Like Tree23Likes
 Old 11-20-2014, 04:52 PM   #441
Brockjb41's Avatar
Posts: 32   (View Stats)
Brockjb41 will become famous soon enough
So now what he is saying is that the bolt from the oem line wont fit into the turbo because its too big...?
TURBOXS RP & DP/ COBB SRI/ COBB AP/ AUTOTECH HPFP/ KONI YELLOWS / EIBACH PRO KIT / CORKSPORT LED FOG LIGHTS/ DDM HIGH & LOW BEAM 6000K
Brockjb41 is offline   Reply With Quote
 Old 11-20-2014, 06:59 PM   #442
shamie's Avatar
Posts: 952   (View Stats)
My kit from Edge (ATP) was a bolt in. Everything fit - eventually. It was pretty straight forward just time consuming. I don't even want to know what your bill's going to be @ $75-100 an hour shop rate. If this dude can't handle a bolt on kit you've got the wrong dude. If he's having issues in a shop with a lift.... I did mine by myself in a carport with 2 ramps!
 Old 11-20-2014, 07:32 PM   #443
Brockjb41's Avatar
Seriously, i could probably do it with less issues using only a pair of scissors and some glitter glue.
 Old 11-20-2014, 07:36 PM   #444
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I did a search and didn't find much on it, besides a speed6 that went on a 3071 EWG w/stock cat back and upgraded TMIC and still made like 390whp on a dyno. MS6 3071 dyno
Is my stock catback really a restriction for the gtx3076 w/EWG?
My only thought is that is might not be when it's dumping, but maybe it would slow spool time?
Most people have already upgraded their catback by the time they go BT so it's probably never an issue.
 Old 11-21-2014, 10:09 AM   #445
Brockjb41's Avatar
So the bolt they sent me for the return line is too small to fit the oem banjo and the aftermarket banjo. Anyone had similar issue?
 Old 11-21-2014, 10:22 AM   #446
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I used the ones from the kit and they fit well. I remember one of the lines was a PITA to thread into place, I don't remember if it was the return or the feed line for the turbo but it was supposed to thread down into the CHRA somewhere.
Also installed my stuff at the dealer, some mechanics at the dealers are pretty good and the one working on my car at my dealer is one of that too good to be true kind.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-21-2014, 12:30 PM   #447
shamie's Avatar
There was no banjo on my return line - it was the custom line provided in the kit.
 Old 11-21-2014, 08:31 PM   #448
CharliePenn171's Avatar
Posts: 39   (View Stats)
CharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to beholdCharliePenn171 is a splendid one to behold
Originally Posted by Brockjb41 View Post
BecAuse the dealership is saying that the oil lines just wont line up.
I used the line that came with the kit.
Wow...The dealership! I would hate to see that bill. Get the vaseline out because they will be giving it to you DRY! Next time, do more research and you can do the installs yourself. Or get with the local NATOR and see if you can get some help from them.
CharliePenn171 is offline   Reply With Quote
 Old 11-21-2014, 08:39 PM   #449
The banjo bolt I believe is on the feed line. It is a huge PITA to put on. The one in the kit is shorter but it does work fine. Easier to install with help from a friend but it is still a PITA.
 Old 11-21-2014, 10:04 PM   #450
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
Getting close to pulling the trigger at the atp3071r ewg kit you have on the site. What size tial ewg are offered ? It doesnt say anything unless there is only one size we should be using ?
2012 Black Mica Speed 3
300whp-341wtq tuned by John @ Tork Motorsports (2/4/14)
Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC
Mazdaspeed3KHP is offline   Reply With Quote
 Old 11-23-2014, 03:28 PM   #451
Bob-o's Avatar
Posts: 1,312   (View Stats)
The ATP EWG hotside uses a 38mm wastegate
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
The Following User Says Thank You to Bob-o For This Useful Post:
Mazdaspeed3KHP (11-25-2014)
 Old 01-20-2015, 01:58 PM   #452
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
@EdgeAutosport.com
My goal: 400whp "safe" DD
Mods: listed below
Plans: listed below including NEW 0 mile OEM long block
Question: After weeks of research, essentially all GT and BNRs3 turbos can pretty much get me there with proper tune and fueling. I do not plan for meth, but I do plan for at least 30% E85 depending on my local tuner's desires. What is the best BT for my goals that does not strain the turbo/ motor to all hell? Obviously with a GT28/BNR s3 I have to run near close to the boost limits of the turbo... with a gt30/gt35, lower boost to equal the same power but longer spools, see main gains when almost to redline (which i believe would be good for a DD, so you're not max boosting while mod driving). So I guess I'm asking what's better for a 400whp DD, underboosting a larger turbo or near-max boosting a smaller turbo?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
The Following User Says Thank You to Jkelley For This Useful Post:
Shwaykid (01-20-2015)
 Old 01-20-2015, 03:12 PM   #453
cam1391's Avatar
Posts: 326   (View Stats)
Pm price for 3071 drop in turbo please. Side question, whats the best hpfp internals kit iyho. Thanks
 Old 01-20-2015, 03:14 PM   #454
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by Jkelley View Post
@EdgeAutosport.com
Mods: listed below
Bigger turbo, slower spool, lower tq, happy motor.
The Following User Says Thank You to Etipp98 For This Useful Post:
Jkelley (01-20-2015)
 Old 01-20-2015, 03:33 PM   #455
Jkelley's Avatar
i presume gt30 then without meth/5th/6th port?
 Old 01-20-2015, 05:17 PM   #456
Cheapspeed's Avatar
I'm planning on gtx3076. I want my power to the right because I spend a lot of time on the highway and would like my power to stay around redline which is better for straight line racing.
 Old 01-21-2015, 10:20 AM   #457
Gixxer2k4's Avatar
Posts: 130   (View Stats)
Gixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond repute
PM sent
Gixxer2k4 is offline   Reply With Quote
 Old 01-21-2015, 10:26 AM   #458
Gixxer2k4's Avatar
Has anyone had fitment issues with the catted CP-e downpipes and ATP turbos? Heard there could be an issue?
 Old 01-21-2015, 10:55 PM   #459
Bob-o's Avatar
Only if you get an ATP external wastegate hotisde. The bellmouth will contact the wastegate, but that can be resolved with a stuffy 45* vband extension
Gixxer2k4 (01-21-2015)
 Old 01-22-2015, 08:52 AM   #460
@EdgeAutosport.com
Mods: listed below
I think if you are looking for a turbo to maximize your setup, the GTX2871 will be the way to go (you read correct, GTX2871). Its gonna flow like a GTX3071 with a little bit better spool. You'll be able to max out your fuel with that turbo and you won't have to run it on the ragged edge to do it.
But to answer your question, I prefer to underboost a larger turbo than running a smaller turbo out to the ragged edge. When you are close to the edge, you get a lot more heat and efficiency drops. And with the larger turbo, you always have more room up top if you decide to add extra fuel later.
Cheapspeed (01-22-2015), Jkelley (01-31-2015)
 Old 01-30-2015, 11:58 PM   #461
Funktionull's Avatar
Posts: 215   (View Stats)
Funktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the world
Starting my 3071 install tomorrow and have been on the fence about porting the IWG before I put it on.
Have a catted DP for reference. I know it only takes a few minutes and I WOULD just do it but my dremel is broken and I dont feel like buying/borrowing one if creep isn't going to be a problem without porting.
Funktionull is offline   Reply With Quote
 Old 01-31-2015, 07:25 AM   #462
Bob-o's Avatar
Open the flapper and ask yourself: Do you see a small crescent moon that would have ANY chance of acting as a restriction?
Then ask what is more work, getting a dremel and playing it safe, or taking a chance on doing 2 turbo installs because you skipped this step the first time around
I only speak from experience because it happened to a lad in our nator
09TrueRedGTX (01-31-2015)
 Old 01-31-2015, 07:39 AM   #463
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
you're not referring to me are you?
Performance:
Stratified Tune in progress
The Following User Says Thank You to Swinger13 For This Useful Post:
Bob-o (02-01-2015)
 Old 01-31-2015, 09:18 AM   #464
cam1391's Avatar
Im really having a hard time deciding on the turbo. I was originally looking at the gt3071r, but would like to evdntually make just under 500whp(around 450-475) yet still make around 4 while on stock internals, without having to buy another turbo down the road. Would you suggest gt3076r? Id like to stick with the proven gt series. The gtx just seems hit or miss.
 Old 01-31-2015, 09:25 AM   #465
Swinger13's Avatar
Groans: 53
gtx3076
Performance:
The Following 2 Users Say Thank You to Swinger13 For This Useful Post:
Cheapspeed (01-31-2015), Voltwings (02-02-2015)
 Old 01-31-2015, 09:32 AM   #466
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
Definitely check it out before installing. I was pleasantly surprised to find that my gtx3071r didn't have that crescent restriction that the earlier models had. I installed it as is, and with my catted dp I only crept to 21 psi on spring pressure.
09TrueRedGTX is offline   Reply With Quote
 Old 01-31-2015, 02:40 PM   #467
cam1391's Avatar
Originally Posted by Swinger13 View Post
gtx3076
I was either gonna go gt3076 or gtx3071. Gtx3076 seems like overkill for what im trying to do.
 Old 01-31-2015, 04:09 PM   #468
Cheapspeed's Avatar
You wanna make just under 500hp? How is the gtx3076 overkill? Sounds like the perfect turbo for what you're trying to achieve.
 Old 01-31-2015, 05:01 PM   #469
danosrk's Avatar
danosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the world
Where can I find said turbo?
Go catch a headlight
Things learned from 2014 deployment:
1. Tomahawks will kill you
2. Remember that one time you didn't suck at your job? Yeah, neither do I.
3. I work with enough retards on my ship that we should qualify for extra money from the government
Purple Drank Tuned
Wiseco Pistons/Manley H-beams/JBR BSD/JBR Oil Pan Baffle/ACT 6 Puck/Streetlite Flywheel/CP-E Exhaust Mani/GTX2867R/CP-E Catless DP/Electronic Exhaust Cutout/HTP 4" Intake/PERM PCV Plate/Damond Dual OCCs/Kozmic EGR Deletes/Coolant Bypass/CP-E Safe Seals/CP-E HPFP/Grimspeed 3 Port EBCS/3.5 Bar MAP/CX FMIC w/ TR8 Core/Devil's Own Stage 2 Meth Kit/NGK Iridium IX/HKS SSQV 4 VTA/JBR 88D Trilogy Mounts/JBR Small Battery Box/Optima Yellow Top/Gram Lights 57F/Dunlop Direzza ZII's/Yellowspeed Coils/DK Rear Camber Arms/CorkSport RSB/GT Spec Rear Tie Brace/GT Spec Link Reinforcement Panel/TWM Short Throw/CP-E Triple Gauge Pod/ProSport EVO Gauges
danosrk is offline   Reply With Quote
 Old 01-31-2015, 07:45 PM   #470
cam1391's Avatar
Think ill get spool by just over 4k rpms w/ Stock manifold (upgrading to cpe 44mm ewg mani down the road)? I assume it will be a good option for around 400hp while I get the parts together to build the bottom end? And after thinking about it im thinking 450 is a better realistic final goal for a dd. I was making 497awhp @ 512awtq in my evo and as much as I loves it, it was more than I could ever honestly use around here. I know 50hp might not seem like.much to some people, but as im sure you guys know it can be a huge difference in daily drivability.
 Old 01-31-2015, 08:28 PM   #471
I just looked at mine pretty extensively and compared it and it looks as ported as any "extra" porting pics I have seen so I'm not gonna screw with it. No half moon restriction or lip going in.
Soon as the weather gives me a non-shitty day I'll get things started.
The Following User Says Thank You to Funktionull For This Useful Post:
 Old 02-01-2015, 03:58 PM   #472
Bob-o's Avatar
 Old 02-02-2015, 09:05 PM   #473
Trying to confirm whether or not I need to order a step down stud for the oil return on the 3071 kit I got through edge. Read a post from like 5 years ago that said yes but then found nothing else so i dunno if its changed since then.
GT3071R ll HTP 3.5'' ll CP-E DP ll UR Exhaust ll Synapse DV ll Autotech HPFP ll TR8 w/ JBR PIPING ll Cobb 3port EBCS ll Matt Damond OCC ll NGK Iridium IX ll Bosch 3BAR ll JBR Solid Shifter Bushings ll JBR 88/88/80 Trilogy ll AP V3
 Old 02-02-2015, 09:21 PM   #474
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Yes you will need two studs.
 Old 02-03-2015, 09:24 AM   #475
Gixxer2k4's Avatar
Part# by chance?
 Old 02-03-2015, 09:39 AM   #476
jdmage_mx5's Avatar
Sorry, I do not. I will see if I can find it here in a bit.
 Old 02-03-2015, 11:59 AM   #477
MIA-FST-038
They dont come in a set so make sure you order 2.
The Following 2 Users Say Thank You to Funktionull For This Useful Post:
Gixxer2k4 (02-03-2015), jdmage_mx5 (02-03-2015)
 Old 06-09-2016, 07:10 PM   #478
BuddySpeed3's Avatar
Posts: 479   (View Stats)
What exactly comes with the BNR S4 Turbo kit? Is there anything else aside from the HTP 3.5 inch intake that I would need to purchase? Thanks
Sorry if it's already been answered, there's just a lot of pages in this thread.
 Old 06-16-2016, 09:45 AM   #479
D1Sano's Avatar
Posts: 7   (View Stats)
D1Sano has a spectacular aura aboutD1Sano has a spectacular aura about
I'm trying to get my EBCS in and I'm having trouble finding the line for the boost source. I just dropped in a ATP GXT3076R with EWG and there is no outlet coming off the turbo housing. IS there an alternate source I can tap into?
2008.5 CWP MS3
2008.5 True Red MS3
2007 True Red MS3
2007 Cosmic Blue MS3
D1Sano is offline   Reply With Quote
 Old 06-22-2016, 02:25 PM   #480
mituc's Avatar
Groans: 111
Tap into a boost tube. The one coming off the turbo will work just fine.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.56066 seconds with 39 queries
