  • 2 Post By JgamB
 Old 05-26-2015, 02:50 PM   #1
Default BNR Turbos now In Stock at EdgeAutosport!
By now, everyone has heard of the BNR turbo upgrade for the Mazdaspeed 3 and 6. It is a lower cost turbo upgrade that offers a pretty decent bang for the buck. $1099 gets you a nice boost in performance and offers a great replacement for the stock K04.
The benefit of the BNR upgrade is the increased shaft size, shorter shaft, bigger bearings, better thrust bearing assembly, better turbine wheel, and more efficient compressor wheel. These things combine to make for a much more reliable turbo. No question this upgrade is far more superior to the original equipment turbocharger on the Mazdas.
One of the most appealing aspects of the BNR turbo is the stock turbo like response with the added top end performance. It will change the way your Mazdaspeed drives, but only for the better!
Make sure you click the pictures to read more about this turbo on our website!
BNR Stage 3 Turbo Kit - $1099
JgamB (05-27-2015), Micha (05-27-2015), NavySailorMS3 (05-27-2015), tegxsi (05-27-2015), Thepedigree13 (05-26-2015)
 Old 05-27-2015, 09:08 AM   #2
JgamB's Avatar
Posts: 2,566   (View Stats)
About that bang for the buck
atvfreek and Code Monkey like this.
The Following 11 Users Say Thank You to JgamB For This Useful Post:
Addikted To Boost (05-27-2015), atvfreek (07-17-2015), Code Monkey (05-27-2015), dale_gribble (09-29-2015), EdgeAutosport.com (05-27-2015), Micha (05-27-2015), neganox (05-27-2015), razerer (05-27-2015), Rich990 (05-27-2015), speed23 (05-27-2015), SuckSqueezBangBlow (05-27-2015)
 Old 05-27-2015, 10:47 AM   #3
Thank you for posting that! Very good illustration as to the gains you can expect with this setup!
JgamB (05-27-2015)
 Old 05-27-2015, 10:58 AM   #4
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
Hot damn, I may have to hop on this. Thanks JgamB for the posts! Makes me realize how much my K04 is a restriction
The Following 2 Users Say Thank You to SuckSqueezBangBlow For This Useful Post:
EdgeAutosport.com (05-28-2015), JgamB (05-27-2015)
 Old 05-27-2015, 12:29 PM   #5
JgamB's Avatar
I used STD smoothing 1 because this dyno reads a bit low - SAE smoothing 5 is 370/374, but a bolted and tuned Coyote made 370/370 on it as well. Trap speeds back up the STD numbers with 117.92 @ 3487lbs 2800 DA. Coupled with the awesome Freektune, it does some work for a little big turbo.
 Old 05-28-2015, 04:42 PM   #6
We have got these on the shelf guys!
 Old 06-03-2015, 01:35 PM   #7
This will cure your smokey stock turbo...
Micha (06-10-2015)
 Old 06-09-2015, 02:21 PM   #8
We got these on the shelf and ready to ship! No need to wait for a drop ship!
Micha (06-10-2015)
 Old 06-10-2015, 12:15 PM   #9
RusianKid's Avatar
Posts: 353   (View Stats)
RusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the world
Are you having any boost creep issues with the 3"WP and catless DP?
"RACING IS AN ADDICTION CURED ONLY BY POVERTY"
RusianKid is offline   Reply With Quote
 Old 06-10-2015, 01:53 PM   #10
JgamB's Avatar
Negative. It was tuned with a single cat. 0 WGDC yielded 13 on spool, walked up to ~14.5 by ~6K RPM.
I swapped to a catless DP after the fact, didn't contact my tuna. It was holding 24.5psi, now it's a fuzz over 25psi, but spools more quickly and makes a shitload more power throughout. Torque also increased into the somewhat ass puckering range ~390wtq. If/when I ZZB, it sure won't be my tuners fault
You can plainly see BEC intervention on the top 3 pulls, trying to make it play within boost targets.
RusianKid (06-10-2015)
 Old 06-10-2015, 02:45 PM   #11
RusianKid's Avatar
That is great to hear!
I really don't want to get rid of my UR V2 catless DP.
Thank you for the detailed response!
The Following User Says Thank You to RusianKid For This Useful Post:
JgamB (06-10-2015)
 Old 06-17-2015, 01:45 PM   #12
We've got these on the shelf ready to ship! Great replacement for a smokey stock turbo!
 Old 07-17-2015, 09:57 AM   #13
Bolt on a little extra power with a BNR Turbo!
 Old 08-19-2015, 10:04 AM   #14
Got plenty of S3's in stock, but I'm definitely looking forward to seeing some S4's!
 Old 09-21-2015, 11:05 AM   #15
Great little turbo upgrade here! Especially for the price! And they are in stock and ready to ship!
 Old 09-29-2015, 02:11 PM   #16
S4's have been ordered along with more S3's. We'll be keeping them in stock.
JgamB (09-30-2015), Mazdazilla6 (09-29-2015), Thepedigree13 (09-29-2015)
 Old 09-29-2015, 03:22 PM   #17
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I love me some BNR turbo. FYI, for anyone interested, I just got my BNR S3 through a strict emissions visual inspection with ease; the stock TIP can be adapted to fit the BNR S3 inlet and the turbo looks bone stock.
MINI H1 6.0 - CAR LED TAILS
EdgeAutosport.com (09-30-2015), ItsNox (09-29-2015), JgamB (09-30-2015)
 Old 09-30-2015, 11:14 AM   #18
That is good to know!
 Old 10-14-2015, 03:37 PM   #19
Had a local just put down 397whp with a little e mix on the S4. So far, its looking like a pretty solid turbo!
JgamB (10-14-2015), Mazdazilla6 (10-14-2015), Thepedigree13 (10-14-2015)
 Old 10-14-2015, 07:43 PM   #20
speedfreak44's Avatar
Posts: 1,391   (View Stats)
How the hell did you get 2.25" over 3"?
Edit: @dale_gribble;
The line up:
 Old 10-15-2015, 08:14 AM   #21
I'm not sure what you are referring too?
 Old 10-15-2015, 08:28 AM   #22
^ Most likely to @dale_gribble;'s comment.
EdgeAutosport.com (10-16-2015), speedfreak44 (10-15-2015)
 Old 10-15-2015, 10:50 AM   #23
JgamB's Avatar
S3 = 2.46" inlet, S4 = 3" inlet.
You can get the 2.25 on the S3 but it's a tight squeeze. I've done it a few times, including my own car.
 Old 10-15-2015, 11:25 AM   #24
Was always under the impression the s3 was 2.8". Makes sense now.
The line up:
 Old 10-28-2015, 12:01 PM   #25
S4's are on the shelf and S3's are on the way.
The S4 will be $1249 and include the 3 bar map sensor, harness, and an EBCS.
Gorky_Park (12-22-2015), JgamB (10-28-2015)
ATP Bolt On Turbos At EdgeAutosport EdgeAutosport.com EdgeAutosport.com 60 09-17-2015 01:29 PM
Stock smoking turbos? TheDoc MazdaSpeed 3/6 - Turbo Induction 82 10-26-2009 08:33 PM
PG Reworked stock turbos? Yahdy Ras MazdaSpeed 3/6 - Turbo Induction 16 05-19-2008 06:36 PM
Page generated in 0.44629 seconds with 26 queries
