Like Tree12Likes
 Old 01-22-2013, 11:21 AM   #121
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
Originally Posted by BlckMS3 View Post
what exactly comes in the ATP GTX3071 Kit??? i have a Tial MV-S wastegate already, does it comes with a EWG hotside and dumptube??
Yes, comes with dump tube and EWG hot side.
You would know if you read the parts listing on their website.
Get yourself a new oil return line as well. ATP can't even supply a properly sized one.
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 01-22-2013, 11:41 AM   #122
BlckMs3's Avatar
Posts: 769   (View Stats)
BlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the world
Groans: 30
Im not new at this but maybe im blind but could not find a parts list anywhere, even on atp's website...and is the dump tube v banded for 38mm
Stance will make her dance, but boost will make her sploosh
[12:57 PM] Enki: kim should sell her used tampons to msf as fresh teabags
2007 Mazdaspeed3 SOLD
2014 Mustang GT
BlckMs3 is offline   Reply With Quote
 Old 01-22-2013, 12:09 PM   #123
GunGuru727's Avatar
Groans: 38
Look on Edge's website...it will be right there.
5/14/14 - 12.4@110
E85 FreekTune
 Old 01-22-2013, 12:21 PM   #124
slikr's Avatar
Posts: 791   (View Stats)
slikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the worldslikr is the leader of the world
I don't like the way the drain line fits with the EWG on the one that was provided, is there another alternative?
[/B]//2012 CWP Mazdaspeed 3 \\[/CENTER]
slikr is offline   Reply With Quote
 Old 01-23-2013, 12:12 AM   #125
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
have a GT3071r, was looking at this:
Kit Upgrade Charge, upgrade GT3071R in turbo kit to GTX3071R : atpturbo.com
would it fit?
think the compressor housing on the GTX is a 0.6 A/R vs the GT's 0.5 A/R, is this likely to cause any issues?
 Old 01-25-2013, 01:09 PM   #126
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
would it fit?
This is a common misunderstanding. It's actually a different turbo altogether. You can only "upgrade" at the time of purchase. It's a new CHRA as well so it's not as easy to think of as what it seems. You'll need this if you want a GTX upgrade from what you currently have.
Garrett GTX3071R Dual Ball Bearing Turbo : atpturbo.com
The Following 3 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
BlckMs3 (01-25-2013), SarcasticOne (01-25-2013), silvapain (02-25-2013)
 Old 01-25-2013, 01:20 PM   #127
BlckMs3's Avatar
Groans: 30
This is why everyone loves you
2014 Mustang GT
 Old 01-25-2013, 01:27 PM   #128
Do you have the compression style fittings? If so, the hydraulic fittings would be better for fitment. They're a little slimmer. They look like this. I have tried to ask ATP to start sending these with their kits but they won't.
Oil Return Line -10 - 12" ST/ST : atpturbo.com
 Old 01-25-2013, 11:29 PM   #129
slikr's Avatar
yea it doesnt look like that, mine look just like mike and casey's did. I had my leak from the first start up from the oil drain on the turbo side and casey ended up fixing it because it happened to hers too.
 Old 02-25-2013, 02:37 PM   #130
Bumpskis! It really isn't that hard to get 400whp compared to many other platforms. Stick one of these ATP Turbo Bolt-On Turbo Kits on and you'll thank me forever.
Year - 2007 - Mazda - Mazdaspeed 3 - Turbo - Turbo Kit - EdgeAutosport.com
There are many options between EWG and IWG and from GT28-35 and GTX28-35. Get you some powa!
atvfreek (02-25-2013), DSIT995 (02-25-2013), silvapain (02-25-2013)
 Old 04-10-2013, 10:57 AM   #131
IamJamen's Avatar
Posts: 789   (View Stats)
Hi duders,
I am hoping one of you guys can PM me a quote for a GTX3071R IWG and any gaskets, studs, nuts, and hoses needed for installation. I also need a quote for a GT3071R IWG and gaskets, studs, etc.
Mazda is dicking me around on my extended warranty and is now saying they are not going to replace my smokey K04 after approving the work weeks ago.
Cheers!
@EdgeAutosport.com
@JP@edgeautosport.com
The Following User Says Thank You to IamJamen For This Useful Post:
Funkster777 (04-10-2013)
 Old 04-10-2013, 11:02 AM   #132
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Originally Posted by IamJamen View Post
Hi duders,
Cheers!
@EdgeAutosport.com
Hellz yeah man. Do it up.
 Old 04-15-2013, 10:47 PM   #133
LumberJack's Avatar
Groans: 57
Well, if everything goes as planned. Should be ordering a full GTX3076 EWG setup and a Devils Own dvc Stage 2 meth kit by the end of the month to take advantage of the tax refund sale! @EdgeAutosport.com;
10.36@148 Fastest Gen 2
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
EdgeAutosport.com (04-16-2013), lilred (04-15-2013), Little John (04-15-2013)
 Old 04-15-2013, 11:00 PM   #134
lilred's Avatar
Posts: 5,792   (View Stats)
Order me a meth kit while you're at it too
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
LumberJack (04-15-2013)
 Old 04-15-2013, 11:15 PM   #135
LumberJack's Avatar
Groans: 57
tapafuck
Hahahaha! I wish I was that ballin! It's about 80% sure this is going to happen by the end of the month. Just hoping the money situation plays out
 Old 04-16-2013, 07:04 AM   #136
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
The extended warranty expired at 140,000 KM's or 86991.9669 it converts to on google lol, or till 2013 (which ever came first)
Performance:
Stratified Tune in progress
 Old 04-22-2013, 03:23 PM   #137
IamJamen's Avatar
BT setup is ordered... broke feeling has ensued.
EdgeAutosport.com (04-29-2013)
 Old 06-14-2013, 09:29 AM   #138
Just thought I'd put a little life into this thread. Big turbos are easier to install and better to drive than most people come to us thinking they are. Just call us and talk to us. Ask us about what you need. These Garrett turbos are great and you won't regret spending the money or pushing the extra power. Get a big turbo, get your tune right, and all your other problems go away....
These GTX28Rs have become more popular too ever since we teamed up with @atvfreek; to get some results. You don't have to go crazy just because you're going big turbo. Reliability can be maintained and you don't have to have 400whp+ to have fun. You'll just have more fun.
JP
atvfreek likes this.
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
atvfreek (06-14-2013), DSIT995 (06-14-2013), Lex (06-14-2013), Poohster (06-14-2013), SpeedRebirth (06-14-2013), YABBAMZR (06-14-2013)
 Old 06-14-2013, 03:00 PM   #139
blkspeed307's Avatar
Posts: 509   (View Stats)
blkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the world
JP
JP & Allen will definitely set u on the right
BT path , very knowledgeable guys & great 2 deal with .
Also great prices.
blkspeed307 is offline   Reply With Quote
The Following User Says Thank You to blkspeed307 For This Useful Post:
EdgeAutosport.com (06-18-2013)
 Old 06-14-2013, 03:14 PM   #140
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
^truth
I was talking to them, and i kinda felt like i was being talked into something, but in hindsite, i'm glad i changed from my other path. These guys know there shit!!!
99 miata: sold
The Following 2 Users Say Thank You to Mortose For This Useful Post:
atvfreek (06-14-2013), EdgeAutosport.com (06-18-2013)
 Old 06-17-2013, 06:46 PM   #141
yanikemt's Avatar
Posts: 52   (View Stats)
yanikemt is a jewel in the roughyanikemt is a jewel in the roughyanikemt is a jewel in the roughyanikemt is a jewel in the rough
Quote on a IWG setup with a GTX2867 it is time for a bt!
2012 MS3 Velocity Red w/Tech
Cobb AP | Ultimate Racing DP and TP | CorkSport CBE | GoFastBits Hybrid BOV | HTP Full 3in. Intake | Autotech Internals | JBR RSB | JBR 88-RMM | Saikou Michi OCC | Stratified EBCS | | 3 Bar MAP Sensor | GTX 2867R BT | ProSport Gauges | Tint | Rally Armour Mudflaps | DDM Tuning HID Fogs | Corksport Tow Plate | Rockford Fosgate P1-12'
Stratified Tuned
yanikemt is offline   Reply With Quote
The Following 4 Users Say Thank You to yanikemt For This Useful Post:
atvfreek (06-17-2013), EdgeAutosport.com (06-18-2013), LumberJack (06-17-2013), Mortose (06-17-2013)
 Old 06-17-2013, 07:18 PM   #142
Mortose's Avatar
Groans: 39
You won't be disappointed!
Give it a little tappy, a tap tap tap-a-roo
99 miata: sold
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbos-gt-gtx-available-now-82384/
Access port & KMD internals have arrived - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 01-03-2013 09:25 PM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 10:22 AM
What about these turbos? trigun22 Mazdaspeed3/6 General Discussion 7 12-01-2010 05:50 AM
ATP improved their turbos IWG?? Joern MazdaSpeed 3/6 - Big Turbo Builds 10 06-03-2010 03:15 PM
MS3 vs. VW Bug TurboS FridayGt Street Racing Stories ( Bench Racing ) 37 04-25-2010 07:47 PM
OBX Turbos manofhonor24 MazdaSpeed 3/6 - Turbo Induction 8 06-07-2009 12:16 PM
Page generated in 0.46603 seconds with 33 queries
