 Old 06-14-2012, 08:39 PM   #1
blakkat's Avatar
Posts: 572   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
Default exhaust issue
hi, can someone help me out here, i think you guys may have accidentally sent me an obx exhaust. the fitament is off and its banging on the back, and also there are no ultimate racing logos on the exhaust like all other authentics i have seen. please get back to me asap.
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
 Old 06-14-2012, 08:50 PM   #2
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
can't be obx since it has bee on back order since the beginning of time. might be a speed daddy exhaust lol.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
deadlandxtreme (06-14-2012)
 Old 06-14-2012, 09:05 PM   #3
blakkat's Avatar
ok so here are some pictures, let me know what you guys think
Mods:
 Old 06-14-2012, 09:09 PM   #4
SLOWHATCH's Avatar
Groans: 274
IMO if it doesn't say UR on it, I'd ask for refund or exchange. IMO, does not look like the UR exhaust. The UR exhaust looks like a bunch of small pieces of tubing welded together. That looks like speed daddy exhaust IMO.
 Old 06-14-2012, 09:11 PM   #5
blakkat's Avatar
will definitely call tomorrow. wow im glad i noticed this
Mods:
 Old 06-14-2012, 09:34 PM   #6
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
definitely not a speed daddy exhaust because tips are to small.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 06-14-2012, 09:38 PM   #7
blakkat's Avatar
i guess nobody knows wtf it is lol. heres a couple more pics
Mods:
 Old 06-14-2012, 09:46 PM   #8
jrlms6's Avatar
Posts: 1,436   (View Stats)
jrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the world
http://www.mazdaspeedforum.org/forum/foru...7/index97.html
Post #3851 is a UR exhaust.
2006 Mazdaspeed6 GT - SOLD
Titanium Gray Metallic
SURE Aeros | SURE Sidewinder
Forge V1 | CPE TMIC
Magnaflow CBE | Corksport DP | TXS RP
COBB AP | Autotech Internals
JBR SSP | JBR Shift Weight | JBR Knob
Denso ITV22
2012 MS3 w/Tech - Hit and traded
Velocity Red Mica
COBB SRI | COBB TIP
2006 Mazdaspeed6 GT - Totaled
Liquid Platinum Metallic
CS Stage 2 | COBB AP | CPE HPFP
2006 Mazdaspeed6 GT
Black Mica
CS Stage 2 | CS BPV | CS TBE
COBB AP | CPE HPFP | CPE TMIC
DM RMM
jrlms6 is offline   Reply With Quote
 Old 06-14-2012, 09:54 PM   #9
blakkat's Avatar
Originally Posted by jrlms6 View Post
looks similar, just my tubing looks weird and i have no logos at all
only pic of the tips i have, but there are no logos on the tips
Mods:
Last edited by blakkat; 06-14-2012 at 10:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-14-2012, 09:49 PM   #10
snailD's Avatar
Posts: 3,039   (View Stats)
looks liek a ur to me. does it have writing on the tips? lets see pics of those
 Old 06-14-2012, 10:13 PM   #11
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
speed daddy mufflers are round not oval.
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
The Following User Says Thank You to backward_0 For This Useful Post:
SLOWHATCH (06-14-2012)
 Old 06-14-2012, 10:14 PM   #12
blakkat's Avatar
well im confused. theres no ur logos, but it looks exactly like a ur exhaust, kinda weird.
Mods:
 Old 06-14-2012, 10:38 PM   #13
boosted_out's Avatar
Posts: 244   (View Stats)
boosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the worldboosted_out is the leader of the world
I also received my UR TBE exhaust, and on the catback there is no Ultimate racing writting anywhere, I checked the tips everything, and also not sure on the fitment since one of my hangers ends up approx 1mm from the frame which rattles sumtimes which makes it fucking annoying. But there was a UR decal when I took the wrapping off. Got it off Edge.
Possible bad batch?
Sure RMM / Cobb Sri / H&R springs / M'z style front lip / Cobb AP running stage 2 + sf + 93 / Autotech Internals / 18x8,5 +44 Rota grid / 235-40-R18 BfGoodrich G-Force / UR Catless DP / / UR Testpipe / UR CBE / Turbosmart Dual Port 50/50
Last edited by boosted_out; 06-14-2012 at 10:38 PM. Reason: MSF Database - Automerged Doublepost
boosted_out is offline   Reply With Quote
 Old 06-14-2012, 10:41 PM   #14
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Have you called UR yet? They would be able to answer any questions. Doubt they would let an exhaust ship without their brand on it.. Thats free advertisement they are losing.
And OP your looking at refund(for the difference) more than likely since you've already installed it.
Spoofmastafly is offline   Reply With Quote
 Old 06-14-2012, 10:42 PM   #15
I thought it was my mistake from not tightening it properly everywhere that made the hanger come so close to the frame. I mean it fixable, grinding the hanger just a bit, but I also have nothing that says UR on the parts.
 Old 06-14-2012, 10:51 PM   #16
Tips and mufflers should say UR
 Old 06-14-2012, 11:00 PM   #17
blakkat's Avatar
what do you mean by refund for the difference?
Mods:
 Old 06-14-2012, 11:20 PM   #18
Thing that is weird is that to save me custum fees Eric sent the invoice or w-e to UR because I ordered threw EDge and the package that contained my UR tbe was marked that it came directly from UR in Toronto. Yet i have absolutly no UR marking on my tips or anything, but when I was taking off the bubble wrap from the tip section, there was an UR decal that I got but thats it, and like op's post, I also have a rattle from a hanger being too close to the frame. Ill be doing dp and tp tomorow on a lift so it would be noce to know if I got the right UR parts.
 Old 06-14-2012, 11:26 PM   #19
blakkat's Avatar
you and i are in the exact same boat man. same exact packing and issues
Mods:
 Old 06-14-2012, 11:42 PM   #20
Mean since you've already installed the part. I highly doubt any company would take that back, would refund you the difference in prices between the UR and whatever they sent you. But Edge is a good company so they would most likely take the bite on this.. If its even a screw up. Since now I'm reading it shipped directly from UR, it's their mistake.
 Old 06-15-2012, 02:00 AM   #21
Yes then again it did come directly from UR, and they only sell UR products but why we have no marking whatsoever except a decal and the same rattle which would lead me to think it is a fitment issue possibly? Unless it will fix itself once i put dp and tp friday ( today). Now i dont believe we would have to tag Eric or Jp in this because this is there section, im just really hoping to get an answer. Would suck dick to find out perhaps theres an issue and i gotta put back my oem catback with its rusty bolts. It does sound exactly like the UR so perhaps it was just a new way UR decided to produce there exhausts now " no markings", and for the rattle i have no idea other then i can grind off a bit of the hanger so it wont hit the frame. Exited for response.
 Old 06-15-2012, 06:35 AM   #22
blakkat's Avatar
well i have a downpipe and its still hitting. now that i think about it. i think this is a ur screw up.
Mods:
 Old 06-15-2012, 06:56 AM   #23
backward_0's Avatar
i have gotten TP and DP from UR and they both come packed the way you guys are describing. it looks like there are definitely some fitment issues... you can't bend that hanger away from the chassis?
1997 Eclipse GSX
 Old 06-15-2012, 07:03 AM   #24
blakkat's Avatar
Will try bending it soon, I have corksport hangers on the way
Mods:
 Old 06-15-2012, 07:13 AM   #25
I_Heart_Haters's Avatar
Posts: 1,446   (View Stats)
I_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the world
Groaned at 63 Times in 39 Posts
had the same issue with the rattling. i guess there is a fitment issue. since i didn't have the tools, i had our family mechanic grind off some of the hanger beneath the driver seat and that seemed to work.
2011 Liquid Silver Mazdaspeed3 w/ Tech Package : Corksport SRI # Corksport TIP # Corksport DP # Corksport CBE # JBR RMM # OBX Test Pipe # Turbosmart 50/50 BOV # KMD HPFP # Cobb Stage 2 # 20%/35% Tint
# Varrstoen ES7's 18x9.5 w/ 235/40/18 Continental Extreme Contact DWS # KSport Kontrol Pro Coilovers
I_Heart_Haters is offline   Reply With Quote
 Old 06-15-2012, 08:33 AM   #26
blakkat's Avatar
mine is rubbing there, but theres a loud ass banging by where the rear tow hook is on the frame, i had mistaken it for a blown strut it hit so loud. sounds like someone is taking a sledge to my rear end
Mods:
 Old 06-15-2012, 12:31 PM   #27
That sucks. They must of redesigned. I have no fitment issues with mine, nothing rubs. But I got it in 2010.
 Old 06-17-2012, 02:43 PM   #28
blakkat's Avatar
@eric@edgeautosport
Mods:
 Old 06-17-2012, 06:40 PM   #29
Well today I installed my UR dp and test pipe, and I undid the midpipe and everything to tight everything properly and I got no more rattle, just dont have any marking of UR on them. Dp is honestly the biggest bitch, I heard it was bad and now I can confirm fuckkkk.
 Old 06-17-2012, 10:15 PM   #30
Sorry guys we were moving so I couldnt reply til now. What is posted in the pics is a UR exhaust. We dont carry OBX products so its not one of those
If you guys are having fitment issues we need to contact UR and get this sorted out, we get all our products shipped from them directly as it is to hard to stock parts that are always built to the customers specifications
If they dont have proper labeling on them I will make sure and send them the pics once we get the shop back up after the move. If you want give UR a call they are very helpful and could probably answer your questions but once were all settled here I will give them a call myself.
 Old 06-17-2012, 10:28 PM   #31
UR must have changed the design. Those mufflers look Nothing like my UR exhaust I just took off and sold today. UR mufflers have a clean edge, not what looks like an extra strip of metal wrapped around the edges. The exhaust I pulled off the buyers speed looks just like the ones pictured. Sadly no idea what it is. I would call UR to confirm a design change or find out why the tips don't have their brand on it.
The Following User Says Thank You to Spoofmastafly For This Useful Post:
EdgeAutosport.com (06-18-2012)
 Old 06-19-2012, 06:51 AM   #32
blakkat's Avatar
Eric I don't have time to call them Sorry I work and go to school now from 6am to 8pm fuck sucks but whatever. so if you could contact them it would be greatly appreciated
Mods:
The Following User Says Thank You to blakkat For This Useful Post:
EdgeAutosport.com (06-19-2012)
 Old 06-19-2012, 07:56 AM   #33
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
@blakkat Hey there, thanks for letting us know about the issue. There's no question it's an UR exhaust so I wouldn't be worried about that. A lot of companies hand make their products so every part comes out barely different even as minute of a difference as it is. It doesn't surprise me it doesn't have a badge because whoever welds them might have just simply had an oversight and forgot. It there truly is a fitment issue, that is something UR will have to help with. We'll call them today and get back to you with an answer. They might have a quick solution to this if they've seen it many times before. I'll send them a link of this thread so they can more easily see the pics.
The Following 2 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
boosted_out (06-20-2012), Raider (06-19-2012)
 Old 06-19-2012, 10:58 AM   #34
blakkat's Avatar
Thanks Jp, much appreciated. I know you guys are good but better safe than sorry. I look forward to hearing from you guys. Thanks for the great service
Mods:
 Old 06-19-2012, 02:13 PM   #35
Ok sir, here is UR's response. By the pictures, it looks like this is the exact problem.
Is the problem that the hanger is slightly too long and causing it to rub/rattle? If so, my apologies. If the customer wants we can handle the issue, but I would need it to be sent back to us obviously.
Also, they explained the logo issue and they did have a recent batch of parts without the logo on it so they are aware of that issue. So even though it doesn't have the logo, rest assured it is a UR exhaust.
You will not be responsible for shipping if you'd like UR to fix it but you'll need to send it in first in order to get a replacement. Let me know if that's what you'd like to do. There's also the possibility of you getting it fixed by yourself which would help you with the down time of not having the exhaust on there but that's totally up to you and it's not a problem for UR to fix the issue.
Please advise sir!
Thanks again.
 Old 06-19-2012, 02:21 PM   #36
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
Fuck I thought it was just me. I just installed my UR catback from Edge and the driver side tip hangs low.
Looks like ill be calling them too
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
The Following User Says Thank You to m249saw For This Useful Post:
 Old 06-19-2012, 08:22 PM   #37
blakkat's Avatar
hmmmm, ok i will ponder this until the weekend when it is possible for me to remove it
Mods:
 Old 06-20-2012, 06:21 AM   #38
m249saw's Avatar
I sent them an email to see if I can order another one and have them credit my car when I return the bunk one
 Old 06-20-2012, 06:58 AM   #39
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Damn UR must be having issues lately.. ive had mine on for about 5 months now with no fitment issues.. go it from Jp as well.. Although mine does have the logos on the pipes.. the only complaint ive had on the CBE was a slight rattle at idle, because the first right bend from the mid pipe slightly touches the heat shield..
other then that its been doing great.
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 06-20-2012, 07:17 AM   #40
m249saw's Avatar
This is my second UR exhaust. I agree the first one I bought about 6 months ago was perfect.
This one fitment issues and no logos (not a big deal). Almost like they didnt want their name on this bad batch
Cobb CBE pair to Exhaust Depot DP issue mrjoshyman MazdaSpeed 3/6 - Turbo Induction 3 05-23-2012 04:29 PM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 09:12 PM
custom exhaust from exhaust depot? ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 0 08-30-2009 04:22 AM
Page generated in 0.58600 seconds with 33 queries
