| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
(Thread Starter) | Not Ranked : 0 score Is this page an error, or is this really available? Or is there a thread somewhere I don't know about and I'm re-posting like a brownie. GTX2871R Bolt On Turbo Kit for Mazdaspeed3 (2007 thru 2014) : atpturbo.com Code: ATP-MS3-020 Price: $2,050.00 PRODUCT DESCRIPTION: GTX2871R bolt on turbo kit for Mazdaspeed3. Garrett GTX2871R turbo with ATP proprietary exhaust housing and internal wastegate is ready to bolt up to the Mazdaspeed3 exhaust manifold and downpipe! Includes all coolant and oil connections to connect the turbo to the factory lines. The turbo is capable of producing over 500 crank HP as configured with supporting mods and proper tuning. Does not include 3" inlet pipe and 3" downpipe necessary to complete a "kit" in order maximize the turbo. The GTX2871R is the best spooling turbo on the market capable of achieving 500HP. Highly recommended for a very broad powerband with a lot of "area under the curve". For comparison, here's the ATP page for the GTX2867R turbo we all know and love: http://www.atpturbo.com/mm5/merchant...egory_Code=MS3 Code: ATP-MS3-021 Price: $2,050.00 PRODUCT DESCRIPTION: GTX2867R bolt on turbo kit for Mazdaspeed3. Garrett GTX2867R turbo with ATP proprietary exhaust housing and internal wastegate is ready to bolt up to the Mazdaspeed3 exhaust manifold and downpipe! Includes all coolant and oil connections to connect the turbo to the factory lines. The turbo is capable of producing over 450 crank HP as configured with supporting mods and proper tuning. Does not include 3" inlet pipe and 3" downpipe necessary to complete a "kit" in order maximize the turbo. The GTX2867R is the best spooling turbo on the market capable of achieving 450HP. Highly recommended for a very broad powerband with a lot of "area under the curve".
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following User Says Thank You to breakfstincluded For This Useful Post: | Micha (05-01-2015) |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score Looks legit to me.
__________________ 2013 CWP and Stock |
| Not Ranked : 0 score Correction: Garrett gtx2871r is availaible... Assuming a X71mm is making the flow of an old 76mm, it would be like a gt2876r...(A tiny turbine to drive a large compressor) I would be afraid of surge and heat.... Could it be better on high altitude where the atmospheric pressure is low?
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-20-2015 at 08:15 PM. |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
What do you know...you own a probe and a ZE probe at that!
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah | |
| Not Ranked : 0 score my english isn't good enough to understand your joke so it doesn't hurt much...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-20-2015 at 08:03 PM. |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score The gtx2971 is out as well... In case the 2871 is too small and 3071 is too big...
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
![]() Join Date: Jul 2014 Location: Saskatoon, SK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score I found this on Garrett's website: Products | Turbochargers So it definitely looks legit.
__________________ 2010 BM - FREEKTUNED - BNRS3 |
then classed it before the GT28 even if it can make more flow...?
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| Not Ranked : 0 score I am just giving you trouble. I cut my teeth on a 1993 ZE turbo. First car and i still have it. Always a fun car.
Back to subject, i run a gt2871r catless and when i was still running the mazdaspeed accessory CAI 2.64'', the turbo was surging at spool up in cold weather. it is ok now with a full 3.25'' intake but I would preffer a GTX3071R over a GTX2871r to make the same power at lower boost pressure/temperature/octane but i may be wrong too...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-20-2015 at 08:17 PM. | |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score @breakfstincluded;, this turbo is available through us for $1699. We have actually already sold one. |
| The Following 4 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
I'd love to see some real data to compare the GTX2867r and the GTX2871r Although the 67 will probably fit my needs better.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. | |
| Not Ranked : 0 score It may have been, but I don't know what his forum name would be. |
What would your guess be on the performance differences between these two?
| Not Ranked : 0 score look at the compressor map,...You will probably be running between 2.5 to 3 compression ratio up top (Maybe a little more) so you can see the flow difference from the 2.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-21-2015 at 09:47 PM. |
| The Following 3 Users Say Thank You to Jeff23spl For This Useful Post: |
I also ask Edge in particular, because I remember JP commenting he thought the 2867 was the perfect DD turbo. Which the idea of appeals a lot to my needs.
| Not Ranked : 0 score Ok so the gtx2871r outflows a gt3071r from the comp maps. I am guessing spool will be about the same as a gtx2867, faster than a bnr s3 or a gt2871, because gtx wheels historically have spooled faster than gt wheels.
| The Following User Says Thank You to spl For This Useful Post: | Easter Bunny (04-23-2015) |
But faster than what ?.... Do you do autocrossing or any track that really need instant response ? I run a old fashion gt2871 + a quite long fmic piping that should make it more laggy than both of these gtx and it is just perfect for D D. Sometimes it call to downshift a little bit more than would a k04 but it is just better for the engine bloc to use hp instead of low end torque. The car will remain D D and i'm looking for a bigger one. What would make me choose the x67 over the x71 is more about the goal to reach. If you don't want to upgrade the fuel system with a 5th-6th injector and wanna keep the stock rods etc. I won't go x71 when the x67 can brings you there in a easier way. Yes you can use a x71 and limit it to the boost but if you don't plan to unleash it, why going this route...? I don't have any direct refferences to say that but imo, driving a 550hp potential compressor with the gt28 turbine motor seems a little bit underpowered. I imagine the initial spool to be on the far left side of the map because the exaust flow restriction made by the small turbine opening. Again, i may be wrong on this, and if someones have test results from a gtx2871r running on our 2.3 engine, i would be very interrested to read about it. Maybe using an anti-surge comp. housing would just make it fine but when i checked to install a x71 cold side to replace my 71r i ended up looking for GT30 options instead... Another point i read here is about boost controling of a x71 compressor. The complaints from tuners was for the GTX3071r IWG. IT seems to be harder to tune for a stable boost curve because of the small IWG that tend to creep. Imo, using that compressor size on an a smaller turbine will just make this worst if i understand it correctly...If you still choose it, i would go EWG.
| Not Ranked : 0 score Based off what has already been posted, the GTX2871 is the turbo I'd choose between that and the GTX2867. It flows a little more air up top without sacrificing spool which should allow more compromise. Compromise is what a lot of people look for when choosing a turbo. They need it to spool fast and be capable of a lot of power. This turbo seems to offer both... |
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | breakfstincluded (04-22-2015), Easter Bunny (04-23-2015) |
| Not Ranked : 0 score I personally would run the antisurge. It is just an extra little measure of protection against turbo failure from having air trying to go out the way it came in. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | breakfstincluded (04-28-2015) |
![]() Join Date: Mar 2008 Location: South Beach Miami
| Not Ranked : 0 score Shit, I was looking for an ewg gtx30 but this seems to be the perfect compromise for my street needs and a (for now) stock block.
__________________ 07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP 3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks, hawk brake pads, rear camber arms. Speedbakery tuning in the works |
![]() | | #24 | ![]() |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score Someone do the GTX2971 as well...for science. |
![]() | | #25 | ![]() |
![]() Join Date: Aug 2013 Location: Bartlesville, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score I am looking at the "cartridge" option available at ATP to update my GTX2867R to either this GTX2871r or GTX2971r now that I am building my motor. The 2867r is a great little turbo but I need a little more now that I can...
__________________ 2013 MS3 Velocity Red - FLOW Tuned 25% E85 Mods - GTX2867R Turbo, Snow Meth Kit, Forged Manley Platinum pistons and Rods, Matt Dammond Balance Shaft Delete, Southbend Stage 3 Clutch, SPerformance Aux Fan Controller, 4" HTP Intake, Greddy FV BOV, Stratified Guardian Angel V2, Cobb AP V3, Tanabe Strut Tower Brace, Magna-flow CBE, HPFP Autotech Internals, CorkSport Shifter Bushings, CorkSport short throw shifter, CP-e Stage 2 RMM, CP-e Catless Downpipe, QTP Electric Exhaust Cutoff, NGK one step colder plugs, Cobb 3-port EBCS, Whiteline FSB, EBC 3GD Slotted Rotors, Hawk HPS Brake Pads, Goodridge Stainless Steel Brake Lines, HTP Small Battery Box, 51R Optima Yellow, SPC adjustable Rear Camber Arms, KW Variant 3 Coilover setup, Matt Dammond Passenger and Transmission mounts, Falken Azenis tires (street use), Defi Boost Gauge, AEM UEGO Wideband Gauge, AEM Water Temperature Gauge, AEM Oil pressure gauge, Corksport Short Shifter, Apexi Turbo Timer, Corksport Skid Plate, Threadstone TR8 core and crash bar, DOCRACE exhaust manifold, Reletnless Customs Ported IM, JBR 250 Competition Rear Sway Bar, Kuhmo V710 on RX8 wheels (track use), Matt Dammond OCC (VC and intake), Speed Performance Vented Oil Cap, Rice - 20% tint, Morimoto HID kit, Retrofit High Beams, Morimoto projector clear lenses, Corksport Hood Strut Kit, Corksport eyelids color matched, Ebay rear spoiler extension, Morimoto RGB Halos, LED Red Evil Eye, VG Shark Fin Antenna, Coil Cover, Blue Vacuum Hoses, Morimoto LED low beams, Cover King custom Seat Covers |
![]() | | #26 | ![]() |
| Not Ranked : 0 score You have your turbo at ATP getting rebuilt right? |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I'm curious about the options from your x2867 because it would need work/changes on the housings...Vs the price of a complete brand new larger one...Especialy for 2971 where both wheel diameter are different. On ATP website, it says the GT29 is a direct replacement for GT28 but since one is 54mm when the other is 56mm turbine wheel, i would expect machining is needed ?
![]() | | #28 | ![]() |
| Not Ranked : 0 score You should be able to swap the old hotside with the new compressor as a drop in upgrade if I understand the upgrade path correctly. My 2867 is being inspected under warranty, I am expecting the canned ATP answer that it needs rebuild not covered under warranty. That is when I will talk to them about upgrading if is really possible.
| The Following User Says Thank You to Zoom66 For This Useful Post: | EdgeAutosport.com (04-30-2015) |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
The GTX2971R turbine wheel is larger than the GTX28 and smaller the than GTX30 turbine wheels...
| The Following 2 Users Say Thank You to breakfstincluded For This Useful Post: | broda (04-28-2015), EdgeAutosport.com (04-30-2015) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I call BS to ATP. My turbo 2867 New GTX2867R dual ball bearing turbo with ultra high flow compressor wheel featuring Garrett 10-Blade technology . **Turbine Housing is sold separately and is the same as one used on GT2871R using 53.86mm 76 trim turbine wheel. . New GTX2871R dual ball bearing turbo with ultra high flow compressor and featuring Garrett 11-Blade technology. 560HP potential flow. **Turbine Housing NOT included and sold separately. The GTX2871R utilizes the same turbine housing as GT2871R and all GT28 series turbochargers with a 53.9mm and 76 trim turbine wheel. So from their webpage I should be able to get the GTX2871 compressor and mate it to my turbine...
![]() | | #32 | ![]() |
| Not Ranked : 0 score 2867 to 2871 would work. I was only referring to the 2971. |
| The Following 4 Users Say Thank You to broda For This Useful Post: | breakfstincluded (04-28-2015), Jeff23spl (04-29-2015), SarcasticOne (04-29-2015), Zoom66 (04-28-2015) |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Can you tell me where I can get the original video of your avatar.
![]() | | #34 | ![]() |
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to broda For This Useful Post: | breakfstincluded (04-28-2015), Shwa (04-29-2015) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score As long as he replace x67mm cold side hosing by a x71.xmm housing. You would need a complete turbo exept atp hosing not just a chra cartridge. my understanding is when you buy one brand new, you can swap parts because they re use them as new but later on, there is no real direct replacements for different size or neither from x and older series because machined x wheels seems to be half a mm larger. they forgot to tell 67mm compressor wheel is smaller than 71 ...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-29-2015 at 02:25 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score My evening today is in your debt.
| The Following User Says Thank You to breakfstincluded For This Useful Post: | broda (04-29-2015) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I was talking about mating my current hot side the new GTX2871 cold side....
| The Following User Says Thank You to Zoom66 For This Useful Post: | broda (04-29-2015) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Just make sure you talk to the tech guys at ATP and not sales for questions regarding this subject. |
![]() | | #40 | ![]() |
![]() Join Date: Mar 2010 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 631
| Not Ranked : 0 score I saw it was an option on the site to get an EWG exhaust housing as well. Could you confirm this @EdgeAutosport.com; ?
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah |
| GTX2871R????? | themytb | MazdaSpeed 3/6 - Turbo Induction | 70 | 02-29-2012 04:20 PM |
