Like Tree23Likes
 Old 01-31-2012, 02:37 PM   #241
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Originally Posted by eric@edgeautosport View Post
I can hook you up even more
Fuck yes! Will contact you as soon as my turbo sells.
Sent from my BlackBerry 9300 using Tapatalk
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
The Following User Says Thank You to EL F00LI0 For This Useful Post:
EdgeAutosport.com (01-31-2012)
 Old 02-01-2012, 01:30 PM   #242
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
How bout you hook me up with a package deal!
GTX3076, Intake and TB gasket, EGR Block off, Turbo inlet, Injector seals, Devils own meth, and some Denos plugs.
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following User Says Thank You to Lakespeed6 For This Useful Post:
EdgeAutosport.com (02-01-2012)
 Old 02-01-2012, 02:20 PM   #243
pming now
Lakespeed6 (02-01-2012)
 Old 03-16-2012, 01:50 PM   #244
Manny3's Avatar
Posts: 815   (View Stats)
Manny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the world
Eric you have an idea to run the gtx3076 ewg with oem ebcs until I get that grimmspeed in next week? Thanks
09 CWP MS3 sold
15 DCB Mazda 6
Manny3 is offline   Reply With Quote
 Old 03-16-2012, 02:01 PM   #245
Just run spring pressure on your ewg til you get it in
Broxer (03-23-2012)
 Old 03-16-2012, 02:04 PM   #246
Manny3's Avatar
Thank you sir
09 CWP MS3 sold
15 DCB Mazda 6
The Following User Says Thank You to Manny3 For This Useful Post:
EdgeAutosport.com (03-16-2012)
 Old 03-23-2012, 01:36 PM   #247
@Manny3 how did you mount your tr8 core?
 Old 03-23-2012, 05:10 PM   #248
Manny3's Avatar
The battery on my camera just went out so I was able to take one pic hope it makes sense, the bottom hole I readjusted towards the passenger side and the top I left on the original position and added and extension with a bracket to support the top.
09 CWP MS3 sold
15 DCB Mazda 6
JP@edgeautosport.com (04-02-2012)
 Old 03-23-2012, 05:25 PM   #249
drenkel's Avatar
Posts: 604   (View Stats)
drenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the world
Groans: 42
Groaned at 53 Times in 14 Posts
@eric@edgeautosport
I'm wanting to upgrade to a GTX3071... power goals are a modest 400 WHP so I don't have to build the engine.
Can you please take a look at the mods in my sig, and PM me a quote that includes the turbo, and the supporting mods I'll need to make it all work? I'm not sure if EWG or IWG is easier for installation, I'll take your advice on this part. Please set me up with the parts I will need for the easiest installation to meet my 400 WHP goal.
Thanks in advance!
Sold: 2010 MS3 - I'll miss ya
Now: 2013 Mustang GT
drenkel is offline   Reply With Quote
The Following User Says Thank You to drenkel For This Useful Post:
 Old 04-01-2012, 09:37 PM   #250
Gen2Mobbin575's Avatar
Posts: 34   (View Stats)
Gen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant futureGen2Mobbin575 has a brilliant future
Eric did a fantastic job in supplying me with the list of goodies for my gtx3076 build. The easiest route keeping the mazda hotside. Even running the new FullRace Manifold Gonna be a 450ish whp dd. BALLLIN
Gen2Mobbin575 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gen2Mobbin575 For This Useful Post:
EdgeAutosport.com (04-02-2012), JP@edgeautosport.com (04-02-2012)
 Old 04-10-2012, 08:04 AM   #251
865ms3's Avatar
Posts: 2,602   (View Stats)
im going to order the gt2871r today. what size coupler do i need to order to run the cobb turbo inlet? 3-2? also what is the outlet size? im sure i need a coupler for my fmic piping also. thanks!
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
EdgeAutosport.com (04-10-2012)
 Old 04-10-2012, 08:22 AM   #252
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Get the GTX2867r.... You will need a 3" to whatever size the cobb inlet is. You will need a joiner that is the same ID as the cobb inlet as well.
Scoobs likes this.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 3 Users Say Thank You to Broxer For This Useful Post:
atvfreek (04-10-2012), EdgeAutosport.com (04-10-2012), Scoobs (04-17-2012)
 Old 04-10-2012, 10:59 AM   #253
This guys is getting a great turbo!
865ms3 (04-10-2012)
 Old 04-10-2012, 11:10 AM   #254
beno72's Avatar
Posts: 100   (View Stats)
beno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond reputebeno72 has a reputation beyond repute
Hey Eric, I started another post, but I just came across this one, need your advice, I have a GT3071r, and bnr s3, trying to decide which one to install, I am a little worried about the gt issue of boost spike. My goals are 370 to 380whp, I am fully modded. I do not want to change my gt turbo to ewg, so do you think I will have an issue with the gt, or just go with the BNR, need to take into account I do not have E85 gas around, there is one station in MA, but it is a half hour away, thanks
beno72 is offline   Reply With Quote
The Following User Says Thank You to beno72 For This Useful Post:
 Old 04-10-2012, 11:19 AM   #255
Go with the GT for sure. At those power levels you wont need to push crazy amounts of psi so boost spike wont be an issue. Also keep in mind the GT is also ball bearing so longevity is also a factor. I would say go with the GT all day man you will love the turbo and make the car much more enjoyable to drive not getting into boost every .2 seconds.
 Old 04-10-2012, 11:45 AM   #256
865ms3's Avatar
thanks again for the help.
EdgeAutosport.com likes this.
Brent
Dragon Slayer Setup
FreekTuned
 Old 04-10-2012, 12:50 PM   #257
beno72's Avatar
Thanks Eric for the input, so I will need a few things from you to order, the CPE TIP, and what ever you recommend for an intake, do you think a 3" intake would be better. Also I have the turbo but I am not sure what else I need so if you can come up w a part list with prices, i know i need a boost tap, step down studs, coolant flex hose, I do have a grimmspeed ECB, and if you want to pm me so I can paypal the payment over to you would be awesome, thanks
 Old 04-23-2012, 12:25 PM   #258
uberspeed3's Avatar
Posts: 18   (View Stats)
uberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud ofuberspeed3 has much to be proud of
Noob Question! When I bought my MS3 it already had an upgraded ATP turbo installed and I want to know which one it is (ie. GT2871R, GT3076R, GT35R, ect...) I looked at the plate in between the compressor side and exhaust side and it didn't have any of those model numbers on it. Is there anyway to tell which one I have? Thanks!
2008 Mazdaspeed3 (Metropolitan Gray Mica)
ATP GT3071R, CP-E ΔCore FMIC, TurboXS 3" CBE, TurboXS 3" catless DP, CP-E Xcel CAI, ATP 3" TIP, SURE Torq R3, SURE Anchors, Turbosmart Dual Port BOV, StreetUnit STS
uberspeed3 is offline   Reply With Quote
The Following User Says Thank You to uberspeed3 For This Useful Post:
EdgeAutosport.com (04-23-2012)
 Old 04-23-2012, 12:32 PM   #259
what numbers are on that plate? post them up
 Old 04-23-2012, 12:44 PM   #260
uberspeed3's Avatar
Its hard to see down there but it looks like NHM 4564 700177-5023
 Old 04-23-2012, 12:50 PM   #261
hmmm something may be off on that. try and take a picture
JasonMzdSpd3 (04-23-2012)
 Old 04-23-2012, 01:12 PM   #262
uberspeed3's Avatar
I got some pics but I cant find the cable for the camera (not my camera haha) as soon as i find it I'll post them
The Following 2 Users Say Thank You to uberspeed3 For This Useful Post:
EdgeAutosport.com (04-23-2012), JasonMzdSpd3 (04-23-2012)
 Old 04-23-2012, 04:15 PM   #263
uberspeed3's Avatar
OK heres some pics. Hopefully these help.
 Old 04-23-2012, 04:28 PM   #264
Edit you have a gt3071
SarcasticOne (04-23-2012), uberspeed3 (04-23-2012)
 Old 04-23-2012, 04:38 PM   #265
uberspeed3's Avatar
wow that was a bitch to get to with a flashlight and mirror haha but its a .50
How did you figure that? Just curious?
Last edited by uberspeed3; 04-23-2012 at 04:38 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-23-2012, 04:47 PM   #266
part # 700177-5023
uberspeed3 likes this.
 Old 04-23-2012, 04:58 PM   #267
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
There are some exhaust manifold + EWG combos that won't give enough clearance for a TMIC right?
 Old 04-23-2012, 05:00 PM   #268
None that I know of. What is this sorcery you speak of?
breakfstincluded (04-25-2012)
 Old 04-23-2012, 05:03 PM   #269
uberspeed3's Avatar
part # 700177-5023
Haha that makes hella sense thanks a lot for your help
 Old 04-25-2012, 02:20 PM   #270
hehe well I just noticed like the steedspeed EWG look like it might protrude into where a TMIC would be, and that's why I can only find pics of the steeedspeed EWG with FMIC setups.
Or maybe everyone with a steedspeed is smart and knows how much more beneficial a FMIC is unlike me (:
 Old 04-25-2012, 02:23 PM   #271
@triplejumper18 runs this same setup. Havent you seen his car a million times lol
 Old 04-25-2012, 08:05 PM   #272
LOL oh right haha thanks eric (:
EdgeAutosport.com (04-25-2012)
 Old 10-23-2012, 09:44 AM   #273
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
6 month bump.
With the current mods I have (see signature) and add a CP-E TMIC/Cobb BPV... If I drop in a GTX3071R + 38mm EWG, and the JBR 3.5" BT intake, and EBCS what kind of numbers could I be expecting? 400ish?
Here's my dyno from a few months ago, you can see the print out about halfway down the sheet. 2010 Speed3 Dyno @ Corksport On these dyno pulls I was running an unfinished tune with mis-gapped plugs. Plugs are now gapped properly and the tune is done. Rough estimate of numbers I could be seeing with the BT?
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
The Following User Says Thank You to Dumyz For This Useful Post:
EdgeAutosport.com (10-23-2012)
 Old 10-23-2012, 09:57 AM   #274
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Go fmic. I don't know what you're using for fuel but I don't think you'll see over 400 on pump/e85 without supplemental meth or 5th port
Sent from my iPhone your mom's face
07 MS3
The original Genpoo Hater
BPASPEED (10-23-2012), rfinkle2 (10-23-2012)
 Old 10-23-2012, 10:00 AM   #275
I ran over 400whp with just 2.5 gallons of e85 Depends on the tune really and how much psi you want to run.
 Old 10-23-2012, 10:04 AM   #276
trf5000's Avatar
Posts: 2,290   (View Stats)
Eric.......GT3071 vs. GTX3071. Whats the major differences from a practical power perspective?
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following User Says Thank You to trf5000 For This Useful Post:
 Old 10-23-2012, 10:08 AM   #277
Like overall top end goal or power under the curve? Honestly a regular 3071 will suit a majority of peoples power hunger. I meant it really depends on how much psi you want to run out of a specific turbo to get what you want out of it.
For example me 3076r at 22psi felt pretty good. At 24psi it felt amazing and when I was running 27psi it really shined. If you plan on sticking with no more than 25psi the 3071 will suit you just fine but its when you get a little greedy with the boost the GTX wheels really shine up top
Dumyz (10-23-2012), trf5000 (10-23-2012)
 Old 10-23-2012, 10:24 AM   #278
Dumyz's Avatar
Groans: 27
FMIC = More moniez. I would go with a TR8 or TR11 if I could find a piping kit that wasn't so expensive, if there are any kits out there for gen pu that are less than let's say... 150 I'd probably do it.. If I'm going to buy a FMIC I want to do it right the first time and not have to worry about buying a bigger/better one down the road. After I put in the turbo I'd most likely be getting Devil's Own to help out.
 Old 10-23-2012, 10:30 AM   #279
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Fmic helps with every day bat's. you don't want to rely on a chemical intercooler, use it as an assist. Do it right the first time even if it means saving a little longer for the BT
07 MS3
anavrinIV (10-23-2012), rfinkle2 (10-23-2012)
 Old 10-23-2012, 10:34 AM   #280
Dumyz's Avatar
Groans: 27
Well I'd be getting an IC before I went meth of course, but I just need a reliable piping kit that is cheap as well. 450 for CX is a bit absurd...
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.59163 seconds with 34 queries
