PM |
| Long Crank at cold start | maikell77 | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 03-13-2013 08:54 PM |
