Like Tree11Likes
 Old 02-22-2012, 06:12 AM   #121
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Originally Posted by 2.3speed06 View Post
If you wanna run the stage two maps in the AP all you need is the HFHP right? My friend keeps saying that you have to have that and a down pipe. I never heard this n was wondering if that's the case.
Read COBBs website. I believe they say you need a DP for all stage 2 canned tunes.
Tapadatass
 Old 02-22-2012, 09:02 AM   #122
Bob-o's Avatar
Posts: 1,312   (View Stats)
@David@COBB
I also heard from a friend that whats listed does not include a DP/cat delete. Just a HPFP. Can anyone verify?
 Old 02-22-2012, 09:14 AM   #123
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Originally Posted by Bob-o View Post
@David@COBB
It's implied with the Downpipe that you'll need a HPFP. Extra flow/boost means more fueling requirements to hit target AFR. You *could* run stage2 maps, but it's risky and not very consistent.
-David@COBB
The Following User Says Thank You to Cobb Tuning For This Useful Post:
Bob-o (02-22-2012)
 Old 02-22-2012, 09:22 AM   #124
Tapadatass
Saying what Silvapain said in a different way:
The document state that if you delete either of the 2 cats, you will need a HPFP.
After deleting one of the 2 cats and adding a hpfp... Cobb recommends their stage 2 tune.
This is the document which we are getting that info from:
http://accessecu.com/support/docs/su...%20Support.pdf
Bob-o (02-22-2012), breakfstincluded (04-06-2012), silvapain (02-22-2012)
 Old 02-22-2012, 02:21 PM   #125
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
Thanks for the link. Didn't know stage two was intended to have a down pipe.
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 02-22-2012, 02:30 PM   #126
bigriver's Avatar
Posts: 1,123   (View Stats)
Either a down pipe or a race pipe. Just need to delete one of the oem cats.
Here is another link which is on Cobb's Forum
2010 MAZDASPEED3 AccessPORT FAQ - Start Here for 2010 MS3 AP Questions!
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
rfinkle2 (02-22-2012)
 Old 02-28-2012, 01:33 PM   #127
pcvang's Avatar
Posts: 111   (View Stats)
pcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the world
Alright so BT ?'s, I've heard someone mention if they had to it over again they would go ap and fuel pump and then straight into a BT setup. So my mods now consist of ap, pump internals, and CS Sri/tip. Whats the least I need to run BT? Or should I focus on other mods first?
pcvang is offline   Reply With Quote
The Following User Says Thank You to pcvang For This Useful Post:
EdgeAutosport.com (02-28-2012)
 Old 02-28-2012, 03:26 PM   #128
To be honest that would make it the ultimate sleeper car. I know plenty of people will tell you to put other supporting mods to maximize the potential of that turbo but it can be fitted with your stock dp and exhaust. With a gtx3071 you could make in the 350ish range. All you would need extra to make this work with your current mods would be a big turbo inlet and that would be it. To be honest a big turbo will net you more power then going with downpipe and full exhaust at this time.
 Old 02-29-2012, 12:14 AM   #129
pcvang's Avatar
Pm me parts list and pricing, and what about a gtx2867? Would I need a mbc or ebcs? Very interested in this. I am almost going to order dp and cbe. But this has got my attention now.
How much difference between 2867 and 3071?
EdgeAutosport.com (02-29-2012)
 Old 02-29-2012, 10:13 PM   #130
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
what are the spring rates on the H&R coilovers. i looked on their site and couldnt find the answear i was looking for i realize they are progressive rate but that isnt enough info. im planning on ordering these regardless next week but was just curious. im excited to spend some money on your site. you guys have great customer service. speedy responses and answer all the questions we have. thanks guys.
Jhornbrook is offline   Reply With Quote
The Following User Says Thank You to Jhornbrook For This Useful Post:
 Old 02-29-2012, 10:24 PM   #131
John you are absolutely correct, H&R doesnt release the info on the spring rates on their coilovers for our car. We have even called them to get the info but no dice, let us know if you have any other questions!
 Old 03-02-2012, 05:37 AM   #132
Mistersix's Avatar
Posts: 2,585   (View Stats)
any luck on that fender roller?
I'm also gonna need 10mm spacers, studs, front pads, and maybe spc ball joints. how bout a heat gun rental to go with the roller?
The Following User Says Thank You to Mistersix For This Useful Post:
EdgeAutosport.com (03-08-2012)
 Old 03-07-2012, 09:02 PM   #133
blue 2011's Avatar
Posts: 17   (View Stats)
blue 2011 will become famous soon enough
looking for first mods going to get sri tip and rmm will i have any problems running this with the stock tune and stock hpfp
blue 2011 is offline   Reply With Quote
 Old 03-08-2012, 10:08 AM   #134
No ETA on the roller just yet sorry for the delay on it.
You will be fine as you will not be increasing boost levels.
 Old 04-06-2012, 10:25 PM   #135
2.3speed06's Avatar
I was wondering how much would lowering spring make a difference on handling wise in my MS6. Never owned a lowered car before, n just wanted to know if there's a real good noticeable difference in the handling of the car. I know the obvious choice would be a good coil over or nice springs with shocks n struts. But that's a little to expensive for me right now. Thanks in advance.
 Old 04-06-2012, 10:47 PM   #136
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Do you guys sell/rent the injector puller that comes with the cpe safe seals? Picked up the ptp set but would rather not use a pick to pull the injector out.
TEAM LUXURY
 Old 04-07-2012, 01:14 AM   #137
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Are you guys no longer doing the Grimmspeed throttle body?
 Old 04-20-2012, 12:16 AM   #138
Bob-o's Avatar
@eric@edgeautosport
I may or may not have remember either you or JP or someone posting about the cable that connects your accessport to your car?
I remember vaguely reading that there was a defect in the cables, causing the AP to lose communication once you try to start a log, and it appears my AP is one of them. Could you give me some insight on the situation, and what I need to do to remedy it?
The Following User Says Thank You to Bob-o For This Useful Post:
EdgeAutosport.com (04-20-2012)
 Old 04-20-2012, 12:31 AM   #139
speed3sb's Avatar
Posts: 83   (View Stats)
speed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud of
Originally Posted by Arodr260 View Post
i haz smoking turbo
i raised the idle with my hypertech and went away, but i noticed it came back the other night. im going to change the oil to see if it helps, which exactly should i use?
5w 40....its smoking...count down to blowing the turbo...Mine blew..a kittle smoke then the next day on the track first run and boom bye bye turbo....goodluck!
speed3sb is offline   Reply With Quote
 Old 04-20-2012, 02:17 PM   #140
@eric@edgeautosport
http://www.mazdaspeedforum.org/forum/foru...cables-105944/
Here you go bro!
Bob-o (04-20-2012)
 Old 04-20-2012, 02:30 PM   #141
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
when is a good time to go from 5w30 to 5w40? mods in sig
i had denso itv22, but one of them broke two days ago. the porcelain part broke off. there were even little pieces in the cylinder. the shop cleaned out the pieces, but unfortunately i have no extra itv22s so i put the stock one back... so im now running three itv22s and one stock... and we all know that itv22 are probably not going to be available soon... So i guess it's the NGK.
for the NGK i know we have to gap it to 0.026-0.028
now should i go 0.026, 0.027 or 0.028?? or is there not much difference?
also, should i just buy one NKG one step colder to replace that one plug, or should i just replace them all with NGKs and have the densos as back ups...
2011 VRM w/ tech pkg
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Autotech FP internal
Moddiction Anvil shift knob
JBR solid shifter bushing
SURE ShortCut+CounterShift
Corksport LED light kit
Corksport lug nut set
Enkei Raijin
Corksport LED fog light kit
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
dhsieh911018 is offline   Reply With Quote
 Old 04-20-2012, 02:34 PM   #142
Replace all the plugs and gap them at .026 and you can switch the oil at anytime!
 Old 04-20-2012, 03:44 PM   #143
got it!
i read the rotella t6 thread. and i see some debates over seafoaming between oild changes.
im currently running castrol syntech 5w30, is it save to just switch over to rotella t6 5w40 without any sort of treatment?
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Enkei Raijin
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
The Following User Says Thank You to dhsieh911018 For This Useful Post:
 Old 04-20-2012, 03:48 PM   #144
Originally Posted by dhsieh911018 View Post
got it!
Nope you should be good to go.
 Old 04-20-2012, 05:31 PM   #145
the grimspeed EWG block offs would work on racebuilt manifold's ewg?
 Old 04-20-2012, 05:42 PM   #146
If they are the same size yes
breakfstincluded (04-21-2012)
 Old 04-21-2012, 09:05 AM   #147
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
Same question as breakfastincluded.
Do you guys still sell the Grimspeed throttle bodies?
Sent from my DROIDX using Tapatalk 2
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
The Following User Says Thank You to m249saw For This Useful Post:
EdgeAutosport.com (04-23-2012)
 Old 04-21-2012, 09:39 AM   #148
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
How much gain would I get changing the exhaust mani?
Since im doing full cat back as well
Thanks
2012 CWP Mazdaspeed3 Current Mods: Cobb Turbo Back|Cobb Sri/Tip|Cobb XLE|Cobb Ap|Jbr Heavy Shit Knob|AutoTech Internals|JBR Short Shifter Plate/Brushings|Corksport Tmic|
Noodlesincup is offline   Reply With Quote
The Following User Says Thank You to Noodlesincup For This Useful Post:
 Old 04-23-2012, 10:26 AM   #149
Sorry good sir we dont carry that product anymore
Thanks
You wont see an over all increase in power but delivery will be smoother and stronger. The reason is the k04 is the choke point not the manifold
Last edited by EdgeAutosport.com; 04-23-2012 at 10:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-25-2012, 02:11 PM   #150
Bob-o's Avatar
Question regarding H&R wheel spacers. One side is completely flat. One side has a concave lip by the center bore. Which side faces out?
Also, in the order i got from you guys, i don't know if one of the spacers was drilled right, but it seems very hard to get onto my hub compared to the other spacers. Is it normal to have to force these guys on? And I mean really force them.
EdgeAutosport.com (04-25-2012)
 Old 04-25-2012, 02:13 PM   #151
silvapain's Avatar
Groans: 136
Beveled side goes towards the hub; flat side out.
Tapadatass
Bob-o (04-25-2012), EdgeAutosport.com (04-25-2012)
 Old 04-25-2012, 02:15 PM   #152
Bob-o's Avatar
Okay thats what I thought. Thanks mate!
 Old 05-10-2012, 10:50 AM   #153
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Do you have installed pics of a grimmspeed ebcs floating around anywhere? I've done some looking on here without much help. The gs images they've provided in the instructions don't make me feel super confident about tackling the install. Thanks!
Looking mainly for the vacuum line area, where the cap goes and such.
Sent from an iPhone conformist using Tapatalk
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 06-04-2012, 12:35 AM   #154
Bob-o's Avatar
Lowered my car on H&R springs with bilstein sports. Now I have a TERRIBLE clunk in the front, and I think it is because my front end links are too short. I've read and read, and came across: front sway end links
Over bumps, I can feel my front sway bar slapping under my feet.
I think I need new, longer/adjustable end links, but I wanted to double check.
If I were to get new links, would these be the ones?
http://www.edgeautosport.com/whiteli...-endlinks-ms3/
@eric@edgeautosport
 Old 06-04-2012, 02:55 AM   #155
maynard576's Avatar
Posts: 36   (View Stats)
maynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud ofmaynard576 has much to be proud of
So. I've owned my ms3 for a little over a week now. During that week i've read a metric fuckton of info on these forums and decided that my first purchase will more than likely be the jbr trilogy mount set. My question is: How much difference is there between the 70, 80, and 88 Durameter mounts. I get that the 70 is more for the street and the 88 is more for straight race. I'm just unsure about any other differences there may be.
maynard576 is offline   Reply With Quote
 Old 06-04-2012, 03:51 AM   #156
2.3speed06's Avatar
Idk about the pu's or having all three mounts, but me n my friend have MS6's. I have the 70 duro sure rmm n he has the jbr 88 rmm. I love my mount n he loves mine too. He can't even have change in his cup holder or anything cuz it vibes so much. He loves his too but is annoyed by the vibes in lower rpms n the little shit that rattles cuz of it. If your not going all out on the car I personally think that the 70 would be your best choice. You can feel a huge difference in performance either way you go tho. Just depends how much vibe you want lol
maynard576 likes this.
The Following User Says Thank You to 2.3speed06 For This Useful Post:
maynard576 (06-04-2012)
 Old 06-05-2012, 10:43 AM   #157
maynard576's Avatar
1 more question. I'm nearing the end of my break-in. I've decided to go with the Rotella T6 oil for my engine lube. The only question I have is whether or not anyone is running any oil additives at all. I was looking at the lucas oil stabilizer and it seems like some pretty good shit. Is it worth it to add a bottle (1 qt) of this at every oil change? Will it actually help to minimize wear in the motor? Not trying to be an epic brownie or anything just didn't find an answer when I searched.
The Following User Says Thank You to maynard576 For This Useful Post:
EdgeAutosport.com (06-05-2012)
 Old 06-05-2012, 10:45 AM   #158
No worries thats what we are here for! You will be fine with just the t6 rotella with no additives
Let me know if you have any other questions
maynard576 (06-05-2012)
 Old 06-09-2012, 08:03 AM   #159
Like ^^ said you should be alright. If you want a cheap feel better additive check out rislone full engine treatment.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
EdgeAutosport.com (06-11-2012)
 Old 06-11-2012, 08:50 AM   #160
I love this thread it has some great info in it
Bolt help iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-25-2009 11:26 AM
Fully bolt SS/SC vs MS3 Bigbody250 Street Racing Stories ( Bench Racing ) 12 06-22-2009 09:24 PM
Getting new intercooler bolt? iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 11 05-18-2009 04:28 PM
Page generated in 0.58062 seconds with 38 queries
