Like Tree23Likes
 Old 12-28-2011, 04:19 PM   #201
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Originally Posted by eric@edgeautosport View Post
compared to my t3 it doesnt seem very big lol
well a lot bigger then the stock hotside.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
EdgeAutosport.com (01-03-2012)
 Old 01-03-2012, 08:36 AM   #202
So you need that ewg hotside yet lol
 Old 01-03-2012, 06:16 PM   #203
86AmishMs3's Avatar
Groans: 338
nah i just threw a cat in there. I'm good now. but still need to get the massive coolant leak fixed.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 01-03-2012, 06:18 PM   #204
lol which one busted?
 Old 01-03-2012, 06:22 PM   #205
86AmishMs3's Avatar
Groans: 338
haven't taken apart yet, but it looks to be where the coolant in at the bottom of the turbo meets the bigger coolant line. Appears to be leaking right above the wga. so will take of the intake side and while i'm there make me a recirc tube for the inlet.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 01-06-2012, 07:55 AM   #206
why scrapes on side of ms3? cause racecar
 Old 01-06-2012, 05:46 PM   #207
86AmishMs3's Avatar
Groans: 338
that's the way i roll. Oh then i had to run 2 miles to meet a friend so we could push start the car, the battery had died from the emergency lights. Awesome night. Then i got drunk.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
EdgeAutosport.com (01-09-2012)
 Old 01-06-2012, 11:04 PM   #208
jv92red's Avatar
Posts: 319   (View Stats)
jv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the world
Originally Posted by EL F00LI0 View Post
I forgot to mention the turbo I'm going to be using is a journal bearing so I won't be using the coolant lines, ill be routing them together.
Tapatalka
I think the next turbo I slap on will be journal also.
Couple questions:
1) So I assume it's the lower cost up front on a Journal bearing turbo along with the cheaper rebuild & balance ability when they go bad that outweighs all of the the benefits of running a comparable in performance BB turbo? Or is it that these BB GT and GTX Mazda specific kits having the bolt up Mazda specific exhaust housings drive up the cost over comparable standard V-band journal bearing turbos?
2) Please PM me the price on a GT3071 kit. Depending on the price difference with this kit it may be a good choice for me as I'm not looking for the top end #'s I would get with a GTX3071 over a GT3071 and apparently the GTX and GT 3071 models spool the same so hopefully I can save some dorra... Trying to decide between a BNR stg 3 and a GT3071 kit as I still want a quick spooling unit but feel the GT2871 is priced to close to the 3071 unit not to get a 3071 at that negligible price diff so it's either a BNR stg 3 or a GT3071 for me.
Thanks!
jv92red is offline   Reply With Quote
The Following 2 Users Say Thank You to jv92red For This Useful Post:
EdgeAutosport.com (01-07-2012), JP@edgeautosport.com (01-09-2012)
 Old 01-07-2012, 10:56 AM   #209
Originally Posted by jv92red View Post
Couple questions:
Thanks!
pming now!
jv92red (01-09-2012)
 Old 01-09-2012, 06:30 PM   #210
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Thanks!
Thank you! I couldn't have said it better about the price difference between 2871 and 3071. You're right about the spool of the GTX but it will flow much more as you reach higher boost levels. Where the GT starts to level out in airflow, the GTX just keeps going further.
I've never felt a BNR Stage 3 but I'm willing to bet a 3071 feels so much more incredible, even at lower boost levels. The BNR would definitely spool faster but getting used to driving a big turbo showed me how much more I like the driveability of the car with not such quick spool up. It doesn't spool too much slower but the power curve makes it much smoother to accelerate. It doesn't just smack you in the face like the K04 or probly the BNR. Unless you have tons of power and then it still smacks you in the face but just a lot harder lol.
The Following User Says Thank You to JP@edgeautosport.com For This Useful Post:
 Old 01-10-2012, 09:13 AM   #211
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Being that im going to get back into Auto-X im thinking the GTX3071 will be the route i take. I mentioned beofer im looking for ~400 whp. Maybe more now . Anyways what about MAF size? Should i plan on going to a larger MAF? Or is the one on my short ram sufficient? Also i see a lot of the BT guys installing an EGT guage. Can i skate by without one if im running conservative boost levels?
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
EdgeAutosport.com (01-10-2012)
 Old 01-10-2012, 09:55 AM   #212
Well the stock size maf will get you to right around 400 maybe a a little more. If you ever planning on going more then just get a big maf and cal it and re-tune. A 3071 imo would be a great turbo for this car due to spool time and using at auto-x. I auto x my car with the 3076 once with the atp hotside and it marginally slower then the k04 lol
As for running an egt gauge I havent run one in the 15k ive been BT and havent had an issue. I sure have lately beat the piss out of my car racing 135's,335's,s5's and all at heavy wot pulls for extended periods of times on (closed mexico roads of course) I also have a brass egt plug and its only rated for 1750* iirc and it has yet to melt into my turbo so I would say you should be ok.
 Old 01-10-2012, 10:29 AM   #213
Pending a new job ive got an interview for this month, ill be pulling the trigger on this pretty soon. Ill def be looking your way when i do it. Thanks for all of your help!
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following 2 Users Say Thank You to thatsmrgimp2u For This Useful Post:
EdgeAutosport.com (01-10-2012), JP@edgeautosport.com (01-11-2012)
 Old 01-11-2012, 12:07 AM   #214
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
So I am undecided on which size wastegate to run on my build. The other guys running the 5557 are using 44mm wastegates so I was going to run that route but in my build thread I was told to go with 38mm because there are plenty of guys with similar sized turbos using 38mm wastegates who have perfect boost control.
Now idk if the amount of boost determines what size to use but I plan on running at least 25psi maybe 26. if that helps at all.
I am getting my manifold reflanged this month and I need to decide which size to have the wastegate tube flanged to.
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
The Following User Says Thank You to EL F00LI0 For This Useful Post:
 Old 01-11-2012, 07:42 AM   #215
I know what thread you are talking about its rigors. I never really read into why he needed to upgrade to the 44mm besides boost creep and I would have been almost certain the 38mm would have had no problem controlling that issue but I dont know all the details. @rigor was there any other reason you went with the 44mm besides the whole boost creep issue?
 Old 01-11-2012, 10:54 AM   #216
EL F00LI0's Avatar
I think he was trying to troubleshoot his boost creep problems and he started with upgrading the wastegate. I was told he later found out what the issue was or something and it wasn't the wastegate. Idk for sure tho, let's hope he chimes in.
Tapatalka
EdgeAutosport.com (01-11-2012)
 Old 01-11-2012, 06:32 PM   #217
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
not rilly sure the problem, but the 38 mm wg will work but don't plan on running under 26 psi i have the bigger compressor, with the 4'' inlet, plus my wg is 90 degrees off the mani so flow isn't ideal, also the center of the collector hung way down, blocking flow to the wg from 2 cyls.
so i changed wg to 44mm and raised the center of the collector, and it was fine..
still couldn't run under 20 psi
and now i run 26psi so hmmm lol
if you look in the hole you see the collector hanging down
at 104000 2 bent rods
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
EdgeAutosport.com (01-12-2012), JP@edgeautosport.com (01-11-2012)
 Old 01-11-2012, 10:35 PM   #218
EL F00LI0's Avatar
Yeah I have just the standard 5557, no 4" inlet. I'm having my mani reflanged and a wastegate tube welded on so ill have them make sure there's good flow going to it.
Tapatalka
 Old 01-12-2012, 07:40 AM   #219
Yeah EWG Flange placement is key. Glad you got it all figured out EL Foolio
 Old 01-12-2012, 10:48 AM   #220
EL F00LI0's Avatar
Thanks, wouldn't be from the help of this thread though lol. The build should be coming together a lot quicker now that I have everything planned/figured out and the holidays are over so my wallet can recoup lol.
Tapatalka
 Old 01-12-2012, 07:42 PM   #221
VRMSPD6's Avatar
Posts: 64   (View Stats)
VRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond reputeVRMSPD6 has a reputation beyond repute
Couple questions:
Thanks!
I'm with this guy.. I'm not looking for anything crazy, so the benefits of a GTX over a GT don't really concern me too much (I'd even go with a 2871 BB turbo if the price was right), but I called BNR today and with the price of a stage III, it's almost worth it to go with an ATP. I know this has prob come up, but whats the life span of one of these BB BT's? I can't see me being very aggressive with a tune on a daily basis. This is my dd so I need to make sure I keep that in mind. I know a stock turbo at 20 psi will not last as long as I want. I would also need a bigger inlet pipe to switch over, so that also adds to da moneyz.. Does anyone offer a IP + BT package? I have all the other supporting mods, but that's the only thing I need really. Will any 4" inlet pipe work w my CP-e CAI. Or do I need to buy the CP-e one?
So I guess moral of the story is.. I need a price on a GT3071 + 4" inlet pipe. or a 2871 + whatever inlet pipe I need for that if I can't use my current one.
'06 Velocity Red Mica SPEED6
Bolt-on's:
CP-e Cold Air, CP-e 3" turbo Back, KMD Internals, SURE RMM, Jugg/Dread, CP-e FMIC, COBB AP
Engine:
Darton MID sleeves done by CNC Engine Dynamics, Wiseco pistons, Carrillo Super-A rods, BSD, Clevite main bearings, OEM rod bearings, CP-E safeseals, ATP/Garrett IWG GTX3071r, COBB EBC, ACT streetlite/streetdisk.
Evan's Tuning - ET Pro Tune 335 AWHP, 358 ft-lb torque @ 19 lbs (Stock mani's, No meth)
VRMSPD6 is offline   Reply With Quote
The Following User Says Thank You to VRMSPD6 For This Useful Post:
EdgeAutosport.com (01-13-2012)
 Old 01-12-2012, 10:53 PM   #222
EL F00LI0's Avatar
Theres a used 2871r on sale in the fs section right now for $1k
 Old 01-13-2012, 08:09 AM   #223
Well the best price for the 3071 is 1549.00 shipped. As for using any tip that will work without a problem on your cpe cai. You could realistically use your tip you have now just buy the 4''-2'' reducer coupler. The life span of these turbos is really unknown but ive read guys going 30k+ on them without a problem.
I only have 15k on my setup and I have yet to have a problem. The most important factor that seems to come up is reliability and I dd my car just like everyone else and just as long as you maintain your car you will have no problem with it. IMO this turbo is safer then the k04 because the boost doesnt come on so fast and you get all of that low end torque putting stress on your rods.
 Old 01-13-2012, 08:23 AM   #224
trf5000's Avatar
Posts: 2,290   (View Stats)
So maybe this has already been asked and I apologize, but I am thinking about doing a stock flange gtx3071 IWG. How difficult is it to port the IWG to allow for better boost control?
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
EdgeAutosport.com (01-13-2012), rfinkle2 (01-31-2012)
 Old 01-13-2012, 08:26 AM   #225
Fairly easy. Just remove the hotside (6 1/2 inch bolts) and take a dremel with the proper bits and go to town.
trf5000 (01-13-2012)
 Old 01-19-2012, 08:09 AM   #226
ttt
 Old 01-19-2012, 11:29 AM   #227
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
EdgeAutosport.com (01-19-2012)
 Old 01-19-2012, 11:33 AM   #228
@Tomas is that your old hotside? Is that a crack at the top right side left of the stud?
Tomas (01-19-2012)
 Old 01-19-2012, 11:43 AM   #229
Bob Ross Fanclub
Tomas's Avatar
Yup. It's the old hotside.
Not cracked. Just a little dinged from the install back then.
Not everything that looks like crack is real crack. lol
 Old 01-19-2012, 11:46 AM   #230
Oh gotcha. So you have the new turbo in already? Did you also port the iwg whole?
 Old 01-19-2012, 11:56 AM   #231
Bob Ross Fanclub
Tomas's Avatar
yes and yes. With my small mechanical penis and the corresponding grinding tool attachment.
Thanks for great service, fast delivery, and good deal by the way.
 Old 01-19-2012, 01:05 PM   #232
stavros's Avatar
Posts: 53   (View Stats)
stavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant futurestavros has a brilliant future
ok edge working so i dont have time to read so here we go:
just blew the turbo in my speed. looking to get the turbo, do you guys sell the TIP that will fit in my car to the intake? do i need a different mani/dp? once installed can i take drive this car to get it tuned? my mods are sri tip 3'dp 3'exhaust HPFP internals (from you all) AP and front mounted... so would i just need the turbo and pipe.
pm me with a price on what i would need. and if anyother that bolt up to the car can i get those prices as well. thanks guys!
CS FMIC,SRI,TIP. Autotech HPFP. Magnaflow 3' CBE. Cobb AP.
On the way: Cobb DP, +1 colder plugs
Future: JB mounts, CS lowering springs
stavros is offline   Reply With Quote
The Following 2 Users Say Thank You to stavros For This Useful Post:
EdgeAutosport.com (01-19-2012), JP@edgeautosport.com (01-22-2012)
 Old 01-19-2012, 01:29 PM   #233
pming now
 Old 01-28-2012, 06:45 PM   #234
BMON3YZOOMIN's Avatar
Posts: 79   (View Stats)
BMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the worldBMON3YZOOMIN is the leader of the world
ok iv been getting some supporting mods, and im almost ready to pull the triggor on the bt.
Im interested in gtx3076 or gtx35r
need price with 4 in tih & cpe front mount. Thanks
Tuned by Phate.
BMON3YZOOMIN is offline   Reply With Quote
The Following User Says Thank You to BMON3YZOOMIN For This Useful Post:
EdgeAutosport.com (01-31-2012)
 Old 01-28-2012, 07:17 PM   #235
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
Eric can I get a price for a GTX3076 kit for my RR manifold also FRMIC pipping for my genpu. thanks
The Panda is offline   Reply With Quote
The Following User Says Thank You to The Panda For This Useful Post:
 Old 01-28-2012, 09:20 PM   #236
EL F00LI0's Avatar
I wanna upgrafe my rods before my build was thinking of going with eagle h beams. Would you guys recommend going rods + pistons or just rods? Also what am I going to need to supply the shop who's replacing them with? Gasket? Oils? Studs?
Sent from my BlackBerry 9300 using Tapatalk
 Old 01-31-2012, 08:31 AM   #237
pming both now!
 Old 01-31-2012, 01:48 PM   #238
EL F00LI0's Avatar
The prices on your site are the same your pming us correct? Or could you hook it up even more??
 Old 01-31-2012, 01:49 PM   #239
I can hook you up even more
Lakespeed6 (01-31-2012), rfinkle2 (01-31-2012), thehead (02-20-2012)
 Old 01-31-2012, 02:20 PM   #240
I know @driver311 is porting manifolds on the side, ported his own gtx3071, and may be available for porting the gtx3071 if you throw him a few bucks.
I've been thinking about doing the same thing LOL.
EdgeAutosport.com (01-31-2012), thehead (02-20-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.61218 seconds with 34 queries
