Like Tree8Likes
 Old 08-28-2014, 10:04 AM   #41
KCi
KCi's Avatar
Posts: 93   (View Stats)
I thought we should able reuse OE PCV when upgrading to PERM plate. Yes or No?
 Old 08-28-2014, 10:07 AM   #42
SpeedyTater's Avatar
Posts: 155   (View Stats)
SpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond reputeSpeedyTater has a reputation beyond repute
You can reuse the OEM one but when you run a catch can you want one on both sides of the can. Then you use the check valve provided in the kit for the vented catch can.
Sent from my DROID RAZR using Tapatalk
2009 Mazdaspeed 3
HX35/GT30 series hybrid, 3.5" intake and MAF, CP-e catless downpipe, CNT 3" catback, Tial 38mm wastegate, Greddy Type RS BOV, KMD fuel pump internals, COBB AP self tuned, JBR EGR delete, JBR coolant bypass, JBR gasket set, VTSC delete, ported and polished intake manifold, Bosch 3 bar, Cobb EBCS, Treadstone TR8L, NGK plugs, TRZ Dog Bone, JBR TMM, RKM Shifter Bushings, JBR short shift plate & knob, Fiber Images CF hood/roof/hatch, Tein lowering springs, Koni yellows, StopTech drilled and slotted rotors, Rx8 wheels with 235/40/18 Sumitomo HTR Z III.
Dyno numbers from summer of 2012 (K04) - 319hp/347tq
Dyno numbers HX35 - Coming soon
SpeedyTater is offline   Reply With Quote
The Following User Says Thank You to SpeedyTater For This Useful Post:
EdgeAutosport.com (08-28-2014)
 Old 08-28-2014, 11:44 AM   #43
You can reuse the OEM PCV Valve as long as its still functioning properly.
This is how it should be setup with the PERM Plate.
You just need a check valve between the PCV Plate and vented can and you need the PCV Valve between the PCV Plate and the non vented can. A check valve goes between the non vented can and the intake manifold to prevent boosting the catch can.
SpeedyTater (08-28-2014)
 Old 08-28-2014, 03:37 PM   #44
dagrimey1's Avatar
Posts: 1,246   (View Stats)
Originally Posted by IMASA View Post
Really?
I was going to install it this way
http://www.permtuning.com/images/PCV...boost_flow.jpg
How can I add the OEM PCV to my order?
I think that is a PCV check valve you are referring to. Not the actual PCV plate.
 Old 08-31-2014, 10:02 AM   #45
skiptowncat's Avatar
Posts: 1,592   (View Stats)
You are correct then. For some reason I was thinking the kit came with a PCV valve but I just checked and it just comes with the check valve. The OE PCV Valve is $18.44. If you call in or send me a PM I can include that with your order.
I need your zip so I can get you a quote.
We currently have 3 people who have used the PERMGB5 code. We need 2 more and we'll start shipping them out.
Wn12ta
Tuned with by
 Old 09-03-2014, 09:04 AM   #46
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Well, no need for VVT now
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
ItsNox (09-05-2014)
 Old 09-03-2014, 04:20 PM   #47
We are almost at the mark for the Perm Plates. We need one more and we should be good to go on those. I'm gonna hold it open until the 19th of September. Once 5 people have paid we will ship them out but the coupon code will still be active until the 19th. After the five, we will ship them out as the orders come in.
 Old 09-03-2014, 04:50 PM   #48
Somebody buy a perm plate so I can finally turn the boost up without making an oil volcano out my dipstick tube.
2009 Mazdaspeed 3
The Following 3 Users Say Thank You to SpeedyTater For This Useful Post:
865ms3 (09-03-2014), EdgeAutosport.com (09-04-2014), ItsNox (09-05-2014)
 Old 09-05-2014, 12:18 AM   #49
Originally Posted by skiptowncat View Post
Wn12ta
@EdgeAutosport.com; shipping quote?
Tuned with by
 Old 09-05-2014, 08:24 AM   #50
Sorry about that! Shipping to that zip will be $61.35.
 Old 09-08-2014, 03:45 PM   #51
Looks like we still need two more PERM Plates to complete the group by!
 Old 09-08-2014, 03:46 PM   #52
Did somebody back out?
2009 Mazdaspeed 3
 Old 09-09-2014, 01:23 AM   #53
KCi
KCi's Avatar
C'mon guys. Don't let those subscribing to GB hanging half way.
 Old 09-09-2014, 11:00 AM   #54
No body backed out, just miscounted before. Surely there are two more out there who want to benefit from better crank case ventilation...
 Old 09-09-2014, 04:45 PM   #55
slvrbullet's Avatar
Posts: 7   (View Stats)
slvrbullet will become famous soon enough
Wish I would have saw this earlier I just ordered one off the site last Friday. Any chance the code could still be used? It could help some of the other fellas get there perm plates sooner. Also what is everybody running for the catch can/s?
slvrbullet is offline   Reply With Quote
 Old 09-10-2014, 11:45 AM   #56
Let me see what we can do...
 Old 09-12-2014, 06:28 PM   #57
VRM_MS3's Avatar
Posts: 317   (View Stats)
VRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the worldVRM_MS3 is the leader of the world
I would be interested in the Auto tech internals depending on cost...
i am also interested on internals
2010 VRM Mazdaspeed3
VRM_MS3 is offline   Reply With Quote
The Following User Says Thank You to VRM_MS3 For This Useful Post:
EdgeAutosport.com (09-15-2014)
 Old 09-15-2014, 04:46 PM   #58
Still need two more PERM Plates!
 Old 09-16-2014, 12:24 PM   #59
stoickiwi's Avatar
Posts: 235   (View Stats)
stoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the world
I'd be interested in picking up some internals.
stoickiwi is offline   Reply With Quote
 Old 09-22-2014, 12:47 PM   #60
Any updates on the perm plates?
2009 Mazdaspeed 3
 Old 09-22-2014, 04:41 PM   #61
We'll be contacting the three guys who are in on the PERM Plate deal tomorrow to either give them a refund or charge them for the difference between the 5 person buy in and the 3 person buy in. We unfortunately did not make it to 5 people...
 Old 09-23-2014, 08:19 AM   #62
Originally Posted by blkspd3 View Post
Yeah, I'm interested in the Perm Plate and Autotechs, but knowing the group buy price is what would determine whether I pull the trigger now or not.
Originally Posted by Blown_Dan View Post
I'm looking at internals soon, so I'll be keeping my eye on this thread. Might do the PERM plate, too, if the timing/price is right.
Originally Posted by Badger_ View Post
Possible interest in autotechs
I'll be down to order intervals here in a few weeks.
Originally Posted by grade247 View Post
Might be in for internals depending on price
Not a bad price for the FP internals!
I just quoted everyone who mentioned interest in the autotechs. Plenty here to do the GB price. Post up if you are still interested and I'll message you the price.
 Old 09-23-2014, 01:32 PM   #63
Raiders Bitch
Shampu's Avatar
Posts: 803   (View Stats)
Bought some during the Labor day sale. @EdgeAutosport.com; Thanks for looking out though.
Instagram: Genpu_Drew
235/40 Pilot Super Sports
Tuned by Nishan
25% E85
EdgeAutosport.com (09-23-2014)
 Old 10-03-2014, 05:22 PM   #64
Badger_'s Avatar
Posts: 1,572   (View Stats)
Badger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the world
Default The EdgeAutosport All Group Buys All The Time Thread
PM fail. Carry on.
2007 MS3
Injen SRI | CS TIP | CS TP | 3" TP-Back Straight Pipe | AT Internals
All Mounts | Koni Oranges | Eibach Springs | Moog Endlinks
Thermal Insulating Gaskets | TB Coolant Bypass
AP V3 | FreekTune | Russian Dashcam Mod
Badger_ is offline   Reply With Quote
 Old 10-05-2014, 10:29 AM   #65
danosrk's Avatar
Posts: 130   (View Stats)
danosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the world
Anyone in to try the PERM plates again?
Go catch a headlight
Things learned from 2014 deployment:
1. Tomahawks will kill you
2. Remember that one time you didn't suck at your job? Yeah, neither do I.
3. I work with enough retards on my ship that we should qualify for extra money from the government
Purple Drank Tuned
Wiseco Pistons/Manley H-beams/JBR BSD/JBR Oil Pan Baffle/ACT 6 Puck/Streetlite Flywheel/CP-E Exhaust Mani/GTX2867R/CP-E Catless DP/Electronic Exhaust Cutout/HTP 4" Intake/PERM PCV Plate/Damond Dual OCCs/Kozmic EGR Deletes/Coolant Bypass/CP-E Safe Seals/CP-E HPFP/Grimspeed 3 Port EBCS/3.5 Bar MAP/CX FMIC w/ TR8 Core/Devil's Own Stage 2 Meth Kit/NGK Iridium IX/HKS SSQV 4 VTA/JBR 88D Trilogy Mounts/JBR Small Battery Box/Optima Yellow Top/Gram Lights 57F/Dunlop Direzza ZII's/Yellowspeed Coils/DK Rear Camber Arms/CorkSport RSB/GT Spec Rear Tie Brace/GT Spec Link Reinforcement Panel/TWM Short Throw/CP-E Triple Gauge Pod/ProSport EVO Gauges
danosrk is offline   Reply With Quote
 Old 10-06-2014, 10:19 AM   #66
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Running 20psi on the k04, would the perm plate be of any value?
 Old 10-06-2014, 04:12 PM   #67
Couldn't hurt, but it really just depends on how much blow by you are getting. Either way, venting blow by gasses will make more room in the cylinders for fresh air rather than dirty air.
 Old 10-07-2014, 04:05 AM   #68
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Still needing people for that perm plate group buy?
danosrk likes this.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
danosrk (10-07-2014)
 Old 10-08-2014, 11:44 AM   #69
If we can get 5 people together we'll do another group buy. We were only able to get 3 on the last one though.
 Old 10-08-2014, 01:02 PM   #70
What would the price point be at 5? I think I may have seen it already posted but I'm being to lazy to go look again lol.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 10-08-2014, 04:02 PM   #71
shadesofgray19's Avatar
Posts: 794   (View Stats)
This is what they provided previously.
PERM PCV Plate x5 or more = $165.60 including shipping to Continental US
The Following 3 Users Say Thank You to shadesofgray19 For This Useful Post:
danosrk (10-12-2014), EdgeAutosport.com (10-08-2014), King Scumbag (10-08-2014)
 Old 10-10-2014, 04:14 AM   #72
the2falcon's Avatar
Posts: 263   (View Stats)
the2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the worldthe2falcon is the leader of the world
I'm in for a perm plate
danosrk likes this.
the2falcon is offline   Reply With Quote
The Following User Says Thank You to the2falcon For This Useful Post:
 Old 10-12-2014, 09:00 AM   #73
danosrk's Avatar
In for perm plate too, @SBMS316; you in on this?
Purple Drank Tuned
 Old 10-14-2014, 02:48 PM   #74
The coupon code for 5 people is PERMGB5. You guys can use that code to get the PERM Plate for $165.60, but we will not ship them until five people have purchased. I will hold this opportunity open until the first of November. Once we get 5 people who have used the code, we will ship and continue to ship for people who use the code until November 1st. If we do not get 5 people we will either refund your money or we will send you an invoice for the difference and ship the perm plate. Let me know if you guys have any questions!
 Old 10-20-2014, 11:36 AM   #75
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
Has anyone purchased Autotech internals?
 Old 10-20-2014, 02:59 PM   #76
Not with the GB code...
everton99 (10-21-2014)
 Old 10-21-2014, 09:11 AM   #77
tubeman's Avatar
Posts: 11   (View Stats)
tubeman has a spectacular aura abouttubeman has a spectacular aura about
I need me some internals!
tubeman is offline   Reply With Quote
The Following User Says Thank You to tubeman For This Useful Post:
EdgeAutosport.com (10-21-2014)
 Old 10-21-2014, 09:31 AM   #78
Bfleyva's Avatar
Posts: 8   (View Stats)
Bfleyva is a glorious beacon of lightBfleyva is a glorious beacon of lightBfleyva is a glorious beacon of lightBfleyva is a glorious beacon of lightBfleyva is a glorious beacon of light
Me too! That is next on my list!
Bfleyva is offline   Reply With Quote
The Following User Says Thank You to Bfleyva For This Useful Post:
 Old 10-21-2014, 02:34 PM   #79
Well we have got plenty here for you!
 Old 10-21-2014, 10:42 PM   #80
kopf's Avatar
Posts: 327   (View Stats)
kopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the world
I need internals as well, so that should make the minimum 3 yeah?
kopf is offline   Reply With Quote
Any Group Buys for Cobb AP's?!?!?! DarkPasseng3r Gen2 MS3 General Discussion 5 11-04-2011 06:41 PM
Group Buys are Us! ptperformance Mazdaspeed3/6 General Discussion 14 04-13-2009 09:56 PM
Group buys. Demi Mazdaspeed3/6 General Discussion 6 10-13-2008 12:26 PM
Page generated in 0.56458 seconds with 39 queries
