Like Tree4Likes
 Old 02-05-2014, 03:47 PM   #1
Neutral  +1 score
Default ATP Bolt On Turbos At EdgeAutosport
Advanced Tuning Products (ATP Turbo) is a company that has devoted itself to turbocharging and all that is associated with turbocharging. They have dedicated their engineering and manufacturing towards taking fresh and functional approaches with re-imagining turbocharger systems. Their designs are simple yet highly effective and reliable. ATP Turbo is centered around adapting Garrett Turbocharges to many different vehicle types for easy bolt on installation with all the performance that is associated with Garrett turbos.
At EdgeAutosport, we carry the complete line of ATP products but today I just want to feature the bolt on turbo kits. Aside from the AP and Autotechs, this is the next best bang for your buck mod available to the Mazdaspeed platform. And bolting on 350 to 400 horsepower doesn't get any easier than this.
To start, we have the ATP GT2871r Bolt on Turbo ($1499). This turbo is efficient from 20 to 21psi on the MS3 and 6 and will flow enough air for up to 400 hp at the crank.
The next step up from that would be the ATP GT3071 Bolt on Turbo ($1599). The GT3071 flows a bit more on the top end than the GT2871 but it does sacrifice a little more low end power with a bit slower spool. It can support up to 450 crank hp and is efficient up to 22psi on the MS3/6.
The ATP GTX2867 Bolt on Turbo ($1699) is probably the best all around turbo for the MS3/6 because it spools up like the GT2871 while flowing up top like a GT3071. This means it has a much more useable power-band that works within the range of the factory fuel limitations. The GTX2867 can support up to 480 crank hp.
The ATP GT3076 Bolt On Turbo Kit ($1599) is going to be the next step up from the GTX2867. It flows up to 56 lbs/min and will be good for 500+ crank hp. The GT3076 will spool up a few hundred rpm later than the GT3071 but has quite a bit more top end power and will pull much harder to redline.
The ATP GTX3071 Bolt On Turbo Kit ($1799) is a one up from the GT3076. Flowing just slightly more air at 57 lbs/min. It will have a touch more top end on it than the 3076 with a quicker spool as well by a few hundred rpms.
And finally the Grand Daddy of the 30r turbos, the ATP GTX3076 Bolt On Turbo ($1799). This turbo takes you up into 35r territory with the quicker spool of the 3076. Flowing 65 lbs/min, this turbo can take you up over 600 crank hp.
All of the ATP bolt on turbos come with pretty much everything you need for installation. Including the Oil Return Line, the Coolant Feed Line, Low profile Banjo Bolt for the oil feed line, a boost tap to create a boost source for the BCS, and a coupler to connect the turbo to a top mount intercooler.
The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post:
atvfreek (02-06-2014), Awal (05-07-2015), Fail_6 (02-05-2014), kbz0129 (09-30-2014), msantana101 (02-11-2014), NCspecV81 (02-18-2014), Poohster (02-05-2014), taf0422 (02-05-2014), YABBAMZR (02-06-2014)
 Old 02-05-2014, 04:04 PM   #2
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
Not to nit pick, but the 2871 is capable of much greater than 20-21 psi, as well as 400 crank. Without meth, addln injectors, engine internals or properly gapped plugs, I was able to make 20 less than the crank figure advertised at the wheel, which with a 15-20% drivetrain loss factored works to somewhere btwn 430-460 crank hp
And we're still not done
Its worth mentioning though my tune was reasonably aggressive, with almost 25 psi at redline.
All in all, these are all equally beastly turbos though, and a great buy regardless of size, esp if purchased through you guys. With a beastly tune and tuner, great numbers can be extracted, sometime even superseding the expectations, without compromising daily drivability. Have your cake and eat it too.
Great deals and customer service is the name of the game here, and I don't think it gets too much better than Edge!
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
The Following 3 Users Say Thank You to Fail_6 For This Useful Post:
atvfreek (02-06-2014), bstover17 (02-05-2014), EdgeAutosport.com (02-05-2014)
 Old 02-05-2014, 05:58 PM   #3
Polish_Eagle's Avatar
Posts: 408   (View Stats)
I hate you guys right now! All these temptations you keep posting, but school bills take the priority. Damn it!
 Old 02-05-2014, 06:06 PM   #4
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
This is great info for future BTers. I do have a question. I bought a GTX2867R from you back last April 13. I got whole kit with the exception of oil return line. Is this something new? I haven't install my GTX yet and was wonder if this is available? Thanks.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 02-05-2014, 06:20 PM   #5
On the MS6, you should be able to reuse the stock oil return line.
EdgeAutosport.com (02-06-2014), Micha (02-09-2014), Poohster (02-06-2014)
 Old 02-06-2014, 01:01 PM   #6
Like Code Monkey said, the MS6 guys have to reuse the Oil return line but the MS6 Kit's come with step down studs to fit the oil return line with bigger turbo.
atvfreek (02-06-2014), Fail_6 (02-06-2014), Poohster (02-06-2014), rob ms6gt (02-28-2014)
 Old 02-06-2014, 07:59 PM   #7
Poohster's Avatar
Thanks. That braided line looks really nice.
The Following User Says Thank You to Poohster For This Useful Post:
EdgeAutosport.com (02-07-2014)
 Old 02-09-2014, 01:48 AM   #8
Micha's Avatar
Posts: 3,436   (View Stats)
Sooooo, I am using a GTX3076 ewg that I originally got for my speed 3 on my speed 6 now. What different parts do I need exactly to make it work?
Thanks.
I am slow again.
I modded it a little.
trancehead (02-18-2014)
 Old 02-10-2014, 11:13 AM   #9
Thanks.
You won't use the oil return line, and you will need the step down studs to allow the factory oil return line to fit with the big turbo.
Micha (02-10-2014)
 Old 02-11-2014, 08:59 AM   #10
You will need a 90* elbow to clear the TC.
I would recommend against the step-down studs, linky. Take your stock oil drain line to a machine shop and have the holes enlarged to accept 8mm bolts, linky.
However, first check if the oil drain line fits or you will waste $20, linky.
You may have to go custom, linky.
Micha likes this.
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
Awal (05-07-2015), EdgeAutosport.com (02-11-2014), Micha (02-11-2014), MZRSPEED (02-11-2014), sidekick (02-11-2014), trancehead (02-18-2014)
 Old 02-11-2014, 08:38 AM   #11
Remember, these turbos are all currently included in our tax sale so now is a great time to save on them...
atvfreek (02-11-2014), msantana101 (02-11-2014)
 Old 02-11-2014, 10:15 AM   #12
nukepilot's Avatar
Posts: 333   (View Stats)
nukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the world
Groaned at 32 Times in 12 Posts
Leme get this right, this is everything I need , all inclusive minus(tune internals ect ect)to go BT.
100% stock aftermarket parts!!
323whp 367lbs
nukepilot is offline   Reply With Quote
 Old 02-11-2014, 10:17 AM   #13
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
You'll need a few other things such as a 3 bar map sensor.
Tapatalkin'
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
The Following User Says Thank You to anodizedeeznutz For This Useful Post:
 Old 02-11-2014, 10:32 AM   #14
kbz0129's Avatar
Posts: 986   (View Stats)
So looks I'm going to end up buying the gtx3076r ewg setup that atp offers soon. Anything you guys recommend buying with it besides the bigger intake, 3 bar map, pnp harness, and ebcs?
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
 Old 02-11-2014, 10:40 AM   #15
It depends on what intercooler setup you have. If you have a top mount intercooler still, then the coupler that comes with the kit will work with that. But if you have a front mount you may need to get a different coupler for the hot pipe to compressor outlet.
The GT turbo's compressor outlet is 2" (slightly smaller than stock) and it is much shorter. So for instance, if you had a cobb FMIC, you would need to get a 2" straight coupler, a 2" metal joiner, and a 2.5" to 2" 90 degree silicon reducer coupler (as well as the appropriate clamps). This will allow you to get the intercooler connected to the turbo.
kbz0129 (02-11-2014), MZRSPEED (02-11-2014)
 Old 02-11-2014, 12:22 PM   #16
BZiggy10's Avatar
Posts: 725   (View Stats)
BZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the world
I am going to be getting that same setup next black Friday, if ATP will participate in the sale not sure if they did this last one.
06 MS6
Zig Built SOLD!!!!
Rebought back and continuing the mission to fully bolted top mount BT
BZiggy10 is offline   Reply With Quote
 Old 02-11-2014, 03:09 PM   #17
Yeah ATP was included in the BF sale and will most likely still be included this year too
 Old 02-11-2014, 10:56 AM   #18
kbz0129's Avatar
Ahh I'm glad I asked. I'm running the cx racing piping and upgrading the core to a tr8 or so. I'll have to take a look at the cobb kit to compare I guess. Thanks for the heads up you guys are awesome!
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
 Old 02-18-2014, 02:29 AM   #19
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
Just wanted to make sure, I've been searching and reading gtx2867r threads and couldn't find an answer.
Would I be fine with an IWG with a 3in catless DP?
edit: looks like i found my answer lol
PSA: Internal Wastegates and ATP turbos
08 cwp ms3
 Old 02-18-2014, 09:14 AM   #20
There is always the possibility of creep with the IWG turbos and you can sometimes have issues of higher creep, but most people run around 23 to 24psi on these turbos and that is usually more than what the turbo will creep too.
 Old 02-18-2014, 12:50 PM   #21
Alright thanks, looks like I have more reading to do
08 cwp ms3
 Old 02-18-2014, 01:27 PM   #22
Just to add on what Edge said - creep is highly dependant on your exhaust setup, intake setup, and ambient temperatures and pressures. If you have a 3" catless TBE and a big intake and well flowing intercooler you are more likely to creep especially when the temperatures drop in the winter. Higher altitude cars are less likely to creep.
If you are creeping with your setup and temperatures you see, you can port the wastegate or weld in a high flow cat in the test pipe location to prevent boost reep. The welded in cat is easier to do and if you have a two piece downpipe can be taken in and out (cold and warm weather) fairly easily.
Awal (05-07-2015), Boostin'likeAboss (02-18-2014), EdgeAutosport.com (02-18-2014), jreiden1 (02-18-2014), JSmith (02-18-2014), trancehead (02-18-2014)
 Old 02-18-2014, 04:28 PM   #23
Thanks Lex.
I planned out a setup with some pretty solid flow, 3in catless TBE, 3in TIP/SRI, and an upgraded higher flow TMIC. Factoring in the WI winter temps I'am pretty sure I would have some creep issues. looks like I'd either have to go EWG or take a better look / read into the BNR S3.
and of course, you know I'd have to get a strat tune!
08 cwp ms3
The Following User Says Thank You to Boostin'likeAboss For This Useful Post:
Lex (02-23-2014)
 Old 02-23-2014, 02:54 PM   #24
alextheguineapig's Avatar
Posts: 827   (View Stats)
Thanks Lex.
As I understand it, the BNR will also creep with a larger intake and catless set up.
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
The Following User Says Thank You to alextheguineapig For This Useful Post:
Boostin'likeAboss (02-23-2014)
 Old 02-23-2014, 02:58 PM   #25
yeah, after doing some reading the k04 will even creep with all that extra flow lol. looks like EWG it is
08 cwp ms3
 Old 02-23-2014, 03:27 PM   #26
NCspecV81's Avatar
Posts: 2,867   (View Stats)
+1. Picked up the 3067r from these guys. Even gave me the tax return discount for something that wasn't even listed on their site. That's grade A delivery of service right there!
I'm wondering if the 3067r can dethrone the gtx28 for best of all worlds turbo
The Following 3 Users Say Thank You to NCspecV81 For This Useful Post:
EdgeAutosport.com (02-24-2014), Lex (02-23-2014), twenty5psi (02-23-2014)
 Old 02-23-2014, 03:49 PM   #27
I think you're about to find out .
 Old 02-24-2014, 03:13 PM   #28
We, as I'm sure a lot of people here are looking forward to your results!
 Old 02-26-2014, 05:48 PM   #29
Mr Wilson's Avatar
Posts: 120   (View Stats)
Mr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the world
Very much so.......hoping we'll hear about them before the end of March
2008.5 CWP SPEED3
MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP
Mr Wilson is offline   Reply With Quote
 Old 02-28-2014, 11:00 AM   #30
Just wanted to add a couple turbos to the list...
Boostin'likeAboss (02-28-2014), RobT2009 (02-28-2014), The Panda (02-28-2014)
 Old 02-28-2014, 04:57 PM   #31
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
So a lot of the creep stories you will hear leave out the fact that most of them ported the ATP housing and wastegate to improve flow... but in reality they hurt them self by porting the Wastegate tunnle which causes creep.. As for Ko4's I run 27psi on mine and have no creep issue as I swapped out the WGA for a 14psi PTP one. All in Alll you want EWG as you can run 4 port EBCS which is a huge tunning advantage.
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
 Old 02-28-2014, 04:58 PM   #32
NCspecV81's Avatar
My first ATP turbo was creep free. Let you know on the second in about a week's time. I done zero porting.
The Panda likes this.
 Old 03-12-2014, 07:09 AM   #33
Boost_creep's Avatar
Posts: 829   (View Stats)
Just want to say thanks again to @EdgeAutosport.com; for the sweet deal on my GTX3071R.
I also wanted to mention that it looks like ATP has revised their hot sides to decrease possible boost creep. The crescent shaped obstruction that I have seen in the past is no longer there. It looks like they have done their own porting before assembling the turbo.
As a side note- mine shipped right from ATP, as edge was out of stock. So this may be a very recent change.
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following User Says Thank You to Boost_creep For This Useful Post:
EdgeAutosport.com (03-12-2014)
 Old 03-12-2014, 09:19 AM   #34
We are glad you got your turbo and are very happy with it!
Typically most ATP turbos are shipped directly from ATP as they are built to order.
Though we do have an EWG GTX3071 for an MS6 on the shelf here right now.
Boost_creep (03-12-2014)
 Old 03-19-2014, 12:03 PM   #35
The GTX3067 (that is GTX30 sixty-seven) is on the site now.
ATP Turbo GTX3067 Bolt-On Turbo Mazdaspeed 3
cshunter (03-19-2014)
 Old 05-09-2014, 10:17 AM   #36
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
What would be the best gtx turbo for 600 awhp would the gtx 3576 make this power?
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
 Old 05-09-2014, 10:50 AM   #37
If you have the fuel to do it, the GTX3576 will certainly get you there. You could probably also get that power out of a GTX3076 if you push it.
 Old 05-09-2014, 12:30 PM   #38
I'll definitely be upgraging the fuel system I'm making a list for a build.. would you say the gtx3576 would make 600hp with less stress on the turbo? I've read on the turbo flow chart thread they flow the same if I'm remembering right but I would think the gtx3576 would make these numbers and be safer because of the bigger cold side.
 Old 05-12-2014, 02:02 PM   #39
Yes the GTX3576 will flow more at less boost than the GTX3076.
WetzMS3 (09-17-2015)
 Old 05-09-2014, 11:19 AM   #40
keychain12's Avatar
Posts: 239   (View Stats)
keychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the world
Recently purchased and installed the ATP GTX2867 from Edge
The powerband is great! Lovin it so far!
ATP GTX2867r | CP-e 3" catted TBE | HTP 3.0" Full inlet & intake | CX Racing piping w/ Treadstone TR8 FMI | HPFP | EGR Delete | Grimmspeed EBC | Forge V2 BPV | Thermal Intake Gasket | NGK Plugs | 3.0 bar Map | Devils Own WMI w/ d07 Nozzle | Cobb AP
Dynojet Dyno:
92 pump gas tune: 326whp & 320tq
24psi tune w/ WMI: 349whp & 351tq
26psi tune w/ WMI: 360whp & 364tq
XXR 531 18x8.5 [+35mm] | Dunlop Sport 225/40 | Cobb Springs | JBR Rear camber arms | JBR 80 RMM | Hotchkis front & rear SB| SS brake lines | Corksport CC | MSD Dashhawk |Custom Stealth Sub Box by user: JTMS3
keychain12 is offline   Reply With Quote
The Following User Says Thank You to keychain12 For This Useful Post:
EdgeAutosport.com (05-09-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/atp-bolt-turbos-edgeautosport-164035/
GT3071R vs GT2876R vs GTX2867R - Mazda 3 Quebec This thread Refback 09-17-2014 10:04 AM
Turbos Last_Loser CorkSport 3 10-02-2012 08:50 PM
For all of those with BNR turbos.. numbnuts22715 MazdaSpeed 3/6 - Turbo Induction 66 01-09-2012 10:37 AM
ATP 1 Bar iwg turbos I Love Brownies MazdaSpeed 3/6 - Turbo Induction 93 08-30-2011 01:28 PM
MS3 vs. VW Bug TurboS FridayGt Street Racing Stories ( Bench Racing ) 37 04-25-2010 07:47 PM
Page generated in 0.63959 seconds with 38 queries
