  • 1 Post By EdgeAutosport.com
 Old 01-30-2015, 08:51 AM   #1
Default Aquamist Meth Tank. The standard to which all others should be held.
Aquamist has really thought this tank through.
Designed with space savings in mind, at only 2.6" wide, 13" deep, and 13" tall. It will also hold a very respectable 5 quarts.
The bracket is ergonomically designed to minimize installation time. Offering chassis floor or cross-rail mounting options. Four holes at the center section of the bracket are intended for mounting an Aquamist pump below.
The bracket is constructed with 2mm zinc plated mild steel plate and powder-coated (light grey). The structure is very strong. All fixing fasteners are supplied as well.
But more than that, look how neatly this tank fits in the trunk!
But enough with all this form. Where this tank really shines is its function! The narrow shape coupled with internal baffles will insure you never starve the pump for meth even in hard corning or acceleration.
[video=youtube;gXszFa3MkKM]https://www.youtube.com/watch?v=gXszFa3MkKM&x-yt-cl=85027636&x-yt-ts=1422503916[/video]
Check out this tank on our site by clicking any of the pictures. Or you can click below to purchase!
Aquamist Water/Methanol Tank with Baffle - $142.50
Mauro_Penguin likes this.
The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post:
09TrueRedGTX (01-30-2015), chaser27 (01-30-2015), Hush (02-02-2015), John596 (02-05-2015), lobitoPU (01-30-2015), Mauro_Penguin (01-30-2015), tegxsi (01-30-2015), trancehead (01-30-2015), WetzMS3 (09-25-2015)
 Old 01-30-2015, 11:48 AM   #2
lobitoPU's Avatar
Posts: 3,205   (View Stats)
Groans: 42
Sweet. Now give us that tax return discount code!
Fuck mazdaspeeds
Fuck shayne
The Following 5 Users Say Thank You to lobitoPU For This Useful Post:
BLKSTIG (02-01-2015), cyclist20 (02-01-2015), EdgeAutosport.com (02-02-2015), ms6mil (01-31-2015), Speedster13 (01-30-2015)
 Old 02-02-2015, 02:43 PM   #3
It is up
 Old 09-25-2015, 09:31 AM   #4
Regardless of what meth kit you go with, this is the tank you need!
 Old 09-25-2015, 10:11 AM   #5
I may be retarded, but how do you install the meth level sensor and the filter in this tank? IIRC, both have to be dropped inside the tank and then you tighten a nut on the outside so there are no leaks.
 Old 09-25-2015, 10:25 AM   #6
I believe that is still what you do with this tank. I suggest a really long flat head screw driver and some needle nose pliers to get the job done.
Code Monkey (09-25-2015)
 Old 09-28-2015, 12:33 PM   #7
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
I think by tightening the nut on the outside, the grommet is compressed causing it to flair out or "bulge" and seal on the inside of the tank. So I think you just stick it in the outside and turn the nut. Or at least that's what I did. Not sure if yours is different but I most definitely did not need to drop anything into the tank and hold it there while tightening the nut from the outside.
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following 2 Users Say Thank You to mize13 For This Useful Post:
Code Monkey (09-28-2015), EdgeAutosport.com (09-29-2015)
in tank meth?? david001wj 2010 MS3 - Fuel, Nitrous & Water Injection 7 06-19-2013 07:16 AM
Page generated in 0.29642 seconds with 23 queries
