  • 1 Post By
 Old 09-28-2015, 12:33 PM   #1
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
I may be retarded, but how do you install the meth level sensor and the filter in this tank? IIRC, both have to be dropped inside the tank and then you tighten a nut on the outside so there are no leaks.
I think by tightening the nut on the outside, the grommet is compressed causing it to flair out or "bulge" and seal on the inside of the tank. So I think you just stick it in the outside and turn the nut. Or at least that's what I did. Not sure if yours is different but I most definitely did not need to drop anything into the tank and hold it there while tightening the nut from the outside.
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following 2 Users Say Thank You to mize13 For This Useful Post:
Code Monkey (09-28-2015), EdgeAutosport.com (09-29-2015)
in tank meth?? david001wj 2010 MS3 - Fuel, Nitrous & Water Injection 7 06-19-2013 07:16 AM
Page generated in 0.23324 seconds with 21 queries
