Like Tree23Likes
 Old 09-29-2011, 09:22 AM   #1
RyansSpd3's Avatar
Posts: 424   (View Stats)
RyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the world
Groaned at 7 Times in 5 Posts
So about the intake..if going bt all i need is a bigger TIP and the rest of the intake can remain the same? I have a mazdaspeed CAI
||2008 Metro Grey Ms3|| Cobb Sri|| Cobb TIP|| Cobb AP|| TurboSmart Dual Port BOV|| ATP full downpipe|| Autotech fuel pump internals|| TurboXS FMIC|| Denso ITV22's|| JBR 88a RMM|| BC Coilovers|| Evo X Wheels|| 25% E85 Mix|| Phate Tuned||
RyansSpd3 is offline   Reply With Quote
 Old 09-29-2011, 09:30 AM   #2
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Yes that will work. Although if you want a FMIC one day, the piping might not fit with the cold air intake. But if I remember right, the MS CAI is two piece so I think you might be able to turn it into a short ram, maybe not, I'm not 100% sure. @eric@edgeautosport, can you confirm this by chance?
Either way, yes, you just need to replace the TIP with the correctly fitted one for that intake.
The Following User Says Thank You to JP@edgeautosport.com For This Useful Post:
EdgeAutosport.com (09-29-2011)
 Old 01-31-2015, 09:18 AM   #3
cam1391's Avatar
Posts: 326   (View Stats)
Im really having a hard time deciding on the turbo. I was originally looking at the gt3071r, but would like to evdntually make just under 500whp(around 450-475) yet still make around 4 while on stock internals, without having to buy another turbo down the road. Would you suggest gt3076r? Id like to stick with the proven gt series. The gtx just seems hit or miss.
 Old 01-31-2015, 09:25 AM   #4
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
gtx3076
Performance:
Stratified Tune in progress
The Following 2 Users Say Thank You to Swinger13 For This Useful Post:
Cheapspeed (01-31-2015), Voltwings (02-02-2015)
 Old 01-31-2015, 02:40 PM   #5
cam1391's Avatar
Originally Posted by Swinger13 View Post
gtx3076
I was either gonna go gt3076 or gtx3071. Gtx3076 seems like overkill for what im trying to do.
 Old 01-31-2015, 04:09 PM   #6
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
You wanna make just under 500hp? How is the gtx3076 overkill? Sounds like the perfect turbo for what you're trying to achieve.
 Old 09-29-2011, 09:39 AM   #7
JP you are correct on turning it into an sri and he might be able to run the cai with a fmic just depends on the fmic he gets.
Eric
 Old 09-29-2011, 09:44 AM   #8
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
The MSCAI does have 2 pieces and you can turn it into a SRI. Now i have some questions. Whats the advantage or going with an ewg? Im looking at the steedspeed mani but i dont know which one i want. And can i get a turbo without the iwg?
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
The Following 2 Users Say Thank You to YokiMazoku For This Useful Post:
EdgeAutosport.com (09-29-2011), JP@edgeautosport.com (09-29-2011)
 Old 09-29-2011, 01:27 PM   #9
Yes, T3 with vband or any other design, you name it we can get it. Not sure if you know about the EWG turbine housing with the stock Mazda style discharge flange (where the turbo meets the downipe) but we can get that too.
Here's a picture of that.
Externally Wastgated Turbine Housing for Mazdspeed 3 - GT3071R/GT3076R : atpturbo.com
Obviously, this is for a stock style exhaust manifold as well.
The Following 2 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
Alpha (09-29-2011), Manny3 (02-20-2012)
 Old 09-29-2011, 09:48 AM   #10
Yes we can get you a turbo without an iwg and the advantage you have with an ewg is controlling boost better
Broxer (09-30-2011), YokiMazoku (09-29-2011)
 Old 09-29-2011, 01:57 PM   #11
adrager622's Avatar
Posts: 745   (View Stats)
Groans: 46
This is a stupid question, but I haven't been running synthetic on my car. I got about 19K miles on the car (going in for an oil change in a week or two). If I'm going to possibly run a GT3071R by next summer, would it be safe to switch to synthetic now to prepare for it?
2010 MS3 Black Mica
 Old 09-29-2011, 01:58 PM   #12
yes you should have been running synthetic all along, switch on your next oil change.
 Old 09-29-2011, 05:27 PM   #13
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
You are running 5w30 at least right?
reason I ask is because if you are taking your car to a quick oil change place, they may not know or care and will put in 5w20 like they do for all the regular mazda3's that come through there.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 09-29-2011, 08:49 PM   #14
adrager622's Avatar
Groans: 46
Ya, I have the right oil going in. I make sure of it haha. I just really never thought of running synthetic since I didn't expect to really modify this car much.
2010 MS3 Black Mica
 Old 09-30-2011, 11:42 AM   #15
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
/fail
Turbo = synthetic.
 Old 09-30-2011, 01:37 PM   #16
adrager622's Avatar
Groans: 46
Originally Posted by helmetface00 View Post
/fail
Turbo = synthetic.
Hey, it's my first turbo car. Give me a break. Still learning as I go along. Synthetic is going in when I change the oil in a week.
2010 MS3 Black Mica
 Old 09-29-2011, 09:28 PM   #17
Well it's good to run synthetic regardless. The synthetic handles heat better and heat is what you get with a turbo.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-29-2011, 10:14 PM   #18
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Will my dick grow 5" if I go BT?
ABolewski (11-16-2012), Dumyz (10-22-2012)
 Old 09-30-2011, 11:38 AM   #19
yes
The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post:
ABolewski (11-16-2012), breakfstincluded (11-24-2011), Broxer (01-31-2012), Dumyz (10-22-2012), Fail_6 (01-12-2012), Flaverre (11-27-2011), Manny3 (02-20-2012), rghispanic88 (12-26-2011), thehead (03-24-2012)
 Old 09-30-2011, 03:15 PM   #20
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Working within my estimated budget, I can't afford to get a BT and FMIC at the same time. Well, maybe the CS FMIC. But I'm looking for opinions on running say a CS TMIC with a GTX BT. I know it will be prone to heat soak but would it be sufficient otherwise? I would prefer to get the BT in the car ASAP and then add a FMIC down the road, even if I have to run it at lower boost levels.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
EdgeAutosport.com (10-03-2011)
 Old 09-30-2011, 03:42 PM   #21
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
I would avoid the CS FMIC at this time if you want to go BT. Their "small core" version is too small for a BT, and their "large core" version removes the crash bar - you don't want that. Save up for either cp-e or UR w/crashbar option.
If you run with a TMIC you should be fine, although your BAT's are going to be pretty high. As you said, keep a conservative tune.
The Following 2 Users Say Thank You to adlpb For This Useful Post:
Broxer (09-30-2011), JP@edgeautosport.com (10-01-2011)
 Old 10-05-2011, 04:06 PM   #22
I'm running GTX3071 with CS TMIC. BAT's can get a little high when its hot out but it works just fine for now. Plus you get a little faster spool...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following 3 Users Say Thank You to JacksonMS30 For This Useful Post:
Broxer (10-05-2011), EdgeAutosport.com (10-05-2011), pebenito (10-06-2011)
 Old 10-05-2011, 02:26 PM   #23
we will be having a local go bt with top mount here pretty soon so i will have him post some logs
Broxer (10-12-2011)
 Old 10-05-2011, 04:18 PM   #24
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
You could always go pg pipes with godspeed core like I did...$450 and my bats are nice and low
I'm considering selling my pte 5557 and buying a gtx3071...could you run the gtx as ewg?
Tapawho?
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
The Following 2 Users Say Thank You to EL F00LI0 For This Useful Post:
Broxer (10-05-2011), JacksonMS30 (10-05-2011)
 Old 10-05-2011, 04:41 PM   #25
Broxer's Avatar
Groans: 90
Tapawho?
Ya I may go that route. How did you secure your core to the car? I'm in the works of getting a crash bar fabbed so I can run more than a 6.5" core.
 Old 10-05-2011, 04:44 PM   #26
Yes, you should be able to order the ATP ewg housing with it no problem...
<===== wishes he had done that...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
 Old 10-05-2011, 05:44 PM   #27
RyansSpd3's Avatar
Tapawho?
Hey are you bt yet? wanted the exact same pg/godspeed FMIC but wasnt sure if that core could handle low 400's or not
The Following User Says Thank You to RyansSpd3 For This Useful Post:
 Old 10-05-2011, 06:55 PM   #28
EL F00LI0's Avatar
At the moment, no. I'm putting it off to buy some camera/video equipment and get a side job shooting/editing videos at my buddies production company to gather funds faster for my build. I am most likely going to upgrade to a slightly bigger core though. I am pretty sure that sized core can handle that much power. Don't quote me on that though because that is all speculation.
Can someone pm me the price for the gtx3071 with and without the atp ewg hotside?
Tapawho?
 Old 10-05-2011, 07:14 PM   #29
yes it will handle low 400s with no problem
Tapawho?
well the iwg is 1649 shipped and im pricing that other option so I will pm you here in a bit.
 Old 10-05-2011, 07:46 PM   #30
EL F00LI0's Avatar
Alright sounds good!
Tapawho?
The Following User Says Thank You to EL F00LI0 For This Useful Post:
 Old 10-05-2011, 08:20 PM   #31
Tapawho?
do you need the kit with the lines and the dump tube and the ewg
 Old 10-05-2011, 07:53 PM   #32
RyansSpd3's Avatar
Alright sweet thanks Eric looks like Im going pg/godspeed...you've been so helpful! lol
 Old 10-05-2011, 09:07 PM   #33
EL F00LI0's Avatar
I would just need the lines and turbo. I have a mani and dump tube already. I still have to see if I can get a buy for my current turbo.
Tapawho?
 Old 10-06-2011, 07:38 AM   #34
Tapawho?
cool just let me know if you want to go this route. also did you have an external waste gate?
 Old 10-06-2011, 08:16 AM   #35
EL F00LI0's Avatar
Nope, picking up a tial wastegate from a buddy sometime soon. Would a 38mm be good for the gtx? Or 44mm? Because on the pte 5557 you need to run a 44mm.
Tapawho?
 Old 10-06-2011, 09:21 AM   #36
Tapawho?
why do you say you need to run a 44mm on the 5557? imo 38mm is plenty even for the 5557
 Old 10-06-2011, 08:29 AM   #37
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
With the mods in my sig how much and what items do you think i would need to buy to go ATP bolt on GT3071r? pm me the answer to this one please. If everything goes according to my grand scheme i will be going BT around july or august of next yr
RichTuned
BlueDmnSpeed is offline   Reply With Quote
The Following User Says Thank You to BlueDmnSpeed For This Useful Post:
EdgeAutosport.com (10-06-2011)
 Old 10-06-2011, 08:47 AM   #38
Tapawho?
I didn't read up on what your setup is going to be but if you are using the EWG turbine housing, the only wastegate you can use is the 38mm. It's flanged for that already. If you're using it on the mani, either one will obviously work but the 38mm is really all you need for a 3071/76 even for a GTX.
Looks like you need a boost controller, new TIP for Big Turbo, and with the UR FMIC, you'll probably need a new coupler for the turbo to hot pipe.
 Old 10-07-2011, 06:31 AM   #39
Hmm. So with the 3071 turbo and those that should be about what 3000 for the parts at the most then depending on if I install myself or not maybe more for the labor from wherever.
RichTuned
 Old 10-07-2011, 07:31 AM   #40
You could always have a willing MSF member come to your location and get them to help you install it at the cost of a couple of pizzas and a plane ticket (round trip)... lol!!
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
EdgeAutosport.com (10-07-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.79460 seconds with 35 queries
